    PiGRRL 2 buttons help
    pigrrl 2button problemretro pie
    5 Posts 3 Posters 437 Views
      r33_bnd
      I am building a PiGRRL 2 and none of my buttons from the buttons game pad are working. I have tried in ssh the "ps -ef | grep retrogame" and "/etc/udev/rules.d/10-retrogames.rules" and it keeps coming back with nothing. The latter says no such file or directory. I have also tried to reinstalling the keypress support and that didn't work either. Any thoughts? Thanks in advance.
      • IanDaemonI
        IanDaemon
        This post is deleted!
          @r33_bnd said in PiGRRL 2 buttons help:
          What instructions are you following for installation ?
            r33_bnd
            From the Adafruit website.
            https://learn.adafruit.com/pigrrl-2/software
              The installer looks pretty simple - did it create the retrogame.cfg file in /boot ? Are you running the installer as root (via sudo), as indicated in the instructions ?
