    retroarch/lr-hatari loads a particular hatari.cfg while starting
    hatari.cfglr-hatari
    20 Posts 3 Posters 1.6k Views
      toninodigiacomo
      Hello,
      I am wondering if someone knows how to load a particular hatari.cfg file while loading the emulator (retroarch / lr-hatari).
      For example, I have an app that needs to have one disk in drive A and one disk in drive B or, another example, I do not want to have the borders while loading the emulator.
      Thanks.
        JimmyFromTheBay @toninodigiacomo
        @toninodigiacomo I can't find a way to do this either. I've tried naming the CFG file with the filename with and without the .ST suffix (ie GAMENAME.CFG and GAMENAME.ST.CFG), and I've tried putting it in the /home/pi/RetroPie/roms/atarist folder, the /opt/retropie/configs/all/retroarch/config/atarist folder and the /opt/retropie/configs/all/retroarch/config/Hatari folder, and none of it works. I can only conclude that it's not possible and you have to load it manually every time.
        • FollyF
          Folly @JimmyFromTheBay
          @JimmyFromTheBay
          In the docs I saw this :
          Unlike the standalone Hatari, lr-hatari supports .m3u files and .zip files.
          Look in the docs you should be able to make .m3u files when using lr-hatari.
          I will try to explain why it doesn't work.
          If you are using lr-hatari and the game is called GAMENAME.ST and if you then put a config GAMENAME.ST.CFG in the same directory then that config is loaded as an extra game specific RetroArch config.
          What you probably tried is to load a config from the 'Hatari standalone emulator' which is a totally different config.
          So if an .m3u suits your need then try to do that approach.
            JimmyFromTheBay @Folly
            @Folly Nope, the config was saved by lr-hatari itself, into the /opt/retropie/configs/all/retroarch/config/atarist folder.
            (lr-hatari is broken in many ways and won't let you specify a name, so you have to create an empty config file first and save to that.)
            The file it saved for Super Zazai Da! looks like this:
            [Log]
            sLogFileName = stderr
            sTraceFileName = stderr
            nExceptionDebugMask = 259
            nTextLogLevel = 4
            nAlertDlgLogLevel = 1
            bConfirmQuit = FALSE
            bNatFeats = FALSE
            bConsoleWindow = FALSE
            [Debugger]
            nNumberBase = 10
            nDisasmLines = 8
            nMemdumpLines = 8
            nDisasmOptions = 15
            bDisasmUAE = FALSE
            [Screen]
            nMonitorType = 1
            nFrameSkips = 0
            bFullScreen = FALSE
            bKeepResolution = TRUE
            bKeepResolutionST = TRUE
            bAllowOverscan = TRUE
            nSpec512Threshold = 1
            nForceBpp = 0
            bAspectCorrect = TRUE
            bUseExtVdiResolutions = FALSE
            nVdiWidth = 640
            nVdiHeight = 480
            nVdiColors = 2
            bShowStatusbar = FALSE
            bShowDriveLed = TRUE
            bCrop = FALSE
            bForceMax = TRUE
            nMaxWidth = 832
            nMaxHeight = 520
            [Joystick0]
            nJoystickMode = 1
            bEnableAutoFire = FALSE
            bEnableJumpOnFire2 = FALSE
            nJoyId = 1
            nKeyCodeUp = 1073741906
            nKeyCodeDown = 1073741905
            nKeyCodeLeft = 1073741904
            nKeyCodeRight = 1073741903
            nKeyCodeFire = 1073742052
            [Joystick1]
            nJoystickMode = 1
            nJoyId = 0
            [Joystick2]
            nJoystickMode = 1
            nJoyId = 1
            [Joystick3]
            nJoystickMode = 1
            nJoyId = 1
            [Joystick4]
            nJoystickMode = 1
            nJoyId = 1
            [Joystick5]
            nJoystickMode = 1
            nJoyId = 1
            [Keyboard]
            bDisableKeyRepeat = FALSE
            nKeymapType = 0
            szMappingFileName =
            [ShortcutsWithModifiers]
            keyOptions = 111
            keyFullScreen = 102
            keyMouseMode = 109
            keyColdReset = 99
            keyWarmReset = 114
            keyScreenShot = 103
            keyBossKey = 105
            keyCursorEmu = 106
            keyFastForward = 120
            keyRecAnim = 97
            keyRecSound = 121
            keySound = 115
            keyPause = 0
            keyDebugger = 19
            keyQuit = 113
            keyLoadMem = 108
            keySaveMem = 107
            keyInsertDiskA = 100
            keySwitchJoy0 = 282
            keySwitchJoy1 = 283
            keySwitchPadA = 284
            keySwitchPadB = 285
            [ShortcutsWithoutModifiers]
            keyOptions = 293
            keyFullScreen = 292
            keyMouseMode = 0
            keyColdReset = 0
            keyWarmReset = 0
