    Sega model 3 #segamodel3
    sega model 3supermodel
    304 Posts 23 Posters 113.5k Views
    • DTEAMD
      DTEAM @mechafatnick
      @mechafatnick said in Sega model 3 #segamodel3:
      Not sure there are any games that really need save states though)
      I'm on a handheld build and sometime I'm playing 5 minutes and I stop. It's interesting for me to be able to save games even if It's a short game to play.
      Also do:
      ln -s /opt/retropie/emulators/supermodel/bin/NVRAM NVRAM
      That way you'll keep any settings you change on the board (useful for only having to set Daytona/Scud race to single machines the once)
      Already done, I'm following your webpage and I saw that change. I did the same thing for Saves
      ln -s /opt/retropie/emulators/supermodel/bin/Saves Saves
      • Red_TrevR
        Red_Trev @DTEAM
        @dteam said in Sega model 3 #segamodel3:
        @red_trev
        You can do it like that too. With this method, you need to update both files. If you want use a symbolic link (press F4 or just close Emulation Station and write the proposed above command) with that, you only need to update opt/retropie/emulators/supermodel/bin/Config/supermodel.ini
        Both options work
        no change i am afraid, still displays in a small box in center of screen that is focused on bottom left ...
        i have changed all 3 Supermodel.ini files to the following & given rwx permissions to them:
        [ Global ] ; Input settings can only be read from the global section!
        XResolution=1024
        YResolution=768
        FullScreen=0
        WideScreen=1
        Stretch=1
        WideBackground=1
        is there any other setting i am missing ?
        • DTEAMD
          DTEAM @Red_Trev
          @red_trev
          Did you get the updated version from @mechafatnick
          Normally, It should work.
          Try this first:
          XResolution=1024
          YResolution=768
          FullScreen=0
          WideScreen=1
          Stretch=0
          WideBackground=0
          Have you deleted -res=496,384 in emulators.cfg ?
          Red_TrevR 1 Reply Last reply Reply Quote 0
          • Red_TrevR
            Red_Trev @DTEAM
            @red_trev
            Try this first:
            XResolution=1024
            YResolution=768
            FullScreen=0
            WideScreen=1
            Stretch=0
            WideBackground=0
            yes I have deleted in emulators.cfg
            sorry, didnt know there was a new version of supermodel, i will install ....
            so i must modify the Supermodel.ini file that is in the new supermodel\bin\Config (pic below) and add those values ?
            • DTEAMD
              DTEAM @Red_Trev
              @red_trev
              Yes, under [Global]
              You should use Notepad ++ (it's free) instead of notepad.
              Better for program files
              • Red_TrevR
                Red_Trev @DTEAM
                @dteam when i try running a game it fails, looking at the error log says :
                opt/retropie/emulators/supermodel/bin/supermodel:
                error while loading shared libraries libsdl2-2.0.so.0:
                cannot open shared object for file:
                no such file or directory
                when i try to sudo apt install libsdl2-dev it says the latest version is already installed
                @mechafatnick can you please confirm the zip available for download off your original webpage is the correct emulator version to install ?
                it has only one folder called bin , here is the contents
                here is whats inside Config
                the only changes to Supermodel.ini was the first few lines, it has full rwx permissions & i uploaded the same file to the home/pi/Config folder
                  mechafatnick @Red_Trev
                  @red_trev
                  Yeah that's all correct. If you set up the symbolic links those are the only files you need. I think you need this one too:
                  sudo apt-get install libsdl2-net-dev
                  Also the emulator is setup with mappable save states/quit/screenshot controls so make sure they're mapped how you want them!
                  Red_TrevR 1 Reply Last reply Reply Quote 1
                  • DTEAMD
                    DTEAM
                    @dteam there's a hard-wired save state selection key that may need to be rebound. Try using it and then see if it will load (would be an easy update if it solves the issue. Not sure there are any games that really need save states though)
                    I've set those lines but I'm not able to load savestates:
                    ;my personnal setup
                    InputUISaveState = JOY1_BUTTON1+JOY1_BUTTON13
                    InputUILoadState = JOY1_BUTTON1+JOY1_BUTTON11
                    InputUIChangeSlot = JOY1_BUTTON1+JOY1_BUTTON12
                    InputUIDumpInputState = JOY1_BUTTON1+JOY1_BUTTON5
                    When you talk about "hard-wired save state selection key" , is it one of those InputUI option
                    NEW EDIT:
                    in Supermodel.log we can see InitStateFile= <-----(NOTHING, maybe missing value)
                    See below
                    [Info]  Supermodel Version 0.3a-WIP
                    [Info]  Started as:
                    [Info]    argv[0] = ./supermodel
                    [Info]    argv[1] = -config-inputs
                    [Info]  Runtime configuration:
                    [Info]    GameXMLFile=Config/Games.xml
                    [Info]    InitStateFile=
                    [Info]    MultiThreaded=1
                    [Info]    GPUMultiThreaded=1
                    [Info]    PowerPCFrequency=50
                    [Info]    MultiTexture=0
                    [Info]    VertexShader=
                    [Info]    FragmentShader=
                    [Info]    VertexShaderFog=
                    @folly @mechafatnick Could it be the loadstate problem?
