    Reminder, PC-Engine/Turbo CD games are case Sensitive!
    turbo cdpc-enginefreezing
    7 Posts 3 Posters 882 Views
    • JirynJ
      Jiryn
      Ran into an issue last night, just thought I'd remind people that the games Cue and Bin/ISO files are case sensitive to one another.
      If they don't match exactly, they won't work on RetroPie.
      https://retropie.org.uk/docs/PC-Engine/
        A Former User
        You can do it yourself by clicking on the 3 dots and then clicking delete
          Do you want to delete your account ?
          JirynJ 1 Reply Last reply Reply Quote 0
            A Former User
            No, I think he means this question/discusion
            • JirynJ
              Jiryn @mitu
              @mitu @Bluebotlabs
              Just trying to delete the thread/discussion/post.
              After I wrote out all the issues I was having and posted it, I double checked my files once again and noticed all the issues I was having was due to the actual file types not being the case the emulator needed to work properly.
              (All the files were .bin, but the emulator was looking for .BIN thanks to the cues files, I was able to fix them all)
              After I figured out the issue, I came back to delete my post, but you can only delete posts within 3minutes of posting.
              After that it's left up.
                mitu Global Moderator @Jiryn
                You should have modified the post, add a [Solved] prefix/suffix and explain how you solved it. Users with similar problems can still search and find it, so if they run into a similar issue they can see the solution.
                Posts are usually deleted for spam/duplicates, not for other purposes.
                • JirynJ
                  Jiryn @mitu
                  Ah thank you!
                  Sorry about all the confusion
                  The answer was simple, and found in your documents.
                  *PC Engine CD
                  It is important that the image file (usually .bin) and the CUE file (.cue) match.
                  CUE files are just text files containing a description of the CD. If you have files named like:
                  Akumajou Dracula X.bin
                  Akumajou Dracula X.cue
                  then ensure the first line of the CUE file contains:
                  FILE "Akumajou Dracula X.bin" BINARY
                  Any of the following are wrong and will not work:
                  extension has incorrect case
                  FILE "Akumajou Dracula X.BIN" BINARY
                  file name has incorrect case
                  FILE "AKUMAJOU DRACULA X.bin" BINARY
                  does not match the actual file name
                  FILE "Akumajou_Dracula_X_-Chi_no_Rinne(NTSC-J)_[KMCD3005].bin" BINARY*
