    Raspberry PI4 Low FPS (4.6, 260ms) in emulationstation menu
    fpsraspberry pi 4performance
    8 Posts 3 Posters 2.3k Views
    • W
      warchant
      Hi. I installed latest retropie (4.6.4) on Raspberry PI 4, running Raspbian buster.
      $ uname -a
      Linux pi.wlan 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
      I run emulationstation in terminal, it opens and shows 4.6 FPS with 200-250ms latency. Same FPS preserved in games (I tried Mario in GBA). This is unplayable.
      My /boot/config.txt:
      dtparam=audio=on
      [pi4]
      # Enable DRM VC4 V3D driver on top of the dispmanx display stack
      dtoverlay=vc4-fkms-v3d
      max_framebuffers=2
      [all]
      gpu_mem=256
      hdmi_enable_4kp60=0
      hdmi_group=1
      hdmi_mode=16
      What can I do to run at least 30 FPS, or preferably, 60 FPS?
        Are you running EmulationStation from a desktop session ? What's your current resolution - post the output of tvservice -s .
        • W
          warchant
          Yes, I start lightdm (non-root user), then start emulationstation, also as non-root user.
          $ tvservice -s
          state 0xa [HDMI CUSTOM RGB lim 16:9], 3840x2160 @ 30.00Hz, progressive
            This is not a supported or tested configuration - start EmulationStation from a console session at boot - https://retropie.org.uk/docs/FAQ/#where-did-the-desktop-go.
            EmulationStation - and the included emulators - will suffer from the 4k resolution that you've set, you should choose 1080p as your default resolution. You seem to have added the configuration options to config.txt, but the desktop session will not take those into account and start with the TV's 'preferred' resolution - in your case it's 4k@30p, which adds the stuttering and slowdown you're noticing.
            • W
              warchant
              Stopped lightdm, started xinit emulationstation and got stable 60 FPS, with 1080p.
              Thank you!
                mitu Global Moderator @warchant
                @warchant said in Raspberry PI4 Low FPS (4.6, 260ms) in emulationstation menu:
                Still not a supported configuration.
                • W
                  warchant
                  Where can I see a list of supported configurations?
                    BuZz administrators @warchant
                    @warchant RetroPie on the RPI is designed to run from the console. Not under X. Don't use xinit.