            keyScreenShot = 0
            keyBossKey = 0
            keyCursorEmu = 0
            keyFastForward = 0
            keyRecAnim = 0
            keyRecSound = 0
            keySound = 0
            keyPause = 19
            keyDebugger = 0
            keyQuit = 0
            keyLoadMem = 0
            keySaveMem = 0
            keyInsertDiskA = 0
            keySwitchJoy0 = 0
            keySwitchJoy1 = 0
            keySwitchPadA = 0
            keySwitchPadB = 0
            [Sound]
            bEnableMicrophone = TRUE
            bEnableSound = TRUE
            bEnableSoundSync = FALSE
            nPlaybackFreq = 44100
            nSdlAudioBufferSize = 0
            szYMCaptureFileName = /home/pi/hatari.wav
            YmVolumeMixing = 2
            [Memory]
            nMemorySize = 2
            bAutoSave = FALSE
            szMemoryCaptureFileName = /home/pi/.hatari/hatari.sav
            szAutoSaveFileName = /home/pi/.hatari/auto.sav
            [Floppy]
            bAutoInsertDiskB = TRUE
            FastFloppy = TRUE
            EnableDriveA = TRUE
            DriveA_NumberOfHeads = 2
            EnableDriveB = TRUE
            DriveB_NumberOfHeads = 2
            nWriteProtection = 0
            szDiskAZipPath =
            szDiskAFileName = /home/pi/RetroPie/roms/atarist/Super Zazai Da!.st
            szDiskBZipPath =
            szDiskBFileName =
            szDiskImageDirectory = /home/pi/
            [HardDisk]
            nHardDiskDrive = 0
            bBootFromHardDisk = FALSE
            bUseHardDiskDirectory = FALSE
            szHardDiskDirectory = /home/pi
            nGemdosCase = 0
            bUseHardDiskImage = FALSE
            szHardDiskImage = /home/pi
            bUseIdeMasterHardDiskImage = FALSE
            bUseIdeSlaveHardDiskImage = FALSE
            szIdeMasterHardDiskImage = /home/pi
            szIdeSlaveHardDiskImage = /home/pi
            [ROM]
            szTosImageFileName = /home/pi/RetroPie/BIOS/TOS206.IMG
            bPatchTos = TRUE
            szCartridgeImageFileName =
            [RS232]
            bEnableRS232 = FALSE
            szOutFileName = /dev/modem
            szInFileName = /dev/modem
            [Printer]
            bEnablePrinting = FALSE
            szPrintToFileName = /home/pi/.hatari/hatari.prn
            [Midi]
            bEnableMidi = FALSE
            sMidiInFileName = /dev/snd/midiC1D0
            sMidiOutFileName = /dev/snd/midiC1D0
            [System]
            nCpuLevel = 2
            nCpuFreq = 8
            bCompatibleCpu = FALSE
            nMachineType = 1
            bBlitter = TRUE
            nDSPType = 0
            bRealTimeClock = FALSE
            bPatchTimerD = TRUE
            bFastBoot = FALSE
            bFastForward = FALSE
            [Video]
            AviRecordVcodec = 2
            AviRecordFps = 0
            AviRecordFile = /home/pi/hatari.avi
            If I rename that file to Super Zazai Da!.st.cfg and put it in the folder along with the game file, it isn't read and the game tries to boot with default settings. It also isn't read if I leave it in the configs folder with that name. But if I load the game normally and then load that config file manually from the lr-hatari menu, it works. So the CFG file is fine, it's getting lr-hatari to load it that's the problem.
            • FollyF
              @JimmyFromTheBay
              Can't promise but if I have some time I will do some tests.
              Still, I can't see how it can work placing Super Zazai Da!.st.cfg next to the game Super Zazai Da!.st because Super Zazai Da!.st.cfg isn't a RetroArch config but an lr-hatari config.
              So I think the location of the config should be somewhere else.
              • FollyF
                @JimmyFromTheBay @dankcushions
                I took some time to dig into the problem.
                Basically, as said earlier, we have to take into account that we don't mix different config files.
                So when we run a game with lr-hatari core in retroarch it will check the
                retroarch.cfg in /opt/retropie/configs/atarist.
                When we want to add some retroarch specific setting for atarist we can do it in /opt/retropie/configs/atarist/retroarch.cfg.
                The standard reatroarch.cfg in /opt/retropie/configs/all will ultimately be included loading the standard values.
                Now when we run a game everything is passed through the runcommand.sh script.
                This script has the ability to add a game-specific retroarch.cfg file.
                Usually we use this for loading overlays for for example vectrex or the handelds (konamih etc in lr-mess) or the realistic overlays of Orionsangels.
                So if we have a file, for example, 1943.st, and if we add a configfile in the same directory called 1943.st.cfg then the runcommand.sh script will append that config as a game-specific retroarch.cfg file.
