    Mario 64 missing shadow/Depth buffer problem
    n64errormario 64
    2 Posts 1 Posters 391 Views
    • JustNiko02J
      JustNiko02
      Im having problems with mario 64 using the gfx glide64, the shadow and some textures are flickering.
      i found that its a problem with intel and a fix for this was changing the depth buffer from 16 bit to 32 bits but how can i change this?
      • JustNiko02J
        JustNiko02
        nevermind, i think i fixed it by removing a custom video mode from the menu that appears whe you press A at launching
