    How to fix controllers not working with “lr-“ emulators?
    controller cfglibertohelp
    9 Posts 2 Posters 665 Views
      MarcuFinx76
      I’ve been trying to get an Xbox controller to work with gles2rice on the N64 and psx-rearmed on the PS1 but for some reason I can’t do anything unless I use a wireless keyboard. They work perfectly fine with things like lr-mupen64 and other emulators having that “lr-“ but it’s frustrating for the games that don’t run as well on them. If anybody can help it would be much appreciated
      (Also this is all on a Pi 3b+)
      • H
        helloThere
        For non liberto core (lr-) n64 emulators, I usually have to manually edit config files.
        Try editing this file: /opt/retropie/configs/n64/InputAutoCfg.ini
        There's a little more info on how to make n64 controllers work in the docs: https://retropie.org.uk/docs/Nintendo-64/
          MarcuFinx76 @helloThere
          @helloThere Is there a way to get to there through the command line because I’m cycling through the menus and can’t find it, or am I just missing it
          • H
            helloThere
            Just plug in a keyboard and hit F4 to bring up the command line.
            To open back up into EmulationStation, just type emulationstation into the command prompt.
              @helloThere I tried typing that exact line into the command line and it says “Permission denied”?
              • H
                helloThere
                Try sudo nano /opt/retropie/configs/n64/InputAutoCfg.ini
                  @helloThere Ok that worked, looking at a big empty black screen with new file and various key commands at the bottom. Hopefully its not to much to ask what to do next
                  • H
                    helloThere
                    Just try playing around with it for a while. Best way to learn.
                    I don't think it should be a totally empty file when first opened, though. This is what mine looked like after a bit.
                      @helloThere Well that’s weird. Mine is completely empty. Hopefully the image attaches correctly but the box has no code in it like yours. Maybe I missed a step?666C68D6-5BA0-45D6-8402-FC7B9A265938.jpeg
