    Super Mario n64 problem
    n64emulationmario 64pi 4
    34 Posts 4 Posters 4.3k Views
    • UnknownU
      Unknown
      Hi, I just upgraded to a raspberry pi 4 so my n64 roms would run better. The performance is great, but one game seems to have problems. Super Mario n64 runs much better that before, but I can't beat the first level with the bomb-bomb king. Your supposed to run up behind him and press "B" to defeat him, but it is not working. I'm 100% sure that my controller is configured correctly. I'm using emulation-station.
      You can't beat the classics(unless you copy them).
        AdamBeGood @Unknown
        @Unknown So what happens? The button you are using to grab him should be "B" on the N64 Controller. So does pressing that normally during the game do a punch, or dive if you are running?
        • UnknownU
          Unknown
          @AdamBeGood Well the button I use is "B", and what happens is Mario just jumps. I have never seen him punch or dive.
            dankcushions Global Moderator @Unknown
            @Unknown you've misconfigured your controller. reset it via retropie setup > packages > core > emulationstation > reset controller, then reboot.
            be mindful what buttons you configure as A and B.
            • UnknownU
              Unknown
              @dankcushions So "A" is the correct button?
                @Unknown you can see the mapping here: https://retropie.org.uk/docs/Nintendo-64/
                it depends on what core you're using. eg for mupenp64plus-GLideN64, Y is B (punch/grab).
                UnknownU 1 Reply Last reply Reply Quote 0
                • UnknownU
                  Unknown
                  @dankcushions I reconfigured it, but my N64 controller does not have a "y" button. What do you want me to do?
                    @Unknown this is why it's so important to fill out https://retropie.org.uk/forum/topic/3/read-this-first :)
                    in your case, you will have to manually reconfigure the config file. the file you need to edit is /opt/retropie/configs/n64/InputAutoCfg.ini and an example is on the docs page: https://github.com/RetroPie/RetroPie-Setup/wiki/Nintendo-64#example-inputautocfgini
                    you'll want to amend the file to be a 1-1 mapping between your n64 controller's buttons, and the emulator's buttons. you can find the button numbers in /opt/retropie/configs/all/retroarch-joypads/yourcontrollername.cfg
                    • UnknownU
                      Unknown @dankcushions
                      @dankcushions said in Super Mario n64 problem:
                      I tried what you said here but now the start buttton does not work in N64, It does work in emulationstation though.
                        @Unknown could you please show us the contents of the two files i mentioned
                        • UnknownU
                          Unknown
                          @dankcushions Here is /media/pi/retropie/opt/retropie/configs/n64/InputAutoCfg.ini
                          ; InputAutoCfg.ini for Mupen64Plus SDL Input plugin
                          ; Keyboard_START
                          [Keyboard]
                          plugged = True
                          plugin = 2
                          mouse = False
                          DPad R = key(100)
                          DPad L = key(97)
                          DPad D = key(115)
                          DPad U = key(119)
                          Start = key(13)
                          Z Trig = key(122)
                          B Button = key(306)
                          A Button = key(304)
                          C Button R = key(108)
                          C Button L = key(106)
                          C Button D = key(107)
                          C Button U = key(105)
                          R Trig = key(99)
                          L Trig = key(120)
                          Mempak switch = key(44)
                          Rumblepak switch = key(46)
                          X Axis = key(276,275)
                          Y Axis = key(273,274)
                          ; Keyboard_END
                          ; USB Gamepad _START
                          [USB Gamepad ]
                          plugged = True
                          plugin = 2
                          mouse = False
                          AnalogDeadzone = 4096,4096
                          AnalogPeak = 32768,32768
                          Mempak switch =
                          Rumblepak switch =
                          R Trig = button(5)
                          B Button = button(3)
                          C Button U = button(0)
                          Start = button(9)
                          A Button = button(2)
                          C Button D = button(1)
                          X Axis = axis(0-, 0+)
                          Y Axis = axis(1-, 1+)
                          Z Trig = button(4)
                          ; USB Gamepad _END
                          ; DragonRise Inc.   Generic   USB  Joystick  _START
                          [DragonRise Inc.   Generic   USB  Joystick  ]
                          plugged = True
                          plugin = 2
                          mouse = False
                          Mempak switch =
                          Rumblepak switch =
                          L Trig = button(4)
                          C Button D = button(6) button(2)
                          DPad U = hat(0 Up)
                          DPad L = hat(0 Left)
                          C Button L = button(3)
                          Y Axis = axis(1-,1+)
                          X Axis = axis(0-,0+)
                          DPad R = hat(0 Right)
                          Z Trig = button(7)
                          C Button R = button(1)
                          R Trig = button(5)
                          DPad D = hat(0 Down)
                          Start = button(9)
                          A Button = button(8)
                          ; DragonRise Inc.   Generic   USB  Joystick  _END
                          I can't seem to open the folder" /media/pi/retropie/opt/retropie/configs/all/retroarch-joypads"
                            @Unknown said in Super Mario n64 problem:
                            • UnknownU
                              Unknown
                              @dankcushions I still can't open it with my sd card to usb adapter.
                                @Unknown we need more information to assist you. rather than saying you can't do something, show us a screenshot of what you're trying to do. although i would recommend using SFTP: https://github.com/retropie/retropie-setup/wiki/Transferring-Roms#sftp - i have no experience with sd card adapters - your OS might not be able to see this hidden folder without configuration.
                                • UnknownU
                                  Unknown
                                  @dankcushions I'm using raspbien to look at it, do I need ubuntu?
                                    @Unknown https://www.raspberrypi.org/forums/viewtopic.php?t=220100
                                    • UnknownU
                                      Unknown
                                      @dankcushions I know this is noob question, but how do you post a screen shot in retro pie fourm?
                                        mitu Global Moderator @Unknown
                                        @Unknown Copy/Paste the image on the text edit form, or just drag-and-drop it to the same area.
                                        • UnknownU
                                          Unknown
                                          @dankcushions I finally accessed though SSH, which file would you like me to open?
                                          By the way scrot is a command to take a screenshot.
                                            Which one if the controllers are you using in-game ? Post the config for that controller - open the .cfg file and post its contents.
