    Mame 2003 Plus Options Menu, Low Volume
    mame2003-plusnba hangtimesound volumeoptions menu
    4 Posts 2 Posters 935 Views
    • O
      OldSchool
      Hi everyone,
      I have a few games that are extremely quiet when played using Mame 2003 Plus, and I can't figure out how to get into the options menu to change it. In Mame 2003 (non-plus version) you press F2 and get this menu:
      http://blog.greggant.com/images/posts/2016-12-25-openemu/openemu5.png
      You can change the volume from here, so problem solved. But I can't seem to find that menu for Mame 2003 Plus. There is a menu that I can activate that looks like this:
      https://user-images.githubusercontent.com/19554678/47619589-eb37b600-dab6-11e8-8b20-733d0a09b791.png
      But it doesn't have the same options. For instance, there is no sound volume adjustment available from here. Does anyone know if Mame 2003 Plus includes a menu that lets you adjust the sound, and how to access it? Also, I haven't changed any input options/button mapping other than the initial controller setup in RetroPie, in case that's useful information or not.
      Thanks in advance for any help.
        grant2258 Banned
        This option is easy to fix the input is set to retropad (quickmenu->options->input interface) only you can set this to keyboard retropad or simultaneous(both) set it to simultaneous and you should be good to go.
        O 2 Replies Last reply Reply Quote 1
        • O
          OldSchool @grant2258
          @grant2258 Thank you so much. I'll try it out as soon as I get the chance.
          • O
            @grant2258
            Yep, that was it. Thank you again.
