    Mad Dog McCree Dos Box Help
    dos gamesdosboxhelpraspberry pi 3braspberrypi
    62 Posts 5 Posters 13.5k Views
    • E
      escc1986
      My Attempt at Trying To Install An ISO on Dosbox
      Then i Came to a Halt
      last picture don't know what to do from here ..
      after i installed it & Exited the game , i dont know how to restart the game.
      After The Game was playing for the first time (after installation)
      • I Exited The Game
      • I Then Did a Restart of Emulationstation (Retropie)
      • I Went to Ms Dos and the 2 options appear (+START DOSBOX & MADDOG)
      -I Click on Maddog
      then it brought me to the page (you see in the last picture)
      Please Help ?
      @quicksilver @mitu @BuZz @Folly @TedMaul
      BuZzB 1 Reply Last reply Reply Quote -2
        BuZz administrators @escc1986
        @escc1986 why have I been tagged?
        • E
          escc1986 @BuZz
          @BuZz yes i tagged you .
          i tagged you to bring my post to your attention and others due to i have seen other dobox tutorials and you have seemed to help ... hope you may help , but my apologies for any bother
          • E
            escc1986
            Im in need of Help Very Similar to this Post
            https://retropie.org.uk/forum/topic/20659/dos-box-directory-doesn-t-exist
            • shavecatS
              shavecat
              i got the it on a atuoexec.bat
              [autoexec]
              @ECHO OFF
              MOUNT -u C
              MOUNT C /media/usb0/roms/pcwin/MADDOGMC
              IMGMOUNT D /media/usb0/roms/pcwin/MADDOGMC/CD/MADDOG.ISO -t iso
              c:
              cd MadDog > NUL
              cls
              maddog
              exit
              change the names for the directory and see that u got the cd iso with that
              hope it helps good luck :)
              • E
                escc1986 @shavecat
                @shavecat said in Mad Dog McCree Dos Box Help:
                [autoexec]
                @ECHO OFF
                MOUNT -u C
                c:
                cd MadDog > NUL
                cls
                maddog
                exit
                Any Chance you can change the Directorys to fit my pi ... it didnt work for me when i tried
                my results were the same page as the last picture .
                or anyway you could make me .bat file ....
                shavecatS 1 Reply Last reply Reply Quote 0
                • shavecatS
                  shavecat @escc1986
                  @escc1986
                  here u go change your file to that -
                  [autoexec]
                  @ECHO OFF
                  MOUNT -u C
                  MOUNT C /home/pi/RetroPie/roms/pc/MADDOGMC
                  IMGMOUNT D /home/pi/RetroPie/roms/pc/MADDOGMC/CD/MADDOG.ISO -t iso
                  c:
                  cd MadDog > NUL
                  cls
                  maddog
                  exit
                  Just put your MADDOG folder in that name folder in the pc folder .
                  pc/MADDOGMC/MADDOG
                  and cd iso image in a folder -
                  pay attention all the names need to be the same (with big letters)
                  or u can change it.
                  hope it helps ;)
                  • E
                    escc1986
                    I Appreciate This Thank you
                    i will give it a try ...
                    • E
                      escc1986
                      i didnt get it to work :(
                      • E
                        escc1986
                        However this Method Worked
                        • E
                          escc1986
                          @shavecat
                          I guess the only Problem now is i am not getting any sound or volume
                          Any Tips or Suggesting ?
                          i also have a freeze up regarding the sound issue
                          hows everything on your end , did you have sound issues ?
                          • shavecatS
                            shavecat @escc1986
                            @escc1986
                            hey glad u got it working !
                            no sound issues on my side , that u need to check :)
                            u know u also have the same game in sega-cd ...
                            • E
                              escc1986
                              @shavecat
                              Thank you , very nice words from you ... yeahh its great to finally get it to work .... i like this version alot since dos is where i played this game as a young lad
                              yeah no sound for me ... im going to see if i can reinstall and take a picture of the sound settings ? maby you can recoomend me a settings for soundblaster ?
                              • E
                                escc1986
                                @shavecat
                                ok right now im at the Sound Settings of the installation screen for " Mad Dog McCree " game
                                What Settings Do You Prefer ?
                                • shavecatS
                                  shavecat @escc1986
                                  @escc1986
                                  Got to say i never change anything there in the sound options or even go there.
