    Retroarch Retroflag GPi Case Fullscreen for GBA Roms
    retropie retrof
    7 Posts 3 Posters 437 Views
    • insaneplI
      insanepl
      Hi!
      Anyone can help me to set up GBA games in fullscreen? Actually they are stretched in horizontal but I want real fullscreen with vertical too. 3 days I am testing various options and no effect.
        Please add more info about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        What is the screen resolution of your display ?
        • insaneplI
          insanepl
          The system I am running is RetroPie installed from image Magnus Supreme GPI which I downloaded from some site.
          I don't know is that the info You need but in options I have :
          Version 4.5.1 running on Raspbian 9.4
          The resolution is 320x240
          • markyh444M
            markyh444 @insanepl
            @insanepl 3rd party images aren't supported here. Only the official image from the Retropie site
            Retropie in a PSX - Pi3
            • insaneplI
              insanepl
              ok, now I installed latest Retropie for RPi 0 W, what's next step?
              • markyh444M
                markyh444 @insanepl
                @insanepl have you read the documentation? There's detailed steps in there for first setup.
                • insaneplI
                  insanepl
                  Yes, I've enabled wifi and ssh, copied bios files and one GBA rom to test. When I open the rom with gasp its not work, but with mgba is ok but slowdown.
