    Dolphin blue & Extreme hunting 2 Atomiswave Problems
    atomiswave
    10 Posts 4 Posters 1.6k Views
    • shavecatS
      shavecat
      So iv'e played dolphin blue just got the last log (last level) and in like 2 min the in the level its froze the music goes on and i can exit but the game froze and cant play it .
      Extreme hunting 2 gives me this error on the start on the boot after the logo Atomiswave -
      eroor occurred
      100 netbd not respond .(also tried different roms with both games but still ...)
      anyoneelse try that ? or i was able to play them right ? thanks ahead
      • KrakatoaK
        Krakatoa
        Did you try going in the service menu and turn off the network? Service and test are mapped the l3 and r3. Press them on the boot screen to access.
        shavecatS 1 Reply Last reply Reply Quote 0
        • DarksaviorD
          Darksavior @shavecat
          @shavecat I got a "SH4ThrownException" crash with Dolphin Blue but it seems to be random.
          • shavecatS
            shavecat @Krakatoa
            @Krakatoa
            cant get to the service and test in the boot screen ...
            why ??
            got it thanks
            KrakatoaK 1 Reply Last reply Reply Quote 0
            • KrakatoaK
              Krakatoa @shavecat
              @shavecat remap the l3 and r3 to your coin and select key in the Retroarch GUI, save, then restart. You can set the controls back after you've made the required changes.
              shavecatS 1 Reply Last reply Reply Quote 1
              • shavecatS
                shavecat @Krakatoa
                @Krakatoa
                got it thanks :)
                extreme hunting 2 ? u got it working by Chance ?
                • KrakatoaK
                  Krakatoa @shavecat
                  @shavecat I get the same error.
                  • shavecatS
                    shavecat @Krakatoa
                    @Krakatoa
                    Got u thanks ;)
                    • Y
                      Yobiwan
                      Dolphin Blue crashes at level 2 here. I've tested 2 differents versions (bin/lst and bin) and the game stops at the exact same spot. No error, it just returns back to ES...
                      Pi4 4Go
                      RetroPie 4.6.6
                      SD 32 Go
                      USB 256 Go
                      Y 1 Reply Last reply Reply Quote 0
                      • Y
                        Yobiwan @Yobiwan
                        Can't open network settings, the option is grey...