                                  check another msdos game , u have sound with it ?
                                  this is my dosbox-SVN.conf - (in the folder retropie/configs/pc)
                                  # This is the configuration file for DOSBox SVN. (Please use the latest version of DOSBox)
                                  # Lines starting with a # are comment lines and are ignored by DOSBox.
                                  # They are used to (briefly) document the effect of each option.
                                  [sdl]
                                  #       fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
                                  #       fulldouble: Use double buffering in fullscreen. It can reduce screen flickering, but it can also result in a slow DOSBox.
                                  #   fullresolution: What resolution to use for fullscreen: original, desktop or a fixed size (e.g. 1024x768).
                                  #                     Using your monitor's native resolution with aspect=true might give the best results.
                                  #                     If you end up with small window on a large screen, try an output different from surface.On Windows 10 with display scaling (Scale and layout) set to a value above 100%, it is recommended
                                  #                     to use a lower full/windowresolution, in order to avoid window size problems.
                                  # windowresolution: Scale the window to this size IF the output device supports hardware scaling.
                                  #                     (output=surface does not!)
                                  #           output: What video system to use for output.
                                  #                     Possible values: surface, overlay.
                                  #         autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
                                  #      sensitivity: Mouse sensitivity. The optional second parameter specifies vertical sensitivity (e.g. 100,-50).
                                  #      waitonerror: Wait before closing the console if dosbox has an error.
                                  #         priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
                                  #                     pause is only valid for the second entry.
                                  #                     Possible values: lowest, lower, normal, higher, highest, pause.
                                  #       mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the default value.
                                  #     usescancodes: Avoid usage of symkeys, might not work on all operating systems.
                                  fullscreen = true
                                  fulldouble       = false
                                  fullresolution = desktop
                                  windowresolution = original
                                  output = overlay
                                  autolock         = true
                                  sensitivity      = 100
                                  waitonerror      = true
                                  priority         = higher,normal
                                  mapperfile       = mapper-SVN.map
                                  usescancodes = false
                                  [dosbox]
                                  # language: Select another language file.
                                  #  machine: The type of machine DOSBox tries to emulate.
                                  #             Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
                                  # captures: Directory where things like wave, midi, screenshot get captured.
                                  #  memsize: Amount of memory DOSBox has in megabytes.
                                  #             This value is best left at its default to avoid problems with some games,
                                  #             though few games might require a higher value.
                                  #             There is generally no speed advantage when raising this value.
                                  language =
                                  machine  = svga_s3
                                  captures = capture
                                  memsize  = 16
                                  [render]
                                  # frameskip: How many frames DOSBox skips before drawing one.
                                  #    aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!
                                  #    scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,
                                  #              then the scaler will be used even if the result might not be desired.
                                  #              To fit a scaler in the resolution used at full screen may require a border or side bars,
                                  #              to fill the screen entirely, depending on your hardware, a different scaler/fullresolution might work.
                                  #              Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
                                  frameskip = 0
                                  aspect    = false
                                  scaler = none
                                  [cpu]
                                  #      core: CPU Core used in emulation. auto will switch to dynamic if available and
                                  #              appropriate.
                                  #              Possible values: auto, dynamic, normal, simple.
                                  #   cputype: CPU Type used in emulation. auto is the fastest choice.
                                  #              Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.
                                  #    cycles: Amount of instructions DOSBox tries to emulate each millisecond.
                                  #              Setting this value too high results in sound dropouts and lags.
                                  #              Cycles can be set in 3 ways:
                                  #                'auto'          tries to guess what a game needs.
                                  #                                It usually works, but can fail for certain games.
                                  #                'fixed #number' will set a fixed amount of cycles. This is what you usually
                                  #                                need if 'auto' fails (Example: fixed 4000).
                                  #                'max'           will allocate as much cycles as your computer is able to
                                  #                                handle.
                                  #              Possible values: auto, fixed, max.
                                  #   cycleup: Amount of cycles to decrease/increase with keycombos.(CTRL-F11/CTRL-F12)
                                  # cycledown: Setting it lower than 100 will be a percentage.
                                  core = dynamic
                                  cputype   = auto
                                  cycles = max
                                  cycleup   = 10
                                  cycledown = 20
                                  [mixer]
