    raspberry pi not booting into emulationstation
    raspberry pi 4
    31 Posts 6 Posters 19.9k Views
      Devenhulk
      so, i am trying to use the raspberry pi 4 on emulation station and its the first time boot up. But when i booted it up it everything was fine until it got out of the boot text it just went black but i can still use the terminal and everything else including stuff like the raspi config.
      Steps i used
      -used a image for emulation-station from the official site(https://retropie.org.uk/download/)
      -reformatted my SD card to fat 32
      -wrote the image to my sd card (used etcher to write it)
      -booted it up
      -used config text for safe mode and no display(this made me able to atleast go to the terminal)
      -power supply is efficient and i know all the wires and cables are in working order and meant for the raspberry pi
      i have tried to start from fresh and do everything again like 3 times now i don't know what to do.and that's about it please help i was really exited to see the performance on the raspberry pi 4.
      Ty for the help! (;
      • IceChes1I
        IceChes1
        Type emulationstation into the terminal. Then, when you're in, go to Configuration>RetroPie-Setup>Configuration Options>autostart>Boot to Emulationstation. Select it and then reboot the Pi.
        HOME CONSOLE
        Pi 4
        SanDisk 64 GB
        Master branch install
        3.5 amp CanaKit PSU
        Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
        HANDHELD
        Pi 0 W
        SanDisk 32 GB
        Random image I found. Had a driver I needed.
        IPEGA PG-9157 USB Receiver
          Devenhulk
          This post is deleted!
            Devenhulk @IceChes1
            @IceChes1 i tried that but when i type in emulation station it just goes back to a black screen
              You should add the rest of the information asked in https://retropie.org.uk/forum/topic/3/read-this-first.
              What display are you using (TV/Monitor) ? Did you connect the HDMI cable into the 1st port (next to the USB-C power port) ?
                Devenhulk @mitu
                @mitu im using a monitor and yes i connected everything i can still use the terminal so i know i am getting a HDMI signal and the red light isn't blinking so i am pretty sure the power is good
                mituM D 2 Replies Last reply Reply Quote 0
                  mitu Global Moderator @Devenhulk
                  @Devenhulk Can you run, from the terminal, tvservice -s and post the output ? What monitor are you using (model/vendor) ?
                    Devenhulk @Devenhulk
                    @mitu im using a scripture monitor and a 128 gb SD
                      Devenhulk @mitu
                      @mitu yes i can it says state 0x6 {dvi custom rgb full 4;3} 640x480 60.00hz, progressive
                        Never heard of this and can't find any reference to it - can you be more specific ? Model number ?
                          Devenhulk
                          mb i meant to say Sceptre monitor E225W-1920
                            Post your config.txt - as it it now.
                              Devenhulk
                              For more options and information see
                              http://rpf.io/configtxt
                              Some settings may impact device functionality. See link above for details
                              uncomment if you get no picture on HDMI for a default "safe" mode
                              hdmi_safe=1
                              uncomment this if your display has a black border of unused pixels visible
                              and your display can output without overscan
                              #disable_overscan=1
                              uncomment the following to adjust overscan. Use positive numbers if console
                              goes off screen, and negative if there is too much border
                              #overscan_left=16
                              #overscan_right=16
                              #overscan_top=16
                              #overscan_bottom=16
                              uncomment to force a console size. By default it will be display's size minus
                              overscan.
                              #framebuffer_width=1280
                              #framebuffer_height=720
                              uncomment if hdmi display is not detected and composite is being output
                              #hdmi_force_hotplug=1
                              uncomment to force a specific HDMI mode (this will force VGA)
                              #hdmi_group=1
                              #hdmi_mode=1
                              uncomment to force a HDMI mode rather than DVI. This can make audio work in
                              DMT (computer monitor) modes
                              #hdmi_drive=2
                              uncomment to increase signal to HDMI, if you have interference, blanking, or
                              no display
                              #config_hdmi_boost=4
                              uncomment for composite PAL
                              #sdtv_mode=2
                              #arm_freq=800
                              Uncomment some or all of these to enable the optional hardware interfaces
                              #dtparam=i2c_arm=on
                              #dtparam=i2s=on
                              #dtparam=spi=on
                              Uncomment this to enable infrared communication.
                              Additional overlays and parameters are documented /boot/overlays/README
                              Enable audio (loads snd_bcm2835)
                              dtparam=audio=on
                              [pi4]
                              Enable DRM VC4 V3D driver on top of the dispmanx display stack
                              dtoverlay=vc4-fkms-v3d
                              max_framebuffers=2
                              [all]
                              #dtoverlay=vc4-fkms-v3d
                              overscan_scale=1
                                Replace hdmi_safe with
                                hdmi_group=1
                                hdmi_mode=16
                                hdmi_drive=2
                                and see if you get a proper picture.
                                  Devenhulk
                                  okay ill try thanks
                                    Devenhulk @mitu
                                    @mitu i tried all 3 but when i try to boot up it doesn't Evan show that it finds a signal anymore so i switched it back to HDMI_safe
                                      @Devenhulk Try choosing another video mode - see https://www.raspberrypi.org/documentation/configuration/config-txt/video.md. It's strange that for a monitor that claims to support 1080, setting the video mode to 1080p doesn't work.
                                      EDIT: you can add
                                      hdmi_ignore_edid=0xa5000080
                                      to the previous lines, this will make the Pi ignore what your monitor sends in the EDID.
                                        Devenhulk
                                        @mitu k ill go try that
                                          Devenhulk @mitu
                                          @mitu i am sorry for the late reply been a little busy but when i type in those lines it still doesn't change that it boots up and there's a black screen i can still access terminal though but when i type in emulation station it just goes back to the black screen
                                            Devenhulk
                                            hey guys solved the problem it was the hdmi it needed to be closetest to the power
