    4tb external hdd on raspberry pi model 4 running 4.6
    external hdd4.64b model
    10 Posts 3 Posters 1.7k Views
    • Buckey JawB
      Buckey Jaw
      Has anyone had luck with formatting to 4tb fat32? mine is maxing out at 2tb on my external hdd
        Clyde
        Is the drive partitioned as MBR or GPT? As far as I know, only the latter supports FAT32 partitions with more than 2TB (by using 4k sectors rather than 512MB ones).
        That said, why do you want to use FAT32? If you need Windows compatibility, NTFS and ExFAT support >2TB partitions and can be read and written to in Linux / Retropie. If you don't need to use the drive in Windows, just format it with a Linux file system like ext4.
        The package exfat-fuse is needed to mount ExFAT partitions is already installed in the official Retropie image. If you want to format ExFAT as well, you'll have to install the package exfat-utils manually with the command sudo apt install exfat-utils. You can use mkfs.exfat after that (make file system).
        NTFS should be fully installed out of the box in Retropie.
        edit: typo
        • Buckey JawB
          Buckey Jaw
          Thanks, ex4 running good but now getting usbmount service failure
            mitu Global Moderator @Buckey Jaw
            @Buckey-Jaw said in 4tb external hdd on raspberry pi model 4 running 4.6:
            See this topic.
            Buckey JawB 1 Reply Last reply Reply Quote 0
            • Buckey JawB
              Buckey Jaw @mitu
              @mitu I deleted the value listed but still no go, the pi won't see the usb at all now
                @Buckey-Jaw If you remove the usbromservice, then you need to manually mount the disc - https://retropie.org.uk/docs/Running-ROMs-from-a-USB-drive/#configure-fstab-to-automatically-mount-usb-drive.
                • Buckey JawB
                  Buckey Jaw @mitu
                  @mitu ran ls -l /dev/disk/by-uuid/ to get my UUUID of B210AED310AE9E3B on sda1
                  ran sudo nano /etc/fstab to add UUID=B210AED310AE9E3B /home/pi/RetroPie vfat nofail,user,uid=pi,gid=pi 0 2 on the bottom
                  now getting failed to mount home/pi/retropie
                  I verified the drive has the retropie-mount folder
                  BTW thanks for all the help, it's greatly appreciated
                    If your partition is formatted as ext4, then you need to replace vfat with ext4 and also replace the mount options accordingly.
                    UUID=B210AED310AE9E3B  /home/pi/RetroPie      ext4    defaults,noatime 0       2
                    Since this is manually mounted, you don't need a retropie-mount folder (this is only used by the auto-mounting done by usbmount) and you need to manually copy the contents of /home/pi/RetroPie to the disc - this is explained in the documentation page.
                    • Buckey JawB
                      Buckey Jaw @mitu
                      @mitu ahhhhh, I was waiting on the auto copy, it's formatted as ntfs, is that an issue?
                        You'll have to decide what format you have on the disc - is it ntfs or ext4 ?
                        Please use the documentation and follow the instructions - you have to choose one of the methods described there and take into account what filesystem you have.
