    Sega model 3 #segamodel3
    sega model 3supermodel
    304 Posts 23 Posters 113.7k Views
    • FollyF
      Folly @phialek
      @phialek
      In what directory, of the RetroPie-Setup, did you paste the supermodel-mechafatnick.sh module-script ?
      I think you have accidentally pasted it in the wrong supplementary directory, am I correct ?
      Before installation you have to paste it in :
      /home/pi/RetroPie-Setup/scriptmodules/emulators .
      For increasing speed you can try to select a low resolution for the emulator in the retropie-startup menu (in the same menu where you select the launch option).
      The resolution selected there should match the selected launch option.
      But you have to take it for granted, it will always be a bit slower than a good x86/x86-64 computer.
      M P 2 Replies Last reply Reply Quote 1
        mechafatnick @Folly
        @folly It shouldn't be that slow though :)
        I suggest keeping at the native res and stretching it. The super-duper long course causes stutters and slowdowns, but the rest should run reasonably nippily
          phialek @Folly
          @folly
          Yes i have plaved it under supplementary, because before i have installed yabasanshiro and i had to place the script under supplementary. I thought that was the normal way (im a nooby).
          What exactly do you mean with launch resolution? The resolution of the supermodel emulator? I had that at the lowest all the time. (396 pixel i think)
          Now I've changed the global resolution of retropie to 480. At least the game is now full screen but still slow as hell. Every daytona 2 game seconds lasts 5 real seconds. I don't think you have the same low performance.
          I have just tried scud racer. It doesn't start. The in game bios says no network and the game doesn't launch.
          Btw Daytona 2 steering is really great with an arcade sticks.
          FollyF M 2 Replies Last reply Reply Quote 0
          • FollyF
            Folly @phialek
            @phialek
            Indeed it works quite smooth on my end.
            I meant the "video mode" (aka "launch resolution").
            But it seems you already discovered that.
            For scud you have to go into the test-menu with key 6.
            With key 5 you can go to options and with key 6 you can select an option.
            Go to -> "game assignments" -> "link id" -> "single" (not master)
            Go to "exit" for exiting the test menu.
            Now scud will work in single mode.
            For speeding things up you should ask @mechafatnick, because he has more experience with that part, I think.
              mechafatnick @phialek
              @phialek can you post your run command log?
                phialek @mechafatnick
                @mechafatnick
                Parameters:
                Executing: xinit /dev/shm/retropie_xinitrc -- vt1 -keeptty
                X.Org X Server 1.20.4
                X Protocol Version 11, Revision 0
                Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
                Current Operating System: Linux retropie 5.10.52-v7l+ #1441 SMP Tue Aug 3 18:11:56 BST 2021 armv7l
                Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:37:FC:DD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=2aba0d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=3 consoleblank=0 plymouth.enable=0
                Build Date: 19 April 2021 03:23:36PM
                xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
                Current version of pixman: 0.36.0
                Before reporting problems, check http://wiki.x.org
                to make sure that you have the latest version.
                Markers: (--) probed, (**) from config file, (==) default setting,
                (++) from command line, (!!) notice, (II) informational,
                (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
                (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Mon Aug 9 20:39:38 2021
                (==) Using system config directory "/usr/share/X11/xorg.conf.d"
                modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/5.10.52-v7l+
                xrandr: Failed to get size of gamma for output default
                Set mode 1920x1080@60Hz on default
                Executing (via xinit): pushd /opt/retropie/emulators/supermodel-mechafatnick
                /dev/shm/retropie_xinitrc: line 5: ./supermodel: No such file or directory
                /opt/retropie/emulators/supermodel-mechafatnick ~
                Supermodel: A Sega Model 3 Arcade Emulator (Version 0.3a-WIP)
                Copyright 2011-2021 by Bart Trzynadlowski, Nik Henson, Ian Curtis,
                Harry Tuttle, and Spindizzi
                Title:          Daytona USA 2 - Battle on the Edge (Japan, Revision A)
                ROM Set:        daytona2
                Developer:      Sega
                Year:           1998
                Stepping:       2.1
                Extra Hardware: Digital Sound Board (Type DSB2), Drive Board, Net Board, Security Board
                xinit: connection to X server lost
                waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
                  phialek @phialek
                  Right now im reinstalling it. Maybe because of the wrong folder in the beginning something's got messed up.
