    8BitDo SN30 Pro Wired Trigger Assignment
    8bitdo8bitdo sn30 procontroller
    3 Posts 2 Posters 2.5k Views
    • simpleethatS
      simpleethat
      Pi Model or other hardware: 4B 4GB
      Power Supply used: USB-C 5v/3a that came with my villros kit
      RetroPie Version Used: 4.6.4
      Built From: retropie-buster-4.6-rpi4.img ALSO (different SD card) manual install over raspberry pi OS lite 2020-05-27-raspios-buster-lite-armhf.img
      USB Devices connected: AmazonBasics USB Keyboard, 8BitDo SN30 Pro
      Controller used: 8BitDo SN30 Pro
      Working on a new build for my RaspberryPi 4 and I'm having trouble assigning the L2/R2 triggers on my new 8BitDo SN30 Pro through the EmulationStation Controller config. When I press either trigger there is no response. I have updated the firmware of the controller to v1.03.
      I ran jstest and it does register the buttons as axis 2 and axis 5. Both start at -32767 (no input) and change to 32767 when the trigger is pressed.
      When I initially configured the controller it did register it as an Xbox 360 controller.
      EDIT1: I did try to run the controller configuration again (as someone in a different post said this worked for them) and twice after performing the firmware update on the controller.
      EDIT2: the Star button (below the dpad) doesn't respond in jstest. Is there anyway to get this button to work? I would prefer to use it for the hotkey.
      Also, when I tried to run jstest on my manual install it didn't work. Does it not get installed when doing a manual install? I tried looking for it in the menus of the setup script and couldn 't find it (although it is possible I missed it).
        The trigger buttons registering as axis should be solved by installing the xpad driver from RetroPie's drivers section.
        For the 2nd part issue - menu button - this looks like a firmware configuration, you may have to change the pairing mode to 'Nintendo Switch' for the button (Start) to become active.
        • simpleethatS
          simpleethat
          @mitu thanks for the reply! I don't think there's any way to change the pairing setting on the wired controller. The manual is pretty sparse. The button below the B button is actually the Home button and I have it set to the hotkey currently it's just awkward to use with some of the combinations.
          I'll have to give the xpad a whirl. I think I managed a work to make it work by manually editing the appropriate .cfg in the retroarch-joypads folder (the same way I set the toggle fast forward to work across all of the retroarch emulators). But I haven't yet added any games to see if it works. I'll report back with my findings.
          I added these two lines:
          input_l2_axis = "+2"
          input_r2_axis = "+5"
          adding this line:
          input_toggle_fast_forward_axis = "+5"
          works to toggle fast forward so I think it will work to make the triggers function. I've got to track down a PS1 game that uses L2/R2 to see if my solution worked. I'll try the driver on another build as it's always good to have multiple working solutions.
