    Howto : Emulator performance tweaks for PSP and N64 (and quality for PSX)
    gamingn64performancepsppsx
    3 Posts 1 Posters 6.8k Views
      bilu
      Nintendo 64 (Mupen64Plus-Next OpenGLES3, tested with Conker's Bad Fur Day)
      From the Retroarch Quick Menu (Select-X) under Options
      4:3 Resolution = 640x480 (with the parameters below, 720p and overclocking it's smooth enough for me at 2x resolution)
      Bilinear filtering mode: standard
      Noise emulation: false
      Framebuffer emulation: true
      LOD emulation: false
      Color buffer to RDRAM : off
      Depth buffer to RDRAM : off
      Background mode: stripped
      Hardware per-pixel lighting: false
      Continuous textrect coords: off
      Native res. 2D texrects : disabled
      Less accurate blending m... : false
      GPU shader depth write : true
      Cache Textures : true
      Max texture cache size: 8000
      Texture filter: none
      Texture enhancement: As Is
      from "Filter background textures" until "Frame duplication": false
      Framerate: fullspeed
      VI refresh (overclock): 2200
      For all changes done through the Retroarch menu using Select-X you need to save them using overrides:
      Select-X > Overrides > Save Content Directory Overrides (or Game Overrides if specific changes to one game)
      Speaking of which you can save generic options first and then change game-specific and save as game overrides, for Conker's I also use:
      Overscan: enabled
      Offset (Top): 8
      Offset (Left): 14
      Offset (Right): 10
      Offset (Bottom): 12
      Playstation Portable (PPSSPP)
      Combined with the overclocking and 720p allows me to get average 23-26fps in the first fight scene of God of War : Chains of Olympus at 2x resolution :)
      Also great at 2x resolution with Outrun 2006.
      Menu > Settings (if you see the option "Create game config" it means you'll save a global configuration for all PSP games)
      Under Graphics:
      Backend: OpenGL (at least until Vulkan is available)
      Simulate block transfer effects : on
      Software rendering : off
      Frame skipping: 2
      Frame skipping type: Nr of frames
      Auto frameskip : on
      Alternative speed: unlimited
      Alternative speed 2: disabled
      Postprocessing shader: off
      Fullscreen: on
      Rendering resolution: 2x PSP
      Buffer graphic commands: Up to 2
      Hardware transform: on
      Software skinning: on
      Vertex cache: off
      Lazy texture caching: on
      Retain changed textures : off
      Disable slower effects: on
      Spline/Bezier curves quality: Low
      Hardware tesselation: off
      Upscale level: off
      Deposterize: off
      Anisotropic filtering: 16x (this improved performance too)
      Texture filtering: Linear
      Screen scaling filter: Linear
      Lower resolution for effects: Aggressive
      Under System:
      Fast memory : on
      I/O timing method: "fast (lag on slow storage)"
      Force real clock: off
      Change emulated PSP's CPU clock: auto
      Rewind snapshot frequency : off
      Memory Stick inserted: on
      Playstation One
      Enhanced Resolution: on
      Enhanced Resolution (speed hacking): on
      Frame Duping: on
        bilu
        My other relevant threads
        https://retropie.org.uk/forum/topic/27431/howto-major-performance-boost-on-retroarch-based-emulators
        https://retropie.org.uk/forum/topic/27428/howto-change-output-resolution-to-720p-on-libretro-retroarch-emulators
        https://retropie.org.uk/forum/topic/27430/howto-optimized-boot-config-txt
          bilu
          My PPSSPP version on the RPi4 is older than on my Batocera laptop.
          There's a new option "Render duplicate frames to 60Hz" that improved smoothness significantly on my laptop, but I cannot test it on my Rpi4 at the moment.
