    changing default emulator per rom
    default emulatorp4
    5 Posts 2 Posters 993 Views
      gorgar19
      rp4 with an official power supply running version 4.6.1 for the rp using generic android game pads last updated two days ago
      Ive notice if you change the default emulator for a rom it won't let you change it back.
      I've tried removing emulator of choice for rom.
      Deleting both emulators and reinstalling
      deleting the config file for the system in config/saturn (for example) and reinstalling the emulator
      is their another location for this config I'm missing
      I've noticed his happening on dreamcast,psp nd saturn emulators haven't tried others the was just some systems I was testing various emulators per game and found once chosen its locked
        The association is saved in /opt/retropie/configs/all/emulators.cfg. For this kind of problems, it's usually an error with either the permissions on this file or the file gets corrupted and cannot be correctly read.
          gorgar19
          Thanks that was the problem
            @gorgar19 said in changing default emulator per rom:
            Which one ?
              gorgar19
              Deleting the file at
              Put the ROMs back to the default emulators
