    SDLTRS - System command does not work!
    trs80trs-80systemsldtrscas
    2 Posts 2 Posters 394 Views
      mcfaria2000
      Hi!
      I got some problem to load a tape using SLDTRS at Retropie.
      I got the message:
      "WHAT?"
      every time that I use the SYSTEM command.
      I had change the model type and the rom file, but I still get the error message?
      Did I make same mistake or error?
      Thanks everyone!
        JenGun @mcfaria2000
        @mcfaria2000 You are using the "Level I" ROM instead of "Level II". There is no SYSTEM command in "Level I" ...