                Now if we use lr-hatari and we save a configfile in the menu, of lr-hatari, then the default becomes /home/pi/.hatari/hatari.cfg linked to /opt/retropie/configs/atarist/hatari.cfg
                So if we are running 1943.st, for example, and we make a config-file in lr-hatari it will be saved as hatari.cfg.
                This is the config file we would like to load in lr-hatari so we copy the file somewhere inside the atarist roms directory and we rename it to 1943.cfg, for example.
                If we would rename it to 1943.st.cfg then we have a clash because the runcommand.sh script will append it as an game-specific retroarch.cfg but the file is not a retroarch.cfg file !.
                Renaming it somewhat different or making it uppercase can be solution if we want all the letters in the config filename.
                But why not do it simply rename it as 1943.cfg as noted earlier.
                So now we have put the 1943.cfg file in our atarist roms directory and we want to load that file into lr-hatari.
                Too bad the runcommand of lr-hatari in emulators.cfg in /opt/retropie/configs/atarist doesn't pick up configfiles.
                So I looked into the standalone hatari as you can add options to load such configfile.
                Basically it's the same sort of problem when using lr-mess or lr-mame the libretro cores of MAME standalone.
                A year ago I discovered how to add options to a libretro core as lr-mess.
                Now, basically, I tried the same with lr-hatari, and with success.
                For now I made a runcommand for the emulators.cfg that can be pasted it there for loading the game-specific lr-hatari configfiles.
                It looks like this :
                lr-hatari-configfile = "LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-hatari/hatari_libretro.so --config /opt/retropie/configs/atarist/retroarch.cfg 'hatari -c %ROM%'"
                And if we want to have the config files listed in emulationstation then we have to add .cfg .CFG to the /etc/emulationstation/es_systems.cfg for atarist. (change with root permission)
                Though it's possible to skip editing es_systems.cfg if you rename the configfile to 1943.cfg.st then it will be shown as as 1943.cfg in emulationstation which has to be loaded with the lr-hatari-configfile of-course !
                Long story but that should do the trick for now to test.
                Btw.
                I was tinking, now we can also specify the TOS per game in the configfile, sadly that doesn't work.
                TOS2.06 seems to be the best choice for now.
                When using TOSV1.04 :
                • games in "full-screen"
                • many games work, but "Supa zazai da!" does not
                • disadvantage : sometimes you have to load the game twice to get it running
                TOSV4.00 looks problematic to me :
                • games not working
                • games in very tiny windows
                • memory check on start
                • advantage : "Supa zazai da!" works with this TOS (But perhaps there is a better TOS for this)
                When using TOSV2.06 :
                • looks like most games work
                I added a zoomed viewport to my system specific retroarch.cfg in /opt/retropie/configs/atarist/retroarch.cfg.
                Here is the example file :
                input_remapping_directory = "/opt/retropie/configs/atarist/"
                custom_viewport_height = "900"
                custom_viewport_width = "2000"
                custom_viewport_x = "-200"
                custom_viewport_y = "0"
                aspect_ratio_index = 23
                Note that when you are using a different resolution the values have to be changed.
                This file was created for 1600x900.
                  @Folly Okay, I added this line to EMULATORS.CFG
                  and I set Super Zazai Da! to load with lr-hatari-configfile. The gamefile is called Super Zazai Da!.st and the config file (contents in my previous post) is in the roms folder with it, called Super Zazai Da!.cfg.
                  But that just boots up a white screen, and if I check the Hatari menu it has none of the settings from the CFG file. (It does the same if I put the config file in the configs folder rather than the roms folder.)
                  What am I missing?
                  [EDIT] Renaming the config file to Super Zazai Da!.cfg.st worked (yay!), but now I have two entries for the game in EmulationStation (boo!).
                  • FollyF
                    @JimmyFromTheBay said in retroarch/lr-hatari loads a particular hatari.cfg while starting:
                    You can put your real game in some subdirectory then it's not listed together with the configfile.
                    Remember you have to change the location of the .st file in the configfile.
                    • FollyF
                      @JimmyFromTheBay
                      I found some new stuff.
                      Seems the regular lr-hatari binary of RetroPie has a few problems :
                      • drive B isn't recognised
                      • no sliders in gui when selecting a file/directory
                      So I tried to install the source one from the module-script.
                      Sadly, the module-script seems broken, it can't retrieve some files.
                      (edit: solved for some computers : RetroPie-Setup needed to be up to date)
                      I compiled this one manually from here :
                      https://github.com/libretro/hatari
                      As root I replaced hatari_libretro.so in /opt/retropie/libretrocores/lr-hatari.
                      Now I have a this working :
                      • good drive B
                      • good sliders in gui when selecting a file/directory
                      I also found a way to select a different tos.img per game.
                      It's actually quite straight forward once you have discovered it.
                      Because it's a libretro-core it works trough RetroArch therefor the tos.img is hardcoded.
                      That is why it doesn't work with the normal lr-hatari configfile.
                      But we can use different approach using directories and putting the tos.img in these different directories.
