    Using a second controller for the hot key
    controller cfghotkeyhotkey mapping
    3 Posts 2 Posters 517 Views
    • N
      nmlnet
      Hey all,
      I use a USB SNES controller, which has been great so far but with some games I need the pause button (which I usually map as the hotkey)
      I have no spare buttons - is it possible to map a keyboard key as the hotkey, but continue to use the SNES controller for control?
      When I map the input controller buttons for the controller and get to hotkey, it doesn't recognize the keyboard input
      Hope someone can help - my favorite games await me!
      • N
        nmlnet
        Note: it's a wireless keyboard, but I have no issue typing when scraping
          mitu Global Moderator @nmlnet
          @nmlnet said in Using a second controller for the hot key:
          You cannot map inputs from 2 separate input devices in EmulationStation, each one should be mapped separately. Try mapping your keyboard as well - separately from your SNES gamepad - and choose a hotkey there.
          TAhis works because your 2nd device is a keyboard and it works as P1 (just as your gampead), otherwise you wouldn't be able to use a 2nd controller for hotkey - only P1 has hotkey control.
