    Problem connecting a bluetooth ps3 controller
    ps3bluetoothcontroller
    25 Posts 2 Posters 10.3k Views
      mitu Global Moderator @messy
      @messy What error message ?
        messy
        "PS3 driver temporarily interrupted in order to allow compatibility with standard BT peripherals. Please repair duel shock to continue or disregard"
          As explained, that's not an error message.
            messy
            ok, its not an error, but where it says "PS3 driver temporarily interupted" - does that mean it was just a blip and is now fine again? Or does it mean its been temporarily disabled in order to allow a generic device to work correctly?
              messy
              I GOT IT WORKING!!!
              Good Grief.....in the end I used the PS3 driver and what made ti work was, just after registering the device a window pops up saying you can now unplug your cable.
              At this point, I unplugged and paired the controller and THEN with the keyboard moved back to the main menu to configure it.
              Trying to pair the device at ANY other point during the process and it doesnt like it.
              Have rebooted and the device still conect and works so it seems stable :D
              Cheers for the help.