                      For example, like this :
                      BIOS/tos.img (standard)
                      BIOS/tos206/tos.img (1.04)
                      BIOS/tos206/tos.img (2.06)
                      BIOS/tos400/tos.img (4.00)
                      etc
                      But how do we load, well the standard retroarch.cfg contains a line with the directory where to find the tos.img, like this :
                      system_directory = "/home/pi/RetroPie/BIOS
                      If we overrule that with a game-specific retroarch.cfg file an other tos-img is loaded.
                      So for supa_zazai_da!_[no_publisher] I created a game specific retroarch file as test called supa_zazai_da!_[no_publisher].cfg.st.cfg containing only :
                      ( or supa_zazai_da!_[no_publisher].st.cfg when starting the .st disk directly in lr-hatari )
                      system_directory = "/home/pi/RetroPie/BIOS/tos206
                      So for the few files that need something different we can use this approach.
                        @Folly said in retroarch/lr-hatari loads a particular hatari.cfg while starting:
                        That's odd. I put the gamefile in a subfolder called "files", changed the address in the config file, and the game still starts booting up and displays the intro, but then crashes with bomb symbols before it starts.
                        • FollyF
                          @JimmyFromTheBay
                          That's very odd indeed.
                          Bombs you say, does it pick the wrong tos.img ?
                            @Folly Ah, yes it does, it's gone back to the default TOS.
                            • FollyF
                              @JimmyFromTheBay
                              That is the problem I described earlier.
                              The location of the tos.img is "hardcoded".
                              It only works once when you are within the gui of lr-hatari and doing a reset.
                              On next boot from emulationstation it will revert back to the default even if a different tos.img is in the config file.
                              So replace the tos.img with version 206, named tos.img in /BIOS
                              Or you can make a game-specific retroarch config for the game.
                              Look again in post 9.
                              Btw.
                              I updated the RetroPie-Setup, now the source install is ok.
                              • FollyF
                                @JimmyFromTheBay
                                Now I am not sure what all is useful with the game-specific lr-hatari configfile.
                                I just tested putting 2 disk in there like this :
                                szDiskAZipPath =
                                szDiskAFileName = /home/pi/RetroPie/roms/atarist/Arkanoid (1987)(Taito).stx
                                szDiskBZipPath =
                                szDiskBFileName = /home/pi/RetroPie/roms/atarist/Afterburner (1988)(Activision).st
                                That works, so that's nice to know.
                                With Arkanoid I could not play the game, seems it works with the mouse and pressing 1 to start.
                                The mouse only works with tos 1.00, I used the US version creating a game-specific retroarch file to fix this (Arkanoid (1987)(Taito).stx.cfg) :
                                system_directory = "/home/pi/RetroPie/BIOS/tos100us
                                Some disks like this one don't auto-start.
                                I found that if you create an AUTO directory on the disk and copy/move the executable to the AUTO directory it will auto-boot.
                                I think you can edit this only with the standalone hatari, after that you can use it in lr-hatari again.
                                Sadly for Arkanoid it breaks mouse control but for Super Zazai Da! you can use this solution.
                                  I must admit I got a bit lost after the .cfg.st.cfg suffix :D
                                  So if I update lr-hatari from source now through the Retropie Setup menu it'll be the fixed version?
                                  • FollyF
                                    I had some laughter after that sentence of yours ;-)
                                    Well for now I don't use the lr-hatari configfile anymore, seems I can do without it for most games.
                                    And if I want to zoom or use a different tos.img I make a retroarch game-specific config now.
                                    ( only with .st.cfg, which is indeed less confusing :D )
                                    First update RetroPie-Setup.
                                    After that you can istall lr-hatari from source.
                                    It's indeed a better version.
                                      Done.
                                      Boo :(
                                      Log:
                                      Log started at: Tue 18 Oct 14:29:33 BST 2022
                                      RetroPie-Setup version: 4.7.11 (6598a90a)
                                      System: rpi4 (armv7l) - Raspbian GNU/Linux 10 (buster) - Linux retropie 5.4.72-v7l+ #1356 SMP Thu Oct 22 13:57:51 BST 2020 armv7l GNU/Linux
                                      Installing dependencies for 'lr-hatari' : Atari emulator - Hatari port for libretro
                                      /home/pi/RetroPie-Setup/tmp/build/lr-hatari /home/pi
                                      Getting sources for 'lr-hatari' : Atari emulator - Hatari port for libretro
                                      git clone --recursive --depth 1 --branch master "https://github.com/libretro/hatari.git" "/home/pi/RetroPie-Setup/tmp/build/lr-hatari"
                                      Cloning into '/home/pi/RetroPie-Setup/tmp/build/lr-hatari'...
                                      HEAD is now in branch 'master' at commit '1ebf0a0488580ef95c0b28f02223b31813c867c5'
                                      patching file Makefile.libretro
                                      Hunk #1 succeeded at 235 (offset 10 lines).
