    (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b)
    mariomario 64nintendo 64sm64sm64pc
    150 Posts 23 Posters 67.7k Views
      A Former User
      This guide will show you how to add a improved and open-source version of Super Mario 64, called Super Mario 64 PC, and launch it from emulation station.
      Super Mario 64 PC is only for the Pi 4 and 3B+
      NOTE: Super Mario 64 PC requires OpenGL, which runs out of the box on pi4, but needs configuration on other rpi models.
      There are two ways to install Super Mario 64 PC:
      1: Manual installation(You will download and build the game) - for Pi 3B+ and 4
      2: Scriptmodule by @zerojay - ONLY FOR PI 4
      Manual Installation:
      Step 1: Run this command
      sudo apt install build-essential git python3 libaudiofile-dev libglew-dev libglfw3-dev libusb-1.0.0  libsdl2-dev
      Step 2: Git clone into the files
      git clone https://github.com/sm64pc/sm64pc
      Step 3: Take your .z64 file of Super Mario 64 and put it in the files
      cp <ROM_LOCATION>/<YOUR_ROM>.z64 sm64pc/baserom.<ROM_REGION>.z64
      Step 4: Build
      cd sm64pc
      make VERSION=<ROM_REGION> TARGET_RPI=1 -j4
      Step 5: Create .sh file
      Create a .sh file, name it sm64pc.sh, and put the following code in it:
      #!/bin/bash
      /home/pi/sm64pc/build/<ROM_REGION>_pc/sm64.us.f3dex2e.arm %U
      Move the .sh file into /home/pi/RetroPie/roms/ports
      Step 6: Have fun :)
      Scriptmodule:
      Step 1: Go to ~/RetroPie-Setup/scriptmodules/ports
      Step 2: Enter the following in your terminal(F4)
      git clone https://github.com/zerojay/RetroPie-Extra/blob/master/scriptmodules/ports/sm64ex.sh
      Step 3: Go to the RetroPie Setup menu and in the packages you will find sm64ex
      Step 4: Download sm64ex and have fun :)
      Feedback is very appreciated
      Note: sm64pc automatically configures controllers, so you don't need to go into config files
      To add mods, @pjft came up with this solution:
      Run first 4 steps, replacing step 2 with:
      git clone --single-branch --branch nightly https://github.com/sm64pc/sm64ex.git
      Then after step 4 run:
      rm -rf build
      Copy the content of the patch to the folder.
      Then run:
      make VERSION=<ROM_REGION> TARGET_RPI=1 -j4 EXTERNAL_DATA=1
      where <ROM_REGION> is the region of your ROM, as in the first time you compiled it.
      Replace the code inside sm64pc.sh with:
      #!/bin/bash
      /home/pi/sm64ex/build/<ROM=REGION>_pc/sm64.us.f3dex2e.arm %U
      MODS ARE ONLY FOR MANUAL INSTALLATION
      Thanks to @pjft for the solution for mods.
      Thanks to @zerojay for a scriptmodule.
      S 1 Reply Last reply Reply Quote 5
        A Former User
        Edit: In step 3, instead of downloads, type path to rom(eg. RetroPie/roms/n64/Mario.z64
        • KrakatoaK
          Krakatoa
          @Luddo183 said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
          Super Mario 64 PC
          Awesome, does it support the texture packs?
            A Former User @Krakatoa
            @Krakatoa
            It does, you can follow the instructions from any website
            • Stuart2773S
              Stuart2773
              im stuck / confused with steps 3 onwards any help please?
                A Former User @Stuart2773
                @Stuart2773
                What's the problem?
                • Stuart2773S
                  Stuart2773
                  im getting this error
                  Makefile:148: *** unknown version
                    @Stuart2773
                    What are you putting in the terminal for step 3?
                    • Stuart2773S
                      Stuart2773
                      cp RetroPie/roms/n64/Mario.z64 sm64pc/baserom.Mario.z64
                        @Stuart2773
                        First of all, make sure you have a Mario.z64 in there.
                        Second, instead of baserom.Mario, you need to put the region(eg. us, eu)
                        • retropieuser555R
                          retropieuser555
                          Yeah the baserom needs to be called baserom.us.z64 (or eu or jp). I'm just building it now
                          Pi 5 4GB
                          • Stuart2773S
                            Stuart2773
                            my mario.z64 is in my n64 roms dir
                            the original rom file was called Super Mario 64 (U) [!].z64
                            but i changed it to Mario.z64
                              A Former User @retropieuser555
                              @retropieuser555
                              Also when running make VERSION=us TARGET_RPI=1 -j4, replace us with the region of the rom
                                @Stuart2773
                                It is the us file
                                • Stuart2773S
                                  Stuart2773
                                  yes
                                  • Stuart2773S
                                    Stuart2773
                                    step 3 is really confusing me, not sure what needs to be typed
                                      @Stuart2773
                                      For you, type
                                      cp RetroPie/roms/n64/Mario.z64 sm64pc/baserom.us.z64
                                      And for step 4:
                                      cd sm64pc
                                      And for the sm64pc.sh file:
                                      #!/bin/bash
                                      /home/pi/sm64pc/build/us_pc/sm64.us.f3dex2e.arm %U
                                      • Stuart2773S
                                        Stuart2773
                                        @Luddo183
                                        cheers thank you so much ive now got it working,
                                        now to add some texture packs !!!!
                                          @Stuart2773
                                          You can get them on the official website
                                          Stuart2773S 1 Reply Last reply Reply Quote 0
                                          • Stuart2773S
                                            Stuart2773 @A Former User
                                            @Stuart2773
                                            can you provide the link?
