    Redream crashes..again and no idea how I solved it.
    redreamcrashcrashesdreamcast
    17 Posts 5 Posters 7.8k Views
    • DarksaviorD
      Darksavior
      This time, someone else on facebook verified to have the same problem. Latest binary. It crashes so I can't get the version number. I'll assume it's build # v1.5.0-283-g12a313d.
      Slightly different crash messages.
      CHD = https://pastebin.com/6JhAdV53
      GDI = https://pastebin.com/9Tdtsys4
      CDI = boots to dc bios menu
      @inolen
      How I solved it? I tried the latest binary at the website (same one I'm assuming that it installs), fixed its permissions, and that's it. Then uninstalling (to wipe the whole redream folder) and reinstalling with retropie-setup's binary now works..
      I've never encountered such a weird emulator. A few weeks ago I had usb reading problems. I finally got a brand new usb 3.0 stick so hopefully no more problems with that..
      mituM quicksilverQ S 3 Replies Last reply Reply Quote 0
        mitu Global Moderator @Darksavior
        @Darksavior Maybe it's your overclock ?
          Simrose
          Retropie 4.6.1
          PS4 Controllers
          I have been keeping mine updated whenever new updates are available and so far not had any issues with redream. I have been playing lots of games on it. All in Chd format.
          • quicksilverQ
            quicksilver @Darksavior
            @Darksavior said in Redream crashes..again and no idea how I solved it.:
            No problems on my end. I just updated yesterday. Can you try without the USB flash drive? Maybe just load a ROM or two on the SD card itself just to rule that out?
            • quicksilverQ
              quicksilver
              Ok so I tested a bit more and I just had a game freeze up on me
              Edit: can't reproduce it though
              Edit 2: Another game just crashed after running for 15-20 mins.
              @Darksavior How quickly do the crashes occur for you?
              • DarksaviorD
                Darksavior @quicksilver
                @mitu The games would instantly crash back to the menu so it's not my overclock. My other games from other systems load fine.
                @quicksilver When it happened? Instantly. I can't reproduce it anymore that's why I said it's weird. What's interesting is that a guy on fb is having the same problems. The usb problem was from my old stick and this one's brand new. If this lone system is giving me issues and not the rest, I'm not going to remove it from troubleshooting.
                • quicksilverQ
                  quicksilver
                  The crashing issue I was having was due to my wireless Xbox 360 controller disconnecting. As soon as it went to sleep, redream would crash. I reported to inolen and he stated it looks like an sdl bug, of which he will report upstream.
                    Simrose
                    I tested mine with a 2 player approx 45 mins yesterday still no issues.
                    Using 2 ps4 dualshock bluetooth controllerrs.
                    It will be interesting to know if Darksavior uses The Xbox 360 Wireless controller also.
                    • DarksaviorD
                      Darksavior @Simrose
                      @Simrose No. Original snes pads connected to gpio for console games. 360 madcatz joystick for arcade games. Ps4 pad for dreamcast and psp.
                        Simrose @Darksavior
                        @Darksavior
                        I just left a game on in background while doing other stuff and when I came back to it after approx 15 mins like you said the game had exited back to ES. No errors on screen. So something to do with sleeping? When playing yesterday it wasn't a problem.
                          Simrose @Darksavior
                          @Darksavior
                          Can you guide me through the fix, I'm not sure how to follow your steps.
                          Thanks Sim
                            Simrose
                            It could be game related as i tried another game and left it for even longer and it didn't exit back to ES
                            Edit I just tried the same game which exits and it happened again very quickly within a few minutes just loading the game up and not doing anything.
                            I will test the game what didn't exit again and a few others
                            • I
                              inolen
                              Hi @Darksavior , this is different from @quicksilver 's issue. Quicksilver hit a bug in SDL where it crashes when the Xbox One controller disconnects after 10-20 minutes, the bug you're hitting is because redream is unable to write to the cache/ directory.
                              I've just pushed a change which prints the filename it fails to write to, but my guess is the whole directory is inaccessible for some reason.
                                Simrose @Darksavior
                                @Darksavior
                                Im only using games which are passed in the compatible charts.
                                Some games don't have issue they stay working but I've found a few now which everytime you load them without pressing any button on controller after they load within 1-3 minutes they exit back to ES.
                                Didn't help me by changing to root or trying latest redream build and reinstalling
                                I noticed I couldn't change the cfg and a few other files in redream emulator folder to root.
                                  mitu Global Moderator @Simrose
                                  @Simrose said in Redream crashes..again and no idea how I solved it.:
                                  You shouldn't be using root to launch games/emulator - this can break existing permissions and lead to unexpected errors down the road.
                                    Simrose @mitu
                                    Thanks I'll uninstall and reinstall. I don't normally change permissions set by retropie. Just thought it might fix it.
                                    I guess I'll just have to try and find another solution
                                    Sim
                                      Simrose @Simrose
                                      @Simrose
                                      My issue was solved by inolen and updated redream binary made available.
                                      Sim
