    IR-Flycast Help :Confidential Mission Naomi pi 4 Configuration HELP
    pi 4light gunnaomiflycast
    3 Posts 2 Posters 680 Views
    • E
      escc1986
      I seem to be having problems configuring "Confidential Mission" Naomi version
      i do want to play the arcade version which is the Naomi version
      i have a dolphin bar / wii mote combo trying to configure for light gun support
      i could shoot the trigger
      i could reload the gun
      the cross hairs and gun X Y doesn't move
      i tried service menu but that didn't help either (unless im doing something wrong )
      if anyone has a fix , would love to know ....
      thank you for everyone in advanced
        ReadyPlayaWon Banned @escc1986
        @escc1986
        If you can't get it working ... then maybe you'll have more luck with the Dreamcast version of Confidential Mission ?
        I don't have i lightgun, and i couldn't figure out the controls of the Naomi version ... loaded up the Dreamcast version in Redream and controls work perfect without having to configure anything. Maybe the lightgun controls will work for you with the version ?
        • E
          escc1986 @ReadyPlayaWon
          @ReadyPlayaWon
          Thank you for your advice ReadyPlayawon
          I actually do already have the Dreamcast version loaded in my Pi , I just wanted to try the Naomi version due to I have never played the arcade version and sometimes there are little things here and there they may have changed or become different
          Just something about the Arcade version games I enjoy better , possibly because the infinite amount of credits by coins possible , or the service menus to change the lives , difficulty and such .. I don't know for sure ... Call me weird I guess
          I do enjoy your input and advice , Thank you for that
          Maby this version on Flycast is a bit wonky and needs more configuration within the core itself by the developers
