    Compiles fine manually, fails to compile in RetroPie script
    xash3dscriptmodulescompile
    13 Posts 4 Posters 1.9k Views
    • Z
      zerojay
      Hi, I'm currently attempting to write a port for xash3d-fwgs, a newer version of the engine for Half-Life. Unfortunately, I'm having a strange issue where running the steps manually results in a compiled build that functions, but running them through a RetroPie scriptmodule fails. I suspect that what is going on is RetroPie is adding its own CFLAGS and this is causing the script's detection to fail. Here's the in-progress version of the script module:
      rp_module_id="xash3d-fwgs"
      rp_module_desc="xash3d-fwgs - Half-Life Engine Port"
      rp_module_help="Please add your full version xash3d-fwgs files to $romdir/ports/$md_id/ to play."
      rp_module_section="exp"
      rp_module_flags="!mali !x86"
      function depends_xash3d-fwgs() {
          getDepends libsdl2-dev libfontconfig1-dev libfreetype6-dev
      function sources_xash3d-fwgs() {
          gitPullOrClone "$md_build" https://github.com/FWGS/xash3d-fwgs.git
      function build_xash3d-fwgs() {
           ./waf configure -T release
           ./waf build
          md_ret_require=(
              "$md_build/build/game_launch/xash3d"
              "$md_build/build/engine/libxash.so"
      function install_xash3d-fwgs() {
          ./waf install
      function configure_xash3d-fwgs() {
      # Work not started on configure, ignore.
      Building with this script results in the following:
      [  3/258] Compiling public/xash3d_mathlib.c
      [  4/258] Compiling public/crtlib.c
      In file included from ../public/crtlib.h:20,
                       from ../public/crclib.c:17:
      ../public/build.h:188:4: error: #error "Unknown ARM"
      Instructions for building manually found here under Building: https://github.com/FWGS/xash3d-fwgs
      Looking into build/compile_commands.json in my manual compile, I see the following:
       "arguments": [
            "/usr/bin/gcc",
            "-g",
            "-fvisibility=hidden",
            "-O3",
            "-fdiagnostics-color=always",
            "-Werror=return-type",
            "-Werror=parentheses",
            "-Werror=vla",
      Looking at the build/compile_commands.json of the RetroPie build, I see the following:
          "arguments": [
            "/usr/bin/gcc",
            "-march=armv8-a+crc",
            "-mtune=cortex-a72",
            "-mfpu=neon-fp-armv8",
            "-mfloat-abi=hard",
            "-O2",
            "-g",
            "-O3",
            "-Werror=vla",
      Looking at the piece of code for figuring out the ARM stuff, from public/build.h:
      #elif defined __arm__ || defined _M_ARM
              #if defined _M_ARM
                      // msvc can only armv7 ?
                      #define XASH_ARM 7
              #elif __ARM_ARCH == 7 || __ARM_ARCH_7__
                      #define XASH_ARM 7
              #elif __ARM_ARCH == 6 || __ARM_ARCH_6__ || __ARM_ARCH_6J__
                      #define XASH_ARM 6
              #elif __ARM_ARCH == 5 || __ARM_ARCH_5__
                      #define XASH_ARM 5
              #elif __ARM_ARCH == 4 || __ARM_ARCH_4__
                      #define XASH_ARM 4
              #else
              #endif
              #if defined __SOFTFP__ || __ARM_PCS_VFP == 0
                      #define XASH_ARM_SOFTFP 1
              #else // __SOFTFP__
                      #define XASH_ARM_HARDFP 1
      #if XASH_ARM == 7
              #define XASH_ARMv7 1
      #elif XASH_ARM == 6
              #define XASH_ARMv6 1
      #elif XASH_ARM == 5
              #define XASH_ARMv5 1
      #elif XASH_ARM == 4
              #define XASH_ARMv4 1
      #endif
      I'm not too sure how to continue here. I attempted to add CFLAGS="" before the ./waf calls in build and it did indeed remove the flags that RetroPie seems to be adding however you can see that it's only worked for a few files, not all of them.
      Any ideas/advice would be most appreciated.
        That's because -march=armv8-a+crc switches __ARM_ARCH to 8, while the defaults for the compiler sets __ARM_ARCH to 6. The header you referenced doesn't know about the newer __ARM_ARCH variant.
        # RetroPie flags
        $ echo | gcc -march=armv8-a+crc -dM -E - | grep -i '__ARM_ARCH '
        #define __ARM_ARCH 8
        # no flags
        $ echo | gcc -dM -E - | grep -i '__ARM_ARCH '
        #define __ARM_ARCH 6
        Z 1 Reply Last reply Reply Quote 1
        • Z
          zerojay @mitu
          @mitu Thank you, I've sent a pull request upstream with the fix.
            kactius @zerojay
            @zerojay You pull was accepted
            • Z
              zerojay @kactius
              @kactius said in Compiles fine manually, fails to compile in RetroPie script:
              Yep, thanks.
                kactius
                Hi
                I update extras script and test xash3d-fwgs
                Could not successfully build xash3d-fwgs - xash3d-fwgs - Half-Life Engine Port (home/pi/RetroPie-Setup/rmp/build/xash3d-fwgs/xash3d-fwgs/build/game_launch/Xash3D not found)...
                Really the folder is empty sftp://retropie/home/pi/RetroPie-Setup/tmp/build/xash3d-fwgs/xash3d-fwgs/build/game_launch/ empty
                If you need logs, please ask me
                • Z
                  zerojay @kactius
                  Hi
                  Yeah, post the logs please.
                    kactius @zerojay
                    @zerojay
                    /home/pi/RetroPie-Setup/logs/rps_2020-10-14_123218.log.gz
                    https://pastebin.com/wAh1AfQr
                    If you need more logs, say me patch to other logs
                    • Z
                      zerojay @kactius
                      @zerojay
                      Nothing I can do about that, you'll need to ask upstream.
                        kactius @zerojay
                        @zerojay
                        Hi sorry to reflow this threat, pi3b+ now is compile fine.
                        Install source xash3d and next install source xash3d-fwgs
                        link log
                        I still have to put the game files to test.
                        • ExarKunIvE
                          ExarKunIv @kactius
                          @kactius yes it was fixed on Wednesday. I came across it not working so I was working with the dev over there on fwgs and we got it all straightened out. Just hope that it stays that way this time
                            kactius @ExarKunIv
                            @exarkuniv said in Compiles fine manually, fails to compile in RetroPie script:
                            Oh! Very thanks.
                            fwgs is working.
                            I paste the game files in this moment some ¿textures? don't look good in pi 3 b+ pi3.
                            Found rendener gl: OpenGL
                            Found renderer soft: Sofitware Loading renderer: gl -> libref_gl.so
                            Trying safe opengl mode O
                            bpp 32
                            Sys Warn Error: Can't initialize libref_gl.so renderer
                            • ExarKunIvE
                              ExarKunIv @kactius
                              @kactius i think that,s happening cuz the pi3 does not support opengl
                              i have the old halflife port on my pi3 so i cant test it on that since i have it working fine.
                              and right now im working with my pi4