                                      patching file src/floppy_ipf.c
                                      Successfully applied patch: /home/pi/RetroPie-Setup/scriptmodules/libretrocores/lr-hatari/01_libcapsimage.diff
                                      Downloading https://files.retropie.org.uk/archives/spsdeclib_5.1_source.zip to /tmp/tmp.7gCPOd0XGj/spsdeclib_5.1_source.zip ...
                                        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                        0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                                      100  275k  100  275k    0     0  1473k      0 --:--:-- --:--:-- --:--:-- 1473k
                                      Archive:  /tmp/tmp.7gCPOd0XGj/spsdeclib_5.1_source.zip
                                        inflating: /home/pi/RetroPie-Setup/tmp/build/lr-hatari/capsimg_source_linux_macosx.zip
                                        inflating: /home/pi/RetroPie-Setup/tmp/build/lr-hatari/capsimg_source_windows.zip
                                        inflating: /home/pi/RetroPie-Setup/tmp/build/lr-hatari/DONATIONS.txt
                                        inflating: /home/pi/RetroPie-Setup/tmp/build/lr-hatari/HISTORY.txt
                                        inflating: /home/pi/RetroPie-Setup/tmp/build/lr-hatari/LICENCE.txt
                                        inflating: /home/pi/RetroPie-Setup/tmp/build/lr-hatari/RELEASE.txt
                                      Archive:  capsimg_source_linux_macosx.zip
                                         creating: capsimg_source_linux_macosx/
                                         creating: capsimg_source_linux_macosx/CAPSImg/
                                        inflating: capsimg_source_linux_macosx/CAPSImg/bootstrap.sh
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsAPI.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsCore.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsFDCEmulator.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsFDCEmulator.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsFile.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsFile.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsFormatMFM.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsFormatMFM.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsImage.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsImage.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsImageStd.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsImageStd.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CAPSImg.aps
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CAPSImg.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CAPSImg.rc
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CAPSImg.vcxproj
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CAPSImg.vcxproj.filters
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CAPSImg.vcxproj.user
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsLoader.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/CapsLoader.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/config.guess
                                        inflating: capsimg_source_linux_macosx/CAPSImg/config.h.in
                                        inflating: capsimg_source_linux_macosx/CAPSImg/config.sub
                                        inflating: capsimg_source_linux_macosx/CAPSImg/configure
                                        inflating: capsimg_source_linux_macosx/CAPSImg/configure.in
                                         creating: capsimg_source_linux_macosx/CAPSImg/Debug/
                                        inflating: capsimg_source_linux_macosx/CAPSImg/Debug/CAPSImg.log
                                         creating: capsimg_source_linux_macosx/CAPSImg/Debug/CAPSImg.tlog/
                                        inflating: capsimg_source_linux_macosx/CAPSImg/DiskImage.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/DiskImage.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/DiskImageFactory.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/DiskImageFactory.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/dllmain.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/install-sh
                                        inflating: capsimg_source_linux_macosx/CAPSImg/libcapsimage.map
                                        inflating: capsimg_source_linux_macosx/CAPSImg/LICENSE
                                        inflating: capsimg_source_linux_macosx/CAPSImg/Makefile.in
                                         creating: capsimg_source_linux_macosx/CAPSImg/Release/
                                        inflating: capsimg_source_linux_macosx/CAPSImg/Release/CAPSImg.log
                                         creating: capsimg_source_linux_macosx/CAPSImg/Release/CAPSImg.tlog/
                                        inflating: capsimg_source_linux_macosx/CAPSImg/resource.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/stdafx.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/stdafx.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/StreamCueImage.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/StreamCueImage.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/StreamImage.cpp
                                        inflating: capsimg_source_linux_macosx/CAPSImg/StreamImage.h
                                        inflating: capsimg_source_linux_macosx/CAPSImg/targetver.h
                                         creating: capsimg_source_linux_macosx/CAPSImg/x64/