                  Reinstalling from the right folder didnt help. Still slow like before.
                  • FollyF
                    Folly @phialek
                    @phialek
                    I think that your video-mode-resolution is much too high, as seen from the log.
                    You should try a video mode with a lower resolution.
                    Personally I think that should improve the speed.
                      phialek @Folly
                      @folly
                      As said before im using the lowest resolution from supermodel3
                      I've also tried to put the monitor into 480p mode via raspiconfig. Didn't help.
                      • 4
                        4RetroPieTFT
                        Deleted beacause other global moderator consider spamming the act of help!
                        • FollyF
                          Folly @phialek
                          @phialek
                          Your normal resolution is still on "Set mode 1920x1080@60Hz" on default.
                          You have to set something else here :
                            phialek @Folly
                            This post is deleted!
                            4 1 Reply Last reply Reply Quote 0
                            • 4
                              4RetroPieTFT @phialek
                              P FollyF 2 Replies Last reply Reply Quote 0
                                phialek @4RetroPieTFT
                                @4retropietft
                                Thank you
                                Ive tried every resolution there now. its slow like before. 800x600, 720x480, 640x480
                                They don't make a difference. It didn't speed up at all.
                                here is the log of 800x600 in video and launch mode, that was even slower than the 384 launch i had before
                                Parameters:
                                (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Mon Aug 9 21:48:40 2021
                                xrandr: cannot find mode 800x600
                                Set mode 800x600@60Hz on default
                                Executing (via xinit): SDL_VIDEO_KMSDRM_CRTCID=87 SDL_VIDEO_KMSDRM_MODEID=22 pushd /opt/retropie/emulators/supermodel-mechafatnick
                                ROM Set:        daytona2
                                Developer:      Sega
                                Year:           1998
                                Stepping:       2.1
                                FollyF 4 2 Replies Last reply Reply Quote 0
                                • FollyF
                                  Folly @phialek
                                  @phialek
                                  Well overall we made some progress here.
                                  Too bad the resolution changes didn't help to speed things up.
                                  It seems our PI's run it faster that yours.
                                  Perhaps we can find a solution later.
                                  Not sure what's the problem here.
                                  • FollyF
                                    Folly @4RetroPieTFT
                                    @4retropietft
                                    Do you have it running smooth just like me ?
                                      phialek @Folly
                                      @folly
                                      actually im happy to see you guys working so hard for all of us. thank you.
                                      • 4
                                        @phialek said in Sega model 3 #segamodel3:
                                        @4retropietft
                                        Thank you
                                        For supermodel in Pi 4 2gb, i dont touch that option still, some games run fast like lemans, sega rally 2, daytona, and some games like harley davidson are not playable yet. For stretch thd image you can add -fullscreen -wide-screen -wide-bg before %ROM% in emulators.cfg, you can edit. Just press Start, Quit, Quit emulationstation, the write with a keyboard:
                                        sudo nano /opt/retropie/configs/supermodel/emulators.cfg
                                        Changes one or the 3 options from this:
                                        Supermodel-mechafatnick-496x384 = "XINIT:pushd /opt/retropie/emulators/supermodel-mechafatnick;./supermodel -res=496,384 %ROM%"
                                        To this:
                                        Supermodel-mechafatnick-496x384 = "XINIT:pushd /opt/retropie/emulators/supermodel-mechafatnick;./supermodel -res=496,384 -fullscreen -wide-screen -wide-bg %ROM%"
                                        I just put one like example, you can see the other in the tutorial i comment a few comments above.
                                        Save the file with Ctrl+o (vowel o) then Enter and finally Ctrl+x to exit from nano editor.
                                        Then type reboot for reload with the new changes, or just type emulationstation for start the interface.
                                        Sorry for my English.
                                        P 4 FollyF 3 Replies Last reply Reply Quote 0
                                        • FollyF
                                          Folly @phialek
                                          @phialek
                                          I don't have these errors as you :
                                          Perhaps these errors can be an indication of the problem.
                                          Not sure though, I have to think about that.
                                            phialek @Folly
                                            @folly
                                            Thats what im thinking too. But i have no idea how to solve that.
                                            I think also this maybe a problem:
