    Problems with 2 wireless USB controls
    controllerscontroller confusb gamepadproblems
    17 Posts 3 Posters 1.5k Views
    • shahikoS
      shahiko
      Hi. I' m new to the world of raspberrys and retropie. A month ago I bought the raspberry PI 4 B and two wireless USB controls. I followed the guide to configure them by the emulator but when we play with the two controls at the same time they stop working, change them 1 for 2, Start stops working and so on.
      I was reading to configure by retroarch but it was not very clear to me if that is what I should do. Can you help me?
      Pi Model 4 B / 4GB
      DAMASO Image 128GB
      Controls: Shanwan 2.4GHz controller 3 in 1
      mituM lostlessL 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @shahiko
        @shahiko said in Problems with 2 wireless USB controls:
        DAMASO Image 128GB
        We don't support 3rd party images. Either ask the author for support or install the image from retropie.org.uk/download.
        • lostlessL
          lostless @shahiko
          @shahiko the two controllers share the same frequency. Therefore interference. Not pi related. My guess as I’ve run into the problem myself, with cheap 2.4ghz controllers
          Try a fresh image and see if you still have the same issue. If so, it’s that.
          • shahikoS
            shahiko
            Ok, thanks for your responses.
            I'm going to try installing another image and test.
            If I do it with the retropie image, should the controls work fine configuring them from the emulator? Shouldn't I do something else?
            Thank you.
            • lostlessL
              lostless @shahiko
              @shahiko With a fresh Image, RetroPie will ask you to configure a new controller when it boots, and the sets up up the controls for all emulators. You only need to configure 1 controller if they are the same. Also see if you still have the the issue with just one controller plugged in. I once had to cheap identical controllers. What would happen is they would both suddenly disconnect and then they would either switch player one or two or they were just reconnect but I would constantly lose signal. It’s from both receivers controllers you seen the exact same frequency. The controllers don’t know which receiver to connect to.
              • shahikoS
                shahiko
                Ok, I will do the test, thanks.
                What controllers do you recommend if I should buy new ones?
                • lostlessL
                  lostless @shahiko
                  @shahiko If going through usb, any wired controller works great. If you want to go wireless, I know the are kinda expensive , but ps4 controllers work very well over Bluetooth, PS3 controllers work well over Bluetooth. Wii U pro pads work great. Get a quality controller. Or if the problem is interference, use one of your controllers You have for player 2 and use a better one for yourself😉
                  • shahikoS
                    shahiko
                    Hahaha, excellent.
                    Thanks, then comment if I could solve it.
                    • lostlessL
                      lostless @shahiko
                      @shahiko but Definitely start with a fresh install. RetroPie is fun to configure to make it your own. It will also teach you how everything works together
                      • shahikoS
                        shahiko
                        Hi.
                        Well, I did a fresh install and I still have the same problem, control 1 becomes 2 and so on.
                        I also made the selection of controls by configuration and it keeps happening.
                        Can you help me @lostless? Thank you.
                        • lostlessL
                          lostless @shahiko
                          @shahiko if you are using the same exact controllers, with both using the exact same wireless frequency, there is not much you can do. You will never know which Receiver either controller wants to connect to. As I said. It’s not a retropie problem. You might have to buy another type of controller that won’t interfere if you want to play 2 players. Other than that just unplug one to play single player.
                          • shahikoS
                            shahiko
                            But I don't understand, if each one connects to a usb port there should be no problems.
                            I read out there that you can change the ID of the control so that it is not mixed associated with each of the USB ports.
                            • lostlessL
                              lostless @shahiko
                              @shahiko as far as I can see, the issue lies with the connection of the controller to the receiver. I’m assuming here, but if both controllers use the exact same frequency, they don’t have any way to tell which receiver to connect to. They will just connect to whatever receiver responds first. At the same time, the interference of the other receiver is also looking for a controller and sees ones turned on, and tries to connect to it. That’s why it disconnects and sometimes changes player. The same issue would happen with with the adaptors connected to a pc. Unless there is a sync button to create a unique identifier on the receiver or controller, this issue will exist. But as far as I can tell, It has noting to do with the pi or usb Ports.
                              Try unplugging one controller and see if you have any issues.
                              • shahikoS
                                shahiko
                                Well I tried it, and you were right @lostless
                                When only one USB is connected, any of the controls works, always one by one. This confirms what you said anyone's signal raises. I am going to try to use them and if it is only confused between 1 and 2 it is not a problem, but if the buttons stop working, as it has already happened to me, yes. Thank you.
                                • shahikoS
                                  shahiko
                                  Hi.
                                  Well, I have finished setting up the retropie completely.
                                  I have left to buy the new controls. My idea is to buy these:
                                  https://www.amazon.com/Logitech-940-000110-Gamepad-F310/dp/B003VAHYQY/ref=sr_1_3
                                  @lostless, If I buy two I will have no problems, right?
                                  Thank you.
                                  • lostlessL
                                    lostless @shahiko
                                    @shahiko they will work. No problems. Player 1 will stay player 1 and player 2 will stay player 2, Depending what USB ports you use.
                                    • shahikoS
                                      shahiko
                                      @lostless Thanks for all. Yesterday I bought two controls and for now they work, I have not been able to test them much. In time I will see how it works.