                                         creating: capsimg_source_linux_macosx/CAPSImg/x64/Debug/
                                        inflating: capsimg_source_linux_macosx/CAPSImg/x64/Debug/CAPSImg.log
                                         creating: capsimg_source_linux_macosx/CAPSImg/x64/Debug/CAPSImg.tlog/
                                         creating: capsimg_source_linux_macosx/CAPSImg/x64/Release/
                                        inflating: capsimg_source_linux_macosx/CAPSImg/x64/Release/CAPSImg.log
                                         creating: capsimg_source_linux_macosx/CAPSImg/x64/Release/CAPSImg.tlog/
                                         creating: capsimg_source_linux_macosx/Codec/
                                        inflating: capsimg_source_linux_macosx/Codec/CapsDefinitions.h
                                        inflating: capsimg_source_linux_macosx/Codec/CTRawCodec.cpp
                                        inflating: capsimg_source_linux_macosx/Codec/CTRawCodec.h
                                        inflating: capsimg_source_linux_macosx/Codec/CTRawCodecDecompressor.cpp
                                        inflating: capsimg_source_linux_macosx/Codec/DiskEncoding.cpp
                                        inflating: capsimg_source_linux_macosx/Codec/DiskEncoding.h
                                         creating: capsimg_source_linux_macosx/Compatibility/
                                        inflating: capsimg_source_linux_macosx/Compatibility/dirent.h
                                         creating: capsimg_source_linux_macosx/Core/
                                        inflating: capsimg_source_linux_macosx/Core/BaseFile.cpp
                                        inflating: capsimg_source_linux_macosx/Core/BaseFile.h
                                        inflating: capsimg_source_linux_macosx/Core/BitBuffer.cpp
                                        inflating: capsimg_source_linux_macosx/Core/BitBuffer.h
                                        inflating: capsimg_source_linux_macosx/Core/CommonTypes.h
                                        inflating: capsimg_source_linux_macosx/Core/CRC.cpp
                                        inflating: capsimg_source_linux_macosx/Core/CRC.h
                                        inflating: capsimg_source_linux_macosx/Core/DiskFile.cpp
                                        inflating: capsimg_source_linux_macosx/Core/DiskFile.h
                                        inflating: capsimg_source_linux_macosx/Core/MemoryFile.cpp
                                        inflating: capsimg_source_linux_macosx/Core/MemoryFile.h
                                         creating: capsimg_source_linux_macosx/Debug/
                                         creating: capsimg_source_linux_macosx/Device/
                                        inflating: capsimg_source_linux_macosx/Device/C2Comm.h
                                         creating: capsimg_source_linux_macosx/LibIPF/
                                        inflating: capsimg_source_linux_macosx/LibIPF/CapsAPI.h
                                        inflating: capsimg_source_linux_macosx/LibIPF/CapsFDC.h
                                        inflating: capsimg_source_linux_macosx/LibIPF/CapsForm.h
                                        inflating: capsimg_source_linux_macosx/LibIPF/CapsLib.h
                                        inflating: capsimg_source_linux_macosx/LibIPF/CapsLibAll.h
                                        inflating: capsimg_source_linux_macosx/LibIPF/CapsLibVersion.h
                                        inflating: capsimg_source_linux_macosx/LibIPF/ComLib.h
                                         creating: capsimg_source_linux_macosx/Release/
                                         creating: capsimg_source_linux_macosx/x64/
                                         creating: capsimg_source_linux_macosx/x64/Debug/
                                         creating: capsimg_source_linux_macosx/x64/Release/
                                        inflating: capsimg_source_linux_macosx/SPStudio_Dev.sln
                                      /home/pi
                                      Building 'lr-hatari' : Atari emulator - Hatari port for libretro
                                      checking build system type... armv7l-unknown-linux-gnueabihf
                                      checking host system type... armv7l-unknown-linux-gnueabihf
                                      checking for gcc... gcc
                                      checking whether the C compiler works... yes
                                      checking for C compiler default output file name... a.out
                                      checking for suffix of executables...
                                      checking whether we are cross compiling... no
                                      checking for suffix of object files... o
                                      checking whether we are using the GNU C compiler... yes
                                      checking whether gcc accepts -g... yes
                                      checking for gcc option to accept ISO C89... none needed
                                      checking for g++... g++
                                      checking whether we are using the GNU C++ compiler... yes
                                      checking whether g++ accepts -g... yes
                                      checking for a BSD-compatible install... /usr/bin/install -c
                                      checking for tar... tar
