    lr-pcsx-rearmed, certain titles not loading after m3u implementation.
    lr-pcsx-rearmedm3uhelp please
    19 Posts 8 Posters 2.4k Views
      Stutter
      Pi 4b
      Retropie v4.6.1
      The Titles in question are Lunar 1&2 and Tales of Destiny 2. All 3 worked well before I implemented m3u playlists to declutter my games list. I've double, tripple, quadruple checked I've formatted the m3u files properly, I've reuploaded the files 3x. Every time, works great with no playlist, as soon as i edit the .cue file extension to .cd# fails to load, crashes back to ES PSX list, no errors in the runcommand.log.
      Is there something I'm missing? A bunch of my other multi-disc games work peachy with the m3u playlists, just not these 3 and it feels like I'm smashing my head on a brick wall here.
      • windgW
        windg
        I can confirmed this.
        Game is booting without problems if i create the .m3u file with .cue extentions instead of .cdx.
          BreadPie
          Same problem here.
          Each disc will boot perfectly individually using bin and cue. But once the .m3u is introduced it fails to load.
            BreadPie
            To clarify: m3u files DO work if 1) the .cue files are kept as .cue files (rather than .CD1, .CD2, etc.) and listed as cue files in the m3u; or 2) when there is only one .bin file per disc then changing the .cue file to .CDX (for both filename and in the m3u) works. But, when there is more than one .bin file per disc, renaming the .cue files does not work with the m3u.
            stooS 1 Reply Last reply Reply Quote 0
              I think this has been reported a couple of times recently - looks like it's worth investigating. @BreadPie - what RetroPie version are you using ?
              EDIT: can anyone provide a verbose log of running a .m3u consisting of .cdX cue files ?
              windgW 1 Reply Last reply Reply Quote 0
              • windgW
                windg @mitu
                I use the game: Lunar - Silver Star Story Complete (USA)
                • Verbose log (.m3u file with .CDx extensions) :
                  pastebin
                • Verbose log (.m3u file with .cue extensions):
                  pastebin
                • stooS
                  stoo @BreadPie
                  This post is deleted!
                  • stooS
                    stoo @windg
                    I can confirm exactly the same behaviour that @BreadPie and @windg are reporting.
                    .cue extensions in m3u = fine
                    .cdx extensions in m3u = broken
                    Does lr-pcsx-rearmed have special behaviour that it applies to .cue files but only if they actually use the extension?
                      OK, I see it now. @BreadPie's diagnostic is correct
                      When the .cue (or .cdX) file is a multi-track disc image, starting the game results in an error, but if the .cue is a single-track (data) disc, it works (i.e. tested with MGS, which has 2 single-track discs).
                      My suspicion is that pcsx_rearmed looks at filename.cdX file, doesn't know what it is, but tries to load filename.bin anyway. For multi-track discs, the data .bin is different than the .cue (it's usually filename (track 1).bin, 1st data track), so game is not loaded.
                      To confirm this, if I symlink-ed
                      'Lunar - Silver Star Story Complete (USA) (Disc 1) (Track 1).bin'
                      to
                      'Lunar - Silver Star Story Complete (USA) (Disc 1).bin'
                      then started the game with an .m3u file consisting of
                      Lunar - Silver Star Story Complete (USA) (Disc 1).cd1
                      Lunar - Silver Star Story Complete (USA) (Disc 2).cd2
                      and the game starts.
                      • stooS
                        stoo @mitu
                        @mitu said in lr-pcsx-rearmed, certain titles not loading after m3u implementation.:
                        That is the key. We just need it to parse .cdx the same as it does for .cue, since .cue files work fine.
                        \pcsx_rearmed-master\libpcsxcore\cdriso.c
                        	if (numtracks == 0 && strlen(isofile) >= 4 &&
                        				strcmp(isofile + strlen(isofile) - 4, ".cue") == 0)
                        				// user selected .cue as image file, use it's data track instead
                        				fclose(cdHandle);
                        				cdHandle = fopen(filepath, "rb");
                        I dunno if this is helpful, I'm not a programmer.
                          mitu Global Moderator @stoo
                          @stoo said in lr-pcsx-rearmed, certain titles not loading after m3u implementation.:
                          Not only that - it should work with .chd files at the same time.
                          The issue doesn't appear when using .chd (.cue + multiple .bin packed with chdman into a single disc file), so that may be a workaround before a solution can be found.
                          • RionR
                            Rion @mitu
                            Plus you save a lot of space by converting your bin/cue files to .chd with chdman.
                            FBNeo rom filtering
                            Mame2003 Arcade Bezels
                            Fba Arcade Bezels
                            Fba NeoGeo Bezels
                            • stooS
                              stoo @Rion
                              @Rion Yeah, CHD is better; I'm not saying loose bin/cue files are ideal, but if the docs say you can use them with an m3u, then that should probably be true. ;)
                                The issue should be solved now - if anyone wants to test (and hasn't converted their games to .chd yet). Just update lr-pcsx-rearmed from source and check if the game loads ok.
                                • windgW
                                  windg
                                  I test it with Lunar - Silver Star Story and the game now loads fine. Thank you very much !
                                  • kcoconnor76K
                                    kcoconnor76
                                    @mitu I'm noticing on the latest binary version of lr-pcsx-rearmed, my .m3u files that point to .CDx files are no longer working with RetroAchievements and had to be changed back to .CHD which puts them in the list of files in RetroPie. Is this the expected behavior now?
                                    So, to get my .m3u files to work again with RetroAchievements, they went from this:
                                    game_disc1.CD1
                                    game_disc2.CD2
                                    game_disc3.CD3
                                    to this:
                                    game_disc1.CHD
                                    game_disc2.CHD
                                    game_disc3.CHD
                                    Now the .CHD files show in the menu in Emulation Station and the .m3u files work with RetroAchievements.
                                    I suppose an interim solution would be to go back to .cue files as mentioned above with .bin files for the games and simply remove .bin and .cue from the es_systems.cfg file so they don't show up in the menu. Ideally though, I'd like to keep the .CHD files to reduce storage space on multi-disc games.
                                    RetroPie 4.8.4 • RetroArch 1.15.0 • Raspian OS • Pi 4B 8GB • WD 2TB SSD • SanDisk 512GB Extreme microSDXC UHS-I • SanDisk 256GB iXpand • Argon ONE M.2 Case • REiiE Keyboard • 8BitDo Pro 2 & Arcade Stick
                                    retroachievements.org/user/kcoconnor76
                                      sleve_mcdichael @kcoconnor76
                                      @kcoconnor76 you could also keep the CHD files in a separate location:
                                      File: /home/pi/RetroPie/roms/psx/Final Fantasy VII (USA).m3u, content:
                                      ../psx_multi/Final Fantasy VII (USA) (Disc 1).chd
                                      ../psx_multi/Final Fantasy VII (USA) (Disc 2).chd
                                      ../psx_multi/Final Fantasy VII (USA) (Disc 3).chd
                                      Then, since roms/psx_multi isn't associated with any system in es_systems.cfg, the CHD files stored there won't be displayed in ES's menu.
                                      This is also what people do with lr-duckstation which doesn't support renaming CHD's at all.
                                      kcoconnor76K 2 Replies Last reply Reply Quote 1
                                      • kcoconnor76K
                                        kcoconnor76 @sleve_mcdichael
                                        @sleve_mcdichael Thanks for the idea! I'll try that!
                                        • kcoconnor76K
                                          @sleve_mcdichael I tried your suggestion for Dreamcast and Playstation and it worked perfectly. Thanks!
