    No wlan0 interface detected
    no wlan0 interfretropie 4.6busterpi 3
    23 Posts 6 Posters 8.3k Views
      Reignman
      Hi All, I have been using Retropie for over 2 years now and I'm having a problem that keeps returning. I have spent houres and houres trying to fix this but limited en no permanent results. I was hoping someone can help me through this.
      I have a Raspberry Pi Model 3. (All info is below)
      I used to have Jessie installed and my wifi connection would suddenly fail. I would get the massage : No wlan0 interface detected. After trying numerous fixes on the net I would get it to work again but now it's down constantly after I upgrade to Retropie 4.6 (buster)
      Tried a fresh install with a new sd card but still I get the same error. You would think It's a hardware issue but when I got this error earlier I got to fix it with a code through the console :
      sudo wpa_supplicant -Dwext -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
      sudo systemctl enable wpa_supplicant.service
      But this doens't work anymore.
      If I try to connect to the wifi in the config menu I get : No wlan0 interface detected.
      I tried setting the country but then again I get the same message.
      I am currently on the latest release (buster) with Retropie 4.6.
      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..) : Raspberry Pi 3
      Power Supply used: gooboy Model no. 71889 output : 5V - 2.5A
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.6
      Built From: (Pre made SD Image on RetroPie website : retropie-buster-4.6-rpi2_rpi3.img
      USB Devices connected: USB keyboard, USB drive (ROMS and art)
      Controller used: 2x zero delay usb joystick
      Error messages received: No wlan0 interface detected
      Verbose log (if relevant): ?
      How to replicate the problem: Trying to connect to a wifi network
      I can't paste any logs cause my Pi will not connect to my network anymore so. If someone can explain how to, that would be nice.
        Did you set your the Country first ? I think it's required since Raspbian Stretch in order to use the Wi Fi.
          Reignman
          If I try to set Country I get : No wireless interface found 🤔
          • markyh444M
            markyh444 @Reignman
            @Reignman sounds like a hardware issue. Do you get the same behaviour off a standard Raspbian install?
            Retropie in a PSX - Pi3
              Reignman @markyh444
              @markyh444 Yes also of a fresh install. So that's what I'm afraid for that's it's hardware related. Although I don't understand why this was in the past also but back then I got it working again temporary ...
                Can you run dmesg, taken after a cold boot, and post it on pastebin.com ?
                  Reignman @mitu
                  @mitu Yes but how do I save and export this info without network on my pi?
                    mitu Global Moderator @Reignman
                    @Reignman Save it on the boot partition.
                    dmesg | sudo tee  /boot/dmesg.txt
                    Then take the sdcard out of the Pi and read the file from your PC.
                    R 3 Replies Last reply Reply Quote 0
                      Reignman @mitu
                      @mitu thank you, I'm gonna try this tomorrow morning. I'm not home now.
                      Posting log asap. 😁👌
                      • U
                        undrwater
                        I'm running into the same issue. Here's a dmesg from fresh boot.
                        dmesg
                          BuZz administrators @undrwater
                          @undrwater Please don't hijack a topic - start a new topic. You're running a Raspberry Pi2 - which doesn't have built in wifi btw. So you need a dongle.
                          • U
                            undrwater @BuZz
                            @BuZz
                            Wow. Talk about assumptions. I would have sworn I was using the Pi 3. Thanks for the heads up!
                              Reignman @mitu
                              This post is deleted!
                                Reignman @mitu
                                @mitu Here is my dmesg
                                Dmesg
                                  Doesn't seem to be anything Wi-Fi related (Bluetooth included). Maybe they're blocked ? Can you run
                                  sudo rfkill list all
                                  and post the output ? Does it detect any Wifi interfaces ?
                                  Did you disable the Wifi/Bt via config.txt on your Pi ?
                                    Reignman @mitu
                                    @mitu I get no output from chat command. Havent changed anything in config.txt
                                    With iwconfig I get :
                                    lo no wireless extensions.
                                    Enxb827ebb5a2ad no wireless extensions.
                                      Aztechomie64 @undrwater
                                      @undrwater Something is going on i need some type of help anyone.
                                      I di all the steps to install retropie and then i downloaded all roms to usb plugged it in the raspberry pi 3 and when i go to restart emulation it tells me that “if this is the first time rebooting then i got something wrong?
                                      I deleted all and re installed all same steps same outcome.
                                      Right now at this moment i tried to change some audio it let me but as it went back to the main screen it froze ?
                                      Any answers thank y
                                      mituM 1 Reply Last reply Reply Quote -1
                                        mitu Global Moderator @Aztechomie64
                                        @Aztechomie64 Please open a separate topic and add the info asked in https://retropie.org.uk/forum/topic/3/read-this-first.
                                          Reignman
                                          @mitu Any ideas what I could do? Could it ba a hardware failure?
                                            It's most likely a hardware failure.
                                            Just to be sure there's nothing disabled, post your config.txt.
