    Sega model 3 #segamodel3
    sega model 3supermodel
    304 Posts 23 Posters 141.5k Views
      Joosho
      Ok, I see. Thanks for the tip. I'll try it this weekend and will tell you if it works.
        shift
        I'm reopening this post because I have a problem with the controller configuration. I installed the package: https://github.com/Mechafatnick/SuperModelPi/archive/refs/heads/master.zip but whatever I do with the Supermodel.ini, the configuration of the controller keys does not change, while if I modify the keys of the keyboard, yes. I used jstest to test my controller buttons but every change is in vain.
        I'm using Retropie 4.8.6 on a 4GB Raspberry Pi 5.
        roslofR 1 Reply Last reply Reply Quote 0
        • roslofR
          roslof @shift
          @shift said in Sega model 3 #segamodel3:
          There may be more than one ini.
          Be sure you're modifying the one that matches the symlink found at /opt/retropie/emulators/supermodel-mechafatnick/Config/Supermodel.ini <--symlink
          By default, it should map to this location:
          /home/pi/RetroPie/roms/supermodel/model3emu/mechafatnick/Supermodel.ini
          Any other .ini will be ignored.
            shift @roslof
            @roslof Thank you, I solved it, unfortunately I didn't realize that +1 must be added to the jstest, I had all the configurations wrong
