    N64, NES and more not showing
    n64snesnot showingz64 .n64 n64
    17 Posts 6 Posters 2.7k Views
    • Y
      yyx2
      Hi.
      New member here and still trying to learn :)
      I've got most of the emulator games to work, BUT there are still a few that don't show despite its correct file name.
      I've download full packs of roms for nes, snes, atari-seriers, n64, megadrive. The games that work is the snes, atari2600 and some 7800. Before posting this thread i've honestly looked for a solution with people with the same problem, i've found solved threads but it dosen't match my problem sadly.
      Most of the common problem is that people have not unzip the files, i've done that. They are z64 as an example for n64 games.
      What is missing or what have i've done wrong?
      • IanDaemonI
        IanDaemon
        Depending on the emulator you don't need to use uncompressed files. If the emulator supports compressed files you can add the extension to the es_systems.cfg.
        • Cocktail Cabinet Games
        • Check out the MAME RoW
        • Y
          yyx2
          Thanks for your reply. Where do i fix the extension?
          • IanDaemonI
            IanDaemon
            Here's some information to try: https://retropie.org.uk/forum/topic/23120/ports-won-t-launch-from-emulation-station/2?_=1601836370881
            Specifically per @backstander :
            ~/.emulationstation/es_systems.cfg (which is a symlink to /opt/retropie/configs/all/emulationstation/es_systems.cfg)
            Y 1 Reply Last reply Reply Quote 0
              mitu Global Moderator @yyx2
              @yyx2 said in N64, NES and more not showing:
              Each system is documented with it's own page in the Docs, the supported extensions are listed there. If your ROM filenames don't have the correct extension, they'll not show up in the gamelist.
              • Y
                yyx2 @mitu
                thanks for your reply. I've looked trough every single one of the docs and i have already followed those steps. I don't understand.
                Like i mention before i have working snes games and a few atari but the n64 and nes are not showing. The filename on n64 is .z64 which from i understand is a correct file type?
                • Z
                  Zering
                  What emulators are you using to run n64 and nes?
                  • Y
                    yyx2 @IanDaemon
                    @IanDaemon
                    thanks for your reply, since im such a noob. How do i enter that "mode"? the emulationsstation/es_system..
                    • Y
                      yyx2 @Zering
                      @Zering
                      hi. im sorry, but where can i see that?
                        @yyx2 Please add a screenshot with the file listing of your NES or N64 game rom folders and some details about your system, as requested in https://retropie.org.uk/forum/topic/3/read-this-first
                        • Y
                          yyx2
                          Yes'ir.
                          Pi Model or other hardware: Raspberry Pi 3B+
                          Power Supply used: Official charger from starter kit
                          RetroPie Version Used: 4.6
                          Built From: -
                          USB Devices connected: wireless keyboard/mouse / ps4 controller with cable
                          Controller used: PS4 controller
                          Error messages received: -
                          Guide used: N/A
                          File: Presumably -
                          Emulator: Ports
                          Attachment of config files: N/A
                          I hope i got everything and here's the picture
                          https://imgshare.io/image/Nvzp6g
                          https://imgshare.io/image/Nvz6e7
                          https://imgshare.io/image/Nvfzsq
                          Y Thorr69T 2 Replies Last reply Reply Quote 0
                          • Y
                            yyx2 @yyx2
                            Yes'ir.
                            Built From: -
                            Guide used: N/A
                            File: Presumably -
                            Emulator: Ports
                            also it is only showing 28 games on mega drive, and i have 700 games on the usb
                            • Thorr69T
                              Thorr69 @yyx2
                              Built From: -
                              You skipped the most important question. What image did you use to build this system?
                              and
                              Did you configure the system to read roms from the USB directly? If not, you need to copy them to your SD card.
                              RPi 3b
                              Official PSU
                              Official RetroPie image
                              Pandora's Box 5 controller
                                astorga
                                It would help to show the complete path of roms. Since Linux use a case-sensitive file system, if you use, for example "NES" instead of "nes", it might be a problem.
                                  Which USB are we talking about ? You haven't specified how you transfer your files, the screenshots you've posted don't show where these files are located (macOS finder is special like that), but it doesn't seem you're transferring them to your RetroPie via file shares.
                                  As long as you're not mixing the case (NeS, nES), you're fine.
                                  • Y
                                    yyx2 @Thorr69
                                    @Thorr69
                                    okey, let's see. what is meaning with image?
                                    The usb part i've configure to read roms trough the usb. I followed the steps where i first add some roms to the sd card, then transfered them to the usb. i don't know if you understand what i mean, but i hope you do.
                                      How exactly did you install RetroPie ? Did you use the file provided at retropie.org.uk/download (.img.gz) or other methods/files ?
                                      Use the Finder to transfer your files, over the network, and leave the USB alone for now - see the file transfer method using file shares.
