    Dolphin audio lag
    linux mint 19desktopdolphinaudio delayaudio lag
    1 Posts 1 Posters 1.3k Views
    • W
      Wolf64
      Hi there,
      I'm experiencing audio lag or delay (no stutters or crackling) of roughly a quarter to half a second for all games on Dolphin on my Linux desktop.
      I installed Retropie according to these instructions:
      https://retropie.org.uk/docs/Debian/
      I configured Dolphin via it's GUI, since I can't use lr-dolphin because it won't run at all for some reason. Although lr-dolphin did work before, I had the same audio issue. Anyway, I only configured the controls in the Dolphin GUI and left everything else default, so the audio settings are as follows:
      • DSP HLE (fast)
      • ALSA audio backend
      Dolphin version is this, according to the about-window of the GUI:
      b3c705f
      Branch: master:
      Revision: b3c705fa968b8d9a0ea18da044c6de8841019790
      My desktop specs:
      • Linux Mint 19 x64
      • 16 GB RAM
      • AMD Ryzen 5 2600x
      • NVIDIA RTX 2060
      So, any fixes for audio latency in my case? Also if anybody knows why lr-dolphin suddenly refuses to work, I'd appreciate any fix for that as well.