                                      checking for sfd... no
                                      checking for fd2inline... no
                                      checking for autodoc... no
                                      checking how to run the C preprocessor... gcc -E
                                      checking for grep that handles long lines and -e... /bin/grep
                                      checking for egrep... /bin/grep -E
                                      checking for ANSI C header files... yes
                                      checking for sys/types.h... yes
                                      checking for sys/stat.h... yes
                                      checking for stdlib.h... yes
                                      checking for string.h... yes
                                      checking for memory.h... yes
                                      checking for strings.h... yes
                                      checking for inttypes.h... yes
                                      checking for stdint.h... yes
                                      checking for unistd.h... yes
                                      checking whether byte ordering is bigendian... no
                                      configure: creating ./config.status
                                      config.status: creating Makefile
                                      config.status: creating config.h
                                      rm -f libcapsimage.so.5.1 ../Codec/CTRawCodec.o ../Codec/CTRawCodecDecompressor.o ../Codec/DiskEncoding.o ../Core/BaseFile.o ../Core/BitBuffer.o ../Core/CRC.o ../Core/DiskFile.o ../Core/MemoryFile.o CapsAPI.o CapsFDCEmulator.o CapsFile.o CapsFormatMFM.o CapsImage.o CapsImageStd.o CapsLoader.o DiskImage.o DiskImageFactory.o stdafx.o StreamCueImage.o StreamImage.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c ../Codec/CTRawCodec.cpp -o ../Codec/CTRawCodec.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c ../Codec/CTRawCodecDecompressor.cpp -o ../Codec/CTRawCodecDecompressor.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c ../Codec/DiskEncoding.cpp -o ../Codec/DiskEncoding.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c ../Core/BaseFile.cpp -o ../Core/BaseFile.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c ../Core/BitBuffer.cpp -o ../Core/BitBuffer.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c ../Core/CRC.cpp -o ../Core/CRC.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c ../Core/DiskFile.cpp -o ../Core/DiskFile.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c ../Core/MemoryFile.cpp -o ../Core/MemoryFile.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c CapsAPI.cpp -o CapsAPI.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c CapsFDCEmulator.cpp -o CapsFDCEmulator.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c CapsFile.cpp -o CapsFile.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c CapsFormatMFM.cpp -o CapsFormatMFM.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c CapsImage.cpp -o CapsImage.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c CapsImageStd.cpp -o CapsImageStd.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c CapsLoader.cpp -o CapsLoader.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c DiskImage.cpp -o DiskImage.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c DiskImageFactory.cpp -o DiskImageFactory.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c stdafx.cpp -o stdafx.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c StreamCueImage.cpp -o StreamCueImage.o
                                      g++ -Wall -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -g -O2 -fomit-frame-pointer -fconserve-space -fno-exceptions -fno-rtti -std=c++11  -I./../LibIPF -I./../Codec -I./../Core -I./../Device -I. -fPIC -c StreamImage.cpp -o StreamImage.o
                                      g++ -shared -Wl,-soname,libcapsimage.so.5 -Wl,--version-script,libcapsimage.map -fPIC ../Codec/CTRawCodec.o ../Codec/CTRawCodecDecompressor.o ../Codec/DiskEncoding.o ../Core/BaseFile.o ../Core/BitBuffer.o ../Core/CRC.o ../Core/DiskFile.o ../Core/MemoryFile.o CapsAPI.o CapsFDCEmulator.o CapsFile.o CapsFormatMFM.o CapsImage.o CapsImageStd.o CapsLoader.o DiskImage.o DiskImageFactory.o stdafx.o StreamCueImage.o StreamImage.o  -o libcapsimage.so.5.1
                                      install -d /home/pi/RetroPie-Setup/tmp/build/lr-hatari/lib
                                      install libcapsimage.so.5.1 /home/pi/RetroPie-Setup/tmp/build/lr-hatari/lib/libcapsimage.so.5.1
                                      cc  -mcpu=cortex-a72 -mfpu=neon-fp-armv8 -O2 -D__cdecl='' -DHAVE_CAPSIMAGE=1 -DCAPSIMAGE_VERSION=5 -DGIT_VERSION=\"" 1ebf0a0"\" -funroll-loops -ffast-math -fomit-frame-pointer -O3 -fsigned-char -D__LIBRETRO__ -fno-builtin -fPIC -DLSB_FIRST -DALIGN_DWORD -I./src -I./src/uae-cpu -I./src/falcon -I./src/includes -I./src/debug -I./src -I./libretro -I./libretro/libretro-common/include -I./libretro/libretro-common/include/compat/zlib -I./libretro/include -I./libretro/utils -I./libretro/uae-cpu-pregen -c -o libretro/uae-cpu-pregen/cpudefs.o libretro/uae-cpu-pregen/cpudefs.c
                                      cc  -mcpu=cortex-a72 -mfpu=neon-fp-armv8 -O2 -D__cdecl='' -DHAVE_CAPSIMAGE=1 -DCAPSIMAGE_VERSION=5 -DGIT_VERSION=\"" 1ebf0a0"\" -funroll-loops -ffast-math -fomit-frame-pointer -O3 -fsigned-char -D__LIBRETRO__ -fno-builtin -fPIC -DLSB_FIRST -DALIGN_DWORD -I./src -I./src/uae-cpu -I./src/falcon -I./src/includes -I./src/debug -I./src -I./libretro -I./libretro/libretro-common/include -I./libretro/libretro-common/include/compat/zlib -I./libretro/include -I./libretro/utils -I./libretro/uae-cpu-pregen -c -o libretro/uae-cpu-pregen/cpuemu.o libretro/uae-cpu-pregen/cpuemu.c
