    lvl0: Error creating SDL window!, etc... Help!
    helpsupportsdlrenderererror
    3 Posts 2 Posters 3.3k Views
    • kizmiazK
      kizmiaz
      Please bear with me because I'm new to all of this
      I keep getting these error messages when I boot up the pi using the image I flashed onto the previously formatted Micro SD. I have followed the official guide and not made any changes to the scripts or files. I have tried changing the boot up options within rapsi-config to no avail.
      Any help would be greatly appreciated
      Pi Model or other hardware: Raspberry Pi 3 Model B V:1.2
      Power Supply used: Output 5.5V=0.7A (not sure if this is the correct info to put here)
      RetroPie Version Used : 4
      Built From: retropie-buster-4.6-rpi4.img (from retropie.org)
      USB Devices connected: n/a
      Controller used: PS3 Compatible wired controller and a keyboard.
      Error messages received:
      Could not initialize EGL
      lvl0: Renderer failed to initialize!
      lvl0: Window failed to intialize!
      Verbose log (if relevant): not sure.
      Guide used: (Mention if you followed a guide): retropie installation guide, also this:
      File: Not sure.
      Emulator: Emulationstation
      Attachment of config files:
      For more options and information see
      http://rpf.io/configtxt
      Some settings may impact device functionality. See link above for details
      uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      uncomment this if your display has a black border of unused pixels visible
      and your display can output without overscan
      #disable_overscan=1
      uncomment the following to adjust overscan. Use positive numbers if console
      goes off screen, and negative if there is too much border
      #overscan_left=16
      #overscan_right=16
      #overscan_top=16
      #overscan_bottom=16
      uncomment to force a console size. By default it will be display's size minus
      overscan.
      #framebuffer_width=1280
      #framebuffer_height=720
      uncomment if hdmi display is not detected and composite is being output
      #hdmi_force_hotplug=1
      uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      uncomment to force a HDMI mode rather than DVI. This can make audio work in
      DMT (computer monitor) modes
      #hdmi_drive=2
      uncomment to increase signal to HDMI, if you have interference, blanking, or
      no display
      #config_hdmi_boost=4
      uncomment for composite PAL
      #sdtv_mode=2
      #arm_freq=800
      Uncomment some or all of these to enable the optional hardware interfaces
      #dtparam=i2c_arm=on
      #dtparam=i2s=on
      #dtparam=spi=on
      Uncomment this to enable infrared communication.
      Additional overlays and parameters are documented /boot/overlays/README
      Enable audio (loads snd_bcm2835)
      dtparam=audio=on
      [pi4]
      Enable DRM VC4 V3D driver on top of the dispmanx display stack
      dtoverlay=vc4-fkms-v3d
      max_framebuffers=2
      [all]
      #dtoverlay=vc4-fkms-v3d
      overscan_scale=1
      How to replicate the problem: not sure.
        mitu Global Moderator @kizmiaz
        @kizmiaz said in lvl0: Error creating SDL window!, etc... Help!:
        Why are you using the image for a Raspberry Pi 4 model if you have a Pi3B ? Download the correct image for your Pi.
        kizmiazK 1 Reply Last reply Reply Quote 0
        • kizmiazK
          kizmiaz @mitu
          @mitu fixed