                                  #   nosound: Enable silent mode, sound is still emulated though.
                                  #      rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
                                  #              Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
                                  # blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
                                  #              Possible values: 1024, 2048, 4096, 8192, 512, 256.
                                  # prebuffer: How many milliseconds of data to keep on top of the blocksize.
                                  nosound   = false
                                  rate      = 44100
                                  blocksize = 1024
                                  prebuffer = 25
                                  [midi]
                                  #     mpu401: Type of MPU-401 to emulate.
                                  #               Possible values: intelligent, uart, none.
                                  # mididevice: Device that will receive the MIDI data from MPU-401.
                                  #               Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
                                  # midiconfig: Special configuration options for the device driver. This is usually the id or part of the name of the device you want to use (find the id/name with mixer/listmidi).
                                  #               Or in the case of coreaudio, you can specify a soundfont here.
                                  #               When using a Roland MT-32 rev. 0 as midi output device, some games may require a delay in order to prevent 'buffer overflow' issues.
                                  #               In that case, add 'delaysysex', for example: midiconfig=2 delaysysex
                                  #               See the README/Manual for more details.
                                  mpu401     = intelligent
                                  mididevice = alsa
                                  midiconfig = 128:0
                                  [sblaster]
                                  #  sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
                                  #            Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
                                  #  sbbase: The IO address of the soundblaster.
                                  #            Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
                                  #     irq: The IRQ number of the soundblaster.
                                  #            Possible values: 7, 5, 3, 9, 10, 11, 12.
                                  #     dma: The DMA number of the soundblaster.
                                  #            Possible values: 1, 5, 0, 3, 6, 7.
                                  #    hdma: The High DMA number of the soundblaster.
                                  # sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
                                  # oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
                                  #            Possible values: auto, cms, opl2, dualopl2, opl3, opl3gold, none.
                                  #  oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
                                  #            Possible values: default, compat, fast, mame.
                                  # oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
                                  #            Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
                                  sbtype  = sb16
                                  sbbase  = 220
                                  irq     = 7
                                  dma     = 1
                                  hdma    = 5
                                  sbmixer = true
                                  oplmode = auto
                                  oplemu  = default
                                  oplrate = 44100
                                  [gus]
                                  #      gus: Enable the Gravis Ultrasound emulation.
                                  #  gusrate: Sample rate of Ultrasound emulation.
                                  #  gusbase: The IO base address of the Gravis Ultrasound.
                                  #             Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
                                  #   gusirq: The IRQ number of the Gravis Ultrasound.
                                  #             Possible values: 5, 3, 7, 9, 10, 11, 12.
                                  #   gusdma: The DMA channel of the Gravis Ultrasound.
                                  #             Possible values: 3, 0, 1, 5, 6, 7.
                                  # ultradir: Path to Ultrasound directory. In this directory
                                  #             there should be a MIDI directory that contains
                                  #             the patch files for GUS playback. Patch sets used
                                  #             with Timidity should work fine.
                                  gus      = false
                                  gusrate  = 44100
                                  gusbase  = 240
                                  gusirq   = 5
                                  gusdma   = 3
                                  ultradir = C:\ULTRASND
                                  [speaker]
                                  # pcspeaker: Enable PC-Speaker emulation.
                                  #    pcrate: Sample rate of the PC-Speaker sound generation.
                                  #     tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
                                  #              Possible values: auto, on, off.
                                  # tandyrate: Sample rate of the Tandy 3-Voice generation.
                                  #    disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
                                  pcspeaker = true
                                  pcrate    = 44100
                                  tandy     = auto
                                  tandyrate = 44100
                                  disney    = true
                                  [joystick]
