    Failed to load state from"/home/pi/RetroPie/roms/snes/Megaman X (USA).state".
    22 Posts 3 Posters 10.3k Views
      mattw24
      First, I want to note that I know virtually nothing about any of this and started all of this yesterday.
      when i try to create a save state in Megaman X nothing happens and when I try to load one that error pops up in the bottom left
      Raspberry pi 3 B
      RetroPie is v3.8.1
      sd image
        meleu @mattw24
        @mattw24 said in Failed to load state from"/home/pi/RetroPe/roms/snes/Megaman X (USA).state".:
        When you save the state do you have some message in the bottom left?
          mattw24
          Im not sure what hotkeys to press to create a save state because everything i read online says something different (im using a XBox 360 wired controller btw)
            mattw24 @meleu
            @meleu sorry I forgot to mention you
            • Z
              zupi
              https://github.com/retropie/retropie-setup/wiki/retroarch-configuration
              Select and right shoulder should be save and select and left shoulder should be load. ;)
              For some reason I seem unable to load states saved from older version in 4.0.2 beta script update. :/
                mattw24
                @zupi said in Failed to load state from"/home/pi/RetroPe/roms/snes/Megaman X (USA).state".:
                so when i try to save with by pressing select and the right shoulder it comes up the same error as when i do the same thing with the left shoulder- the error in the title
                @zupi
                  meleu @mattw24
                  @mattw24 well... A way to the solution involves checking the file/directory permissions... Are you comfortable with linux commands?
                    mattw24 @meleu
                    @meleu i wish
                    • Z
                      zupi
                      That may be a long shot but there is an option on the new Retropie setup menu that resets rom folder permissions... Fingers crossed of course...
                        mattw24 @zupi
                        @zupi ya I saw that somewhere else but it didn't work
                        • Z
                          zupi
                          Damn, sorry, I am not that geek either...
                            mattw24
                            damn all these views and no solution
                              meleu @mattw24
                              @mattw24
                              The topic title says ".../pi/RetroPe/...". Is this a mistyping? It should be "/home/pi/RetroPie/..."
                              Can you access your RetroPie via SSH and paste here the output of this command:
                              ls -ld /home/pi/RetroPie/roms/snes
                                mattw24 @meleu
                                @meleu yes it is sorry and like I said I'm very new to this so what is ssh?
                                  mattw24
                                  drwxr-xr-x 2 pi pi 4096 Jul 22 12:24 /home/pi/RetroPie/roms/nes
                                  if I did that right
                                    meleu @mattw24
                                    @mattw24 Yeah man! I'm glad to see a person who didn't know SSH accomplished this task! No joking! I'm talking seriously! :D
                                    You said you wish to get comfortable with linux commands before. Well... Let me try to explain what I is my strategy to solve your problem, maybe you can learn something with this info.
                                    1. Your title says "Failed to load state from...". If it failed to load, maybe the state aren't even saved.
                                    2. You said that nothing happens when you try to save the state. Well, if there is no state saved, obviously it'll fail when you try to load. So your problem isn't the load failure, it's the save failure.
                                    3. What do you mean with "when i try to create a save state in Megaman X nothing happens". Is "nothing" really nothing? Not even a "failed to save" message in the bottom left?
                                    4. If "nothing" is really nothing, maybe your hotkey to savestate isn't properly configured. Usually the hotkey for this task is Select+R1.
                                    5. If you get a "failed to save" message, the problem can be file/directory permissions. When I asked you to paste here the output of that ls command, I wanted to see if the user pi has permission to create files on the ".../roms/snes/" directory. By the way: you pasted the output for the nes directory, not the snes.
                                    Can you ask the question in 3, so we can decide if we go to 4 or 5?
                                      mattw24 @meleu
                                      @meleu when I press select and r1 it gives me the error in the title
                                        meleu @mattw24
                                        @mattw24 said in Failed to load state from"/home/pi/RetroPie/roms/snes/Megaman X (USA).state".:
                                        Then Select+R1 is configured to load. You must discover what is the hotkey to save.
                                        What about Select+L1?
                                          mattw24 @meleu
                                          @meleu when I press select and l1 no text comes up
                                            meleu @mattw24
                                            @mattw24 OK, let's continue our investigation...
                                            Please, paste here the output of this command:
                                            grep -R save_state_btn /opt/retropie/configs/all 2> /dev/null
