AmiBerry Whdload Help
I need help with AmiBerry. I am on RetroPie 4.6 with the 8gb raspberry pi 4 B.
I can't get it to load the .lha games automatically. I have downloaded the "Retroplay whd uploads" lha files. When I select a game to play, it loads to the blue disk (Workbench 1.3) screen.
I have all the correct KickStart Roms from Amiga Forever named correctly (I have checked the roms with an online Online CRC32 Checker). I have them stored in BIOS AND BIOS/Amiga. I also have "WHDLoad_usr.lha" and "WHDLoad_dev.lha" stored in Roms/amiga. I have pointed the System Roms path to /home/pi/RetroPie/BIOS and I have rescanned the paths and updated the whdload xml.
When AmiBerry loads and it gives the blue disk, if I then F12 and go to QuickStart and select the "WHDLoad_usr.lha" file in Roms/amiga for the "WHDLoad auto-config" file, it creates 3 drives.
I can then reset AmiBerry and it loads but fails when starting whdload. I can then F12 again and select the game's .lha file in the QuickStart "WHDLoad auto-config" spot, and reset AmiBerry again and the game will load.
It is like it is not really recognizing the whdload so those 3drives are not being created and I have to select it manually on the QuickStart page.
Here are the screens I am talking about. The QuickStart screen where I select the "WHDLoad_usr.lha" file in Roms/amiga for the "WHDLoad auto-config" file.
And here are the 3 drives that it creates which are missing if I don't hand select the "WHDLoad_usr.lha" file on the QuickStart screen.