                                  #  joysticktype: Type of joystick to emulate: auto (default), none,
                                  #                  2axis (supports two joysticks),
                                  #                  4axis (supports one joystick, first joystick used),
                                  #                  4axis_2 (supports one joystick, second joystick used),
                                  #                  fcs (Thrustmaster), ch (CH Flightstick).
                                  #                  none disables joystick emulation.
                                  #                  auto chooses emulation depending on real joystick(s).
                                  #                  (Remember to reset dosbox's mapperfile if you saved it earlier)
                                  #                  Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
                                  #         timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
                                  #      autofire: continuously fires as long as you keep the button pressed.
                                  #        swap34: swap the 3rd and the 4th axis. Can be useful for certain joysticks.
                                  #    buttonwrap: enable button wrapping at the number of emulated buttons.
                                  # circularinput: enable translation of circular input to square output.
                                  #                  Try enabling this if your left analog stick can only move in a circle.
                                  #      deadzone: the percentage of motion to ignore. 100 turns the stick into a digital one.
                                  joysticktype  = auto
                                  timed         = true
                                  autofire      = false
                                  swap34        = false
                                  buttonwrap    = false
                                  circularinput = false
                                  deadzone      = 10
                                  [serial]
                                  # serial1: set type of device connected to com port.
                                  #            Can be disabled, dummy, modem, nullmodem, directserial.
                                  #            Additional parameters must be in the same line in the form of
                                  #            parameter:value. Parameter for all types is irq (optional).
                                  #            for directserial: realport (required), rxdelay (optional).
                                  #                             (realport:COM1 realport:ttyS0).
                                  #            for modem: listenport (optional).
                                  #            for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
                                  #                           transparent, port, inhsocket (all optional).
                                  #            Example: serial1=modem listenport:5000
                                  #            Possible values: dummy, disabled, modem, nullmodem, directserial.
                                  # serial2: see serial1
                                  # serial3: see serial1
                                  # serial4: see serial1
                                  serial1 = dummy
                                  serial2 = dummy
                                  serial3 = disabled
                                  serial4 = disabled
                                  [dos]
                                  #            xms: Enable XMS support.
                                  #            ems: Enable EMS support. The default (=true) provides the best
                                  #                   compatibility but certain applications may run better with
                                  #                   other choices, or require EMS support to be disabled (=false)
                                  #                   to work at all.
                                  #                   Possible values: true, emsboard, emm386, false.
                                  #            umb: Enable UMB support.
                                  # keyboardlayout: Language code of the keyboard layout (or none).
                                  xms            = true
                                  ems            = true
                                  umb            = true
                                  keyboardlayout = auto
                                  [ipx]
                                  # ipx: Enable ipx over UDP/IP emulation.
                                  ipx = false
                                  [autoexec]
                                  # Lines in this section will be run at startup.
                                  # You can put your MOUNT lines here.
                                  and i have a *.sh fie that ruining the config of that before like that -
                                  maddogmc.sh (in just the PC FOLDER)
                                  #!/bin/bash
                                  /opt/retropie/emulators/dosbox/bin/dosbox -conf /opt/retropie/configs/pc/dosbox-SVN.conf -conf /home/pi/RetroPie/roms/pc/MADDOGMC/AUTOEXEC.BAT -exit
                                  try add this files with the data inside , and run the *.sh file.
                                  hope it will make it work ;)
                                  • E
                                    escc1986
                                    #!/bin/bash
                                    Thanks for the advice
                                    unfortuly it didnt work the .sh file you advised ...
                                    i dont know whats wrong with the sound in dosbox ...
                                    i tried with
                                    dosbox
                                    ir dosbox
                                    • shavecatS
                                      shavecat @escc1986
                                      @escc1986
                                      have u tired other games ?
                                      that u got sound on the msdos ?
                                      • E
                                        escc1986 @shavecat
                                        @shavecat
                                        yeah i relized i didnt have sound in any other game ..
                                        i only have
                                        psx games
                                        mame games
                                        3 dosbox games
                                        (all light gun games for those 3 consoles )
                                        then i went to the audio setting in Retropie and selected default ...
                                        i got my sound back in all games , except dosbox (no audio or sound )
                                        i dont know if its my set up but all the audio is either choppy or cracking
                                        but dosbox ... no sound at all
                                        i installed
                                        mad dog 1
                                        mad dog 2
                                        who shot johnny rock
                                        • no sound in the dosbox games
                                        • choppy sounds psx games
                                        • cracking sounds in the mame games
                                        any suggestings ... do you need me to pull up any logs or something so you can see or any pictures of anything ?
                                        • shavecatS
                                          shavecat @escc1986
                                          @escc1986
                                          Sorry dont know whats the deal :\
                                          • E
                                            escc1986 @shavecat
                                            @shavecat
                                            yeah , sorry for that .... i dont know either ...
                                            maby i should start fresh all over with a stock image and try all over huh ?