                    • Red_TrevR
                      Red_Trev @mechafatnick
                      @red_trev
                      that update did the trick, now I can play in full screen
                      thanks for all your help :)
                        mechafatnick @DTEAM
                        @dteam no - init save state loads a save state on load.
                        Turns out i'd mucked up when i was setting the load state to be remappable. It works now.
                        I haven't updated the zips yet, but i'vejust pushed out the small source code change. I also made the cross hair toggle remappable to so you can see what you're shooting in The Lost World.
                        DTEAMD 1 Reply Last reply Reply Quote 2
                        • DTEAMD
                          DTEAM @mechafatnick
                          Thank you, the puzzle is over !!! Thanks also for optimizing the games, it's really appreciated.
                          The next step for you, is it a conversion to libretro cores: lr-supermodel 😉
                          When you make any updates or if you update your zip, could you let us know in this thread. I want to be aware of your changes and I can test it for you if you want. Thanks again.
                          • FollyF
                            Folly
                            @mechafatnick @DTEAM
                            Does it now mean that save-states and load-states is now possible/working ?
                              mechafatnick @Folly
                              @folly yep! Save and load work. As does the shortcut for showing lightgun cross hairs on screen.
                              • FollyF
                                Folly @mechafatnick
                                @mechafatnick
                                Yesterday I made a module-script for the supermodel :
                                https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-scriptmodules-00/emulators/supermodel-mechafatnick.sh
                                Not yet perfect, but I think it's a nice base.
                                Perhaps it's something you could improve with your knowledge.
                                • DTEAMD
                                  DTEAM @Folly
                                  @folly
                                  It's nice, because we don't need the zipped file anymore. Your script make the file with MakeFile !!
                                  • FollyF
                                    Folly @DTEAM
                                    @dteam
                                    Indeed it does.
                                    I structured it a bit differently.
                                    So the emulator binary, configs, Saves map and NVRAM map don't mix up with other installs (if not using the same names btw.)
                                    I did not add extra settings Supermodel.ini in the script and I only implemented one emulators.cfg line.
                                    • DTEAMD
                                      DTEAM @Folly
                                      @folly
                                      Is It better to uninstall my old files before using your script or that's okay.
                                      FollyF Red_TrevR 2 Replies Last reply Reply Quote 0
                                      • FollyF
                                        Folly @DTEAM
                                        @folly
                                        This is the reason I created it in such a way that it should be a complete install on it's own and you should be able to keep using your old install for comparison.
                                        This will make it easier to compare and improve or copy and paste configs or files.
                                        So only for this module-script the emulator files come in :
                                        /opt/retropie/emulators/supermodel-mechafatnick
                                        It will create symlinks in above directory of NVRAM, Saves, Supermodel.ini and Supermodel.log.
                                        These real directories and files, with normal user permissions, come in :
                                        /home/pi/RetroPie/roms/supermodel/model3emu/mechafatnick
                                        These directories are shared with other installs :
                                        /opt/retropie/configs/supermodel
                                        So it uses the same emulators.cfg file for adding the lines.
                                        (but I gave the lines a specific name btw.)
                                        • Red_TrevR
                                          Red_Trev @DTEAM
                                          @dteam is there for global input to toggle Crosshairs (for light gun games) that i can put in supermodel.ini ? the keyboard command for it is Alt-I
                                            mechafatnick
                                            @folly oh wow good job! I've never actually messed around with Retropue modules so thanks for creating that. We have the make files for Windows and Mac in there too. Would it be difficult to make them compatible with those platforms? I've never seen Retropie installed in Windows.
                                            I would say it's worth including the variants with under locked PPC settings. So far 40hz, 48hz and 45hz seem to get the best results in certain games.
