    "EmulationStation --rotate" problems with VGA666
    emulationstaionrotaterotationcrt
    3 Posts 2 Posters 378 Views
      Jouster
      I had rigged up a nice little modification to emulationstation.sh where it would toggle back and forth between rotated mode and horizontal mode. This worked great for my manually rotated CRT monitor.
      However, I have since then moved from an HDMI/VGA input to an analog VGA666 adapter, which required me to manually set the HDMI_TIMINGS for 800x600 mode. I also upgraded to RetroPie 4.6 on my Raspberry Pi 3b+. Now, when I use
      emulationstation --rotate=1
      it still rotates, but the menus do not rescale to the vertical orientation (600 x 800 vs. 800 x 600). As a result, the emulationstation menus do not fill the vertical screen and they extend off the right side of the screen. I tried using
      emulationstation --rotate=1 --windowed --resolution 600 800
      but that created a small image in a corner. Any thoughts as to how I can get this to work correctly? Am I missing a configuration parameter of some kind?
        gomisensei @Jouster
        @Jouster try --screensize 600 800
          Jouster
          @gomisensei That worked perfectly, thanks!
