    help with reset button on mega drive mk1 case
    reset buttonmega drivebuttons gpiogpio pingpio exit roms
    5 Posts 3 Posters 675 Views
      cockneynutjob
      Hello,
      I know this has been answered as ive read a few other posts but im still not sure and was wondering if someone could tell me how to do it in a simple way, im not a noob with retropie/linux but this one has got me, so what i want to be able to do is connect a button to gpio pin 5 and 6, and when i press the button it quits out of the emulator im playing back to emulation station, now i know theres a script out there to do this can someone point me in the right direction and how to enter it in the retropie terminal, sorry to be a pain just need some help.
      Thank you all
        cockneynutjob @cockneynutjob
        @cockneynutjob anybody?
          Try using @cyperghost's script from https://github.com/crcerror/ES-generic-shutdown, if you run it with the --closeemu parameter it will stop the current running emulator.
            cyperghost @cockneynutjob
            @cockneynutjob Yes multi_switch.sh is very flexible. As default if you connect a switch to PIN 5 and 6 it'll powerdown the whole system but you can easily exchange behaviour with some code edit.
              cockneynutjob
              Thank you very much to you both sorted
