    Atari Jaguar at full speed on Pi4 with Lr-MESS
    atari jaguarjaguarlr-messoverclockingpi 4
    3 Posts 2 Posters 1.7k Views
    • DTEAMD
      DTEAM
      Hello,
      I followed this procedure for Atari Jaguar on the Pi4 with Lr-MESS, and OMG...
      https://retropie.org.uk/forum/topic/22600/how-to-emulate-bally-astrocade-vtech-creativision-and-emerson-arcadia-2001-in-lr-mess
      I'm able to run Bubsy and other games at full speed or almost. I switched Astrocade for Jaguar. You have to use jaguar everywhere (Rom folder name, configs, etc.)
      My overclock setting is :
      #OVERCLOCK v3d_freq = 850
      over_voltage=6
      v3d_freq=850
      hdmi_enable_4kp60=1
      arm_freq=2100
      and BIOSes are
      jaguarboot.zip
      jaguar.zip
      jaguarcd.zip
      Have a good weekend!!
        janderclander14
        @DTEAM said in Atari Jaguar at full speed on Pi4 with Lr-MESS:
        Hello,
        I'm able to run Bubsy and other games at full speed or almost. I switched Astrocode for Jaguar. You have to use jaguar everywhere (Rom folder name, configs, etc.)
        over_voltage=6
        v3d_freq=850
        hdmi_enable_4kp60=1
        arm_freq=2100
        and BIOSes are
        jaguarboot.zip
        jaguar.zip
        jaguarcd.zip
        Thanks a lot. I followed your instructions and worked perfectly. However, even though I see better Jaguar performance with lr-mess than with virtualjaguar, framerate is still around 45 fps in most games (it was around 35-40 with virtualjaguar). The sound is particularly scratchy. My cpu is overclocked to 2000. Is there any option to rise fps around fullspeed?
        • DTEAMD
          DTEAM @janderclander14
          @janderclander14
          Thanks for the fps check.
          For the sound, It depends, for some 2D games, the sound is not that bad (not far from a good experience).
          In the Hash file , located in the BIOS/mame/hash folder , they commented slightly on the playability.
          Some games are not playables even on both emulators.
          I'm running Zool 2 or Bubsy at 49 FPS with Lr-Mess and 33 FPS with Lr- virtualjaguar (Big difference)