                                      cc  -mcpu=cortex-a72 -mfpu=neon-fp-armv8 -O2 -D__cdecl='' -DHAVE_CAPSIMAGE=1 -DCAPSIMAGE_VERSION=5 -DGIT_VERSION=\"" 1ebf0a0"\" -funroll-loops -ffast-math -fomit-frame-pointer -O3 -fsigned-char -D__LIBRETRO__ -fno-builtin -fPIC -DLSB_FIRST -DALIGN_DWORD -I./src -I./src/uae-cpu -I./src/falcon -I./src/includes -I./src/debug -I./src -I./libretro -I./libretro/libretro-common/include -I./libretro/libretro-common/include/compat/zlib -I./libretro/include -I./libretro/utils -I./libretro/uae-cpu-pregen -c -o libretro/uae-cpu-pregen/cpustbl.o libretro/uae-cpu-pregen/cpustbl.c
                                      cc  -mcpu=cortex-a72 -mfpu=neon-fp-armv8 -O2 -D__cdecl='' -DHAVE_CAPSIMAGE=1 -DCAPSIMAGE_VERSION=5 -DGIT_VERSION=\"" 1ebf0a0"\" -funroll-loops -ffast-math -fomit-frame-pointer -O3 -fsigned-char -D__LIBRETRO__ -fno-builtin -fPIC -DLSB_FIRST -DALIGN_DWORD -I./src -I./src/uae-cpu -I./src/falcon -I./src/includes -I./src/debug -I./src -I./libretro -I./libretro/libretro-common/include -I./libretro/libretro-common/include/compat/zlib -I./libretro/include -I./libretro/utils -I./libretro/uae-cpu-pregen -c -o src/uae-cpu/hatari-glue.o src/uae-cpu/hatari-glue.c
                                      cc  -mcpu=cortex-a72 -mfpu=neon-fp-armv8 -O2 -D__cdecl='' -DHAVE_CAPSIMAGE=1 -DCAPSIMAGE_VERSION=5 -DGIT_VERSION=\"" 1ebf0a0"\" -funroll-loops -ffast-math -fomit-frame-pointer -O3 -fsigned-char -D__LIBRETRO__ -fno-builtin -fPIC -DLSB_FIRST -DALIGN_DWORD -I./src -I./src/uae-cpu -I./src/falcon -I./src/includes -I./src/debug -I./src -I./libretro -I./libretro/libretro-common/include -I./libretro/libretro-common/include/compat/zlib -I./libretro/include -I./libretro/utils -I./libretro/uae-cpu-pregen -c -o src/uae-cpu/memory.o src/uae-cpu/memory.c
                                      cc  -mcpu=cortex-a72 -mfpu=neon-fp-armv8 -O2 -D__cdecl='' -DHAVE_CAPSIMAGE=1 -DCAPSIMAGE_VERSION=5 -DGIT_VERSION=\"" 1ebf0a0"\" -funroll-loops -ffast-math -fomit-frame-pointer -O3 -fsigned-char -D__LIBRETRO__ -fno-builtin -fPIC -DLSB_FIRST -DALIGN_DWORD -I./src -I./src/uae-cpu -I./src/falcon -I./src/includes -I./src/debug -I./src -I./libretro -I./libretro/libretro-common/include -I./libretro/libretro-common/include/compat/zlib -I./libretro/include -I./libretro/utils -I./libretro/uae-cpu-pregen -c -o src/uae-cpu/newcpu.o src/uae-cpu/newcpu.c
                                      src/uae-cpu/newcpu.c:170:10: fatal error: CapsLibAll.h: No such file or directory
                                       #include <CapsLibAll.h>
                                      compilation terminated.
                                      make: *** [Makefile.libretro:242: src/uae-cpu/newcpu.o] Error 1
                                      make: *** Waiting for unfinished jobs....
                                      Could not successfully build lr-hatari - Atari emulator - Hatari port for libretro (/home/pi/RetroPie-Setup/tmp/build/lr-hatari/hatari_libretro.so not found).
                                      /home/pi
                                      Log ended at: Tue 18 Oct 14:31:22 BST 2022
                                      Total running time: 0 hours, 1 mins, 49 secs
                                      • FollyF
                                        @JimmyFromTheBay
                                        I see the same error I had before.
                                        It can't find the header files for of capsimg.
                                        This package is for supporting .ipf protected disk format in lr-hatari.
                                        You logfile contains a version of an older RetroPie-Setup :
                                        Check again if the update of RetroPie-Setup works.
                                        You see the latest version when you start RetroPie-Setup ?
                                        Try to update again in the RetroPie-Setup.
                                        If the update keeps failing somehow you should backup your old RetroPie-Setup folder and clone RetroPie-Setup from GitHub again.
                                        cd
                                        git clone --depth=1 https://github.com/RetroPie/RetroPie-Setup.git
                                        Then place your 3rd party module-scripts back in the correct place.
                                          @Folly Ah yes, for some reason it keeps fetching and installing 4.7.11. Tried again just now and it did the same thing. Will see if I can fix it up.
                                          • FollyF
                                            @JimmyFromTheBay
                                            I think updating is always a problem when using 3rd party module-scripts, that is probably the reason.
                                            Not sure if there is a good fix for this.
                                            I suggest you do it like I described earlier.
                                            Perhaps putting all 3rd party module-script in the RetroPie-Setup/ext directory like this :
                                            /home/pi/RetroPie-Setup/ext/<3rd-party-repository-name>/scriptmodules/<supplementary|emulators|etc>
                                            will make updating easier just cutting and pasting only the ext directory in the new RetroPie-Setup.
