Navigation
    • Search
    Help with controls in PC9800
    Help and Support
    pc98 rpi 3b+
    4
    5
    66
    • phineascage
      phineascage last edited by
      Pi Model or other hardware: (3B+)
      Power Supply used: (12V/3A)
      RetroPie Version Used (4.4.1):
      Built From: (Raspbian Buster with desktop)
      USB Devices connected: Logitech F710
      Controller used: Logitech F710
      Error messages received: None I have seen
      Guide used: (https://github.com/RetroPie/RetroPie-Setup/wiki/PC-9800)
      File: (home/pi/RetroPie/roms/pc98/Rusty.hdi)
      Emulator: (PC 9800)
      Attachment of config files:
      How to replicate the problem: start rom
      I can't get my controller to work for games in PC 9800. I've looked at the retroarch menu for settings/inputs/input binds and and I don't think anything is out of the ordinary. My controller works in other emulator games so my system controller setup must be good. Can anyone help?
      • mitu
        mitu Global Moderator last edited by
        There is more information about the input handling at https://github.com/libretro/NP2kai.
        • phineascage
          @mitu Thanks. I read that and it didn't answer my question. I figured it out anyway though.
          Arcanthur ecto 2 Replies Last reply Reply Quote 0
          • Arcanthur
            Arcanthur @phineascage last edited by
            @phineascage said in Help with controls in PC9800:
            How did you resolve this issue? I'm running into the same problem
            • ecto
              ecto @phineascage last edited by
              @phineascage I have a similar problem. What did you do to get the controller input to work?
