Streets of rage remake install help
@dishins Thanks, I must have not seen the Exit on the main menu of sorr. I will boot it up later and check.
@greenhawk84 said in Streets of rage remake install help:
@Charco thank you for the info. Do you use ver. 5.1?
Thanks for the trick, but if we do it, we can only play alone, the Two Player is removed from the menu :( :( :(
I have a Hacked Save of this game, from a long years lol ... i try it on PI and it works fine.
With it you will have all characters, all weapons, mods and access to SORMaker : savegame.sorReplace your file in : /opt/retropie/configs/ports/sorr
Now we can access the SORMaker i try it because i have a good selection of mods, but when i enter this menu and select NEw Game, it exit SORR :(
Is some one here already try some mods on PI ?
Thanks -
Could someone sum up the topic? I'm very interested but I'm getting a bit lost... I'm not very good (yet) with linux and retropie :-P I'm pretty sure many users would appreciate this, this is a very good game.
The recent upgrade of the engine to v333 has fixed SORMaker's crashing, worked for me to select the default prototype SORMaker game, anyways.
For other SORMaker games, you just need to copy them into the mods folder but make sure the folder name for each game is written in lowercase letters. It seems like a quirk of the game engine that it always assumes it's running on a case insenstive file system, so it always loads mods by using the lowercase name.
