    Are you having problems running Roms from SSD Pi4???? + Question
    install retropiraspberry pi 4roms wont workssd
    3 Posts 3 Posters 885 Views
    • W
      wiuenright
      IF you cannot get roms to work off SSD/USB read this.
      First of all let me say thank you to all the participants on here, the knowledge is so very helpful. I just received the stuff for my first Pi build today and have been at it for about 10 hours off and on (It has been a nightmare). I wanted to share my experience so that hopefully it helps someone else that runs into this issue.
      Raspberry Pi 4
      RetroPie on Samsung Evo plus 32GB MicroSSD
      Flicr Case
      Samsung 830 256GB SSD
      Orico 2.5 USB 3 External HD Enclosure https://www.amazon.com/gp/product/B01LY97QE8/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
      I loaded Retropie on the SD card just fine. I want to run ROMS off the SSD, I am completely new to Pi and didn't want to get to complicated with booting off of it just yet. This is where my issue started. I followed the videos on youtube instructing you to formatting he SSD to Fat32, enable the USB Rom service on RetroPi and then plug in your SSD. I have tried restarting the whole process over and over, reimaging RetroPi and everything else under the sun. Only once or twice did I get the folders to copy from the SD card to the SSD, and even after that loading roms would not work. I would get a variety of problems and never see any of the Roms.
      After formatting the SSD and plugging it into the Pi, the SSD would blink as if it were writing for a very long time. It would stop after about 10 minutes sometimes. Other times it would start again. I was beyond frustrated and was ready to give up. After starting all over yet again, I accidentally plugged the SSD into one of the USB 2.0 ports and it only was writing for 10 seconds. I plugged it in the PC and it had the folders. I put roms on and put it back in the Pi and it is working FINALLY.
      Whenever I plug into the USB 3.0 it just writes non stop. I don't know what the problem is. Could it be the enclosure??? Is the lack of USB speed going to make a noticeable difference in gaming? Any ideas why this could be happening?
      Hopefully this helps someone out there.
        @wiuenright said in Are you having problems running Roms from SSD Pi4???? + Question:
        Try looking at the system's messages when you plug in the drive, by running dmesg -w (CTRL+C to interrupt) on the console and see if any errors are displayed.
        Make sure you've updated your system (sudo apt update && sudo full-upgrade) to get the latest stable USB firmware and kernel/firmware release.
        There's a sticky topic in the RPI forums here for troubleshooting problematic USB3 SSDs, you might want to take a look and see if your enclosure's USB SSD adapter could be one of the models reported with issues.
          A Former User @mitu
          This post is deleted!
