    Help with .sh scripts and global variables
    variablescriptinghelp me please
    3 Posts 2 Posters 397 Views
      red37
      Hi, first post so i hope it wont be to bad. I couldnt find answers anywhere i looked online and im fairly new to linux and retropie.
      So im using mpg123 for background audio and it works fine, stops when games launch and starts when they close. I made 2 scripts in my desktop roms folder where i have my .sh to start the desktop and they work fine, one stops the music and the other will start/restart the music.
      I want to be able to switch the sourse of my music from folder to folder so I have it set an env variable at boot that points to my music selection and i changed my .sh files to use the variable. That all works fine, my problem is.
      I made another .sh file to set that variable to point at my other music folder. I run the script but my variable doesn't update. I read online that its setting a local variable so I tried using the export command and it still doesnt update. How could i get my .sh files to set environment variables globaly?
        You should post your scripts - on pastebin.com - and indicate how you launch each one. Without the source, it's difficult to give any advice.
          red37 @mitu
          @mitu thank you for your reply, sorry i was distracted for a few days. I didnt figure out how to make variables work but i was able to make a txt file that i could read/write as a varriable so im good now.
