    (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b)
    mariomario 64nintendo 64sm64sm64pc
    150 Posts 23 Posters 73.0k Views
      AdamBeGood @Stuart2773
      @Stuart2773 Did you build it on the version of sm64ex that doesn't have the speed issue? It was mentioned above.
      Pause Menu works fine on Xbox one controllers - pause and then right shoulder, can't vouch for 360 though.
      Stuart2773S 1 Reply Last reply Reply Quote 0
      • Stuart2773S
        Stuart2773 @AdamBeGood
        @AdamBeGood said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
        do you mean this:- git checkout 685efc81c ?
        i will give it a try thanks
          @Stuart2773 Yeah, that's the one! Good luck.
          • I
            iliveinapancake
            really strange issue.. i have 2 Rpi4s with sm64pc installed on both. On one pi its got twister os installed, and when I run the game either in or out of retropie everything works perfect. On my other pi4 it has just the retropie image on the sd card, the controls are totally messed up. Mario always crouching, r button doesn't work, it's all kinds of messed up. Manually configuring doesn't help, shift button on the keyboard won't go into the options menu unless i unplug my controller. it thinks buttons are pressed that aren't. And ive tried sm64pc and both branches of sm64ex, also tried roll back the nightly branch . It doesn't make any sense..?
            ? 2 Replies Last reply Reply Quote 0
              A Former User @iliveinapancake
              @iliveinapancake
              That because sm64pc needs opengl, which retropie does not support.
                @iliveinapancake
                Follow the manual installation here Manual Installation and start from the desktop, not lite
                • I
                  iliveinapancake @A Former User
                  @Luddo183 that explains it, thank you!
                    Theon
                    @iliveinapancake @Luddo183 How does that make any sense...?
                    Why would this guide be about how to compile sm64pc for retropie, if retropie doesn't support it?
                    Am I misunderstanding something here?
                    I'm stuck on the same step. FATAL ERROR: Vertex shader compilation failed
                    I tried both sm64pc and sm64ex multiple times, following pretty much all the alternative suggestions in this thread, but I still just get that error.
                    Any help greatly appreciated!
                    (I'm on a 3B+, by the way)
                      A Former User @Theon
                      @Theon
                      RetroPie does not out of the box have opengl support.
                      • V
                        VictimRLSH
                        The method on Pi Lab's Youtube video worked fine for me.
                        System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
                          mitu Global Moderator @A Former User
                          @Luddo183 said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
                          The Pi4 model has it out-of-the-box, other models need additional configuration (though that particular configuration will likely not be compatible with RetroPie).
                            A Former User @mitu
                            Can there be a way to automatically have opengl in RetroPie
                            • Z
                              zerojay
                              Hi, I wanted to check this out so I created a RetroPie-Setup script for installing it and put in my RetroPie-Extra repository, meant specifically for Pi 4 ONLY: https://github.com/zerojay/RetroPie-Extra/blob/master/scriptmodules/ports/sm64ex.sh
                              Copy your Mario 64 ROM to /home/pi/baserom.<VERSION>.z64 before attempting to install. Everything else is fully automated and a port is added to the Ports menu in RetroPie. This will install the standard version of sm64ex. If there's demand, I may write up a script to automatically compile with external data as well.
                              I would love to support the other Pi boards with this, but the sheer amount of changes that need to be made feel far outside the scope of a script like this, so Pi 4 only it is.
                              roslofR ? B 3 Replies Last reply Reply Quote 4
                              • roslofR
                                roslof @zerojay
                                @zerojay said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
                                Works perfectly, @zerojay Thank you for this.
                                • I
                                  ipnetsensei
                                  hey @Luddo183 , first nice instructions , but I'm having an issue at the last step after I add the .sh file to /home/pi/RetroPie/roms/ports . ports does not show up in the menu. Am I missing something ?
                                  • I
                                    ipnetsensei @ipnetsensei
                                    @ipnetsensei
                                    I resolved it :
                                    just pasted the system menu option manually and it worked.
                                    add to menu : sudo nano /etc/emulationstation/es_systems.cfg
                                    <system>
                                    <name>ports</name>
                                    <fullname>Ports</fullname>
                                    <path>/home/pi/RetroPie/roms/ports</path>
                                    <extension>.sh .SH</extension>
                                    <command>%ROM%</command>
                                    <platform>pc</platform>
                                    </system>
                                      RetroFloppy08
                                      I did everything you said, it runs, but its just a black screen.
                                      Please Help?
                                      I'm Using a Raspberry Pi 3B 1.2 with 32GB of storage
                                      • Z
                                        zerojay @RetroFloppy08
                                        @RetroFloppy08 said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
                                        Please Help?
                                        As I said previously: "I would love to support the other Pi boards with this, but the sheer amount of changes that need to be made feel far outside the scope of a script like this, so Pi 4 only it is."
                                        • DolphinCubeD
                                          DolphinCube
                                          is there any way you can take this. And use it to compile a 3ds version? Idk the raspberry pi is the only linux computer I have https://github.com/mkst/sm64-port
                                          • retropieuser555R
                                            retropieuser555 @DolphinCube
                                            This post is deleted!
