    Issues installing Quake
    quakequake3documentation
    20 Posts 7 Posters 1.8k Views
    • Z
      Zup
      Hi
      I've been installing Quake and Quake 3 on Retropie 4.6, following the docs on Retropie page. So far, I've encountered this issues:
      • There is no information about how to install mod packages.
      • There is no music. I'm using lr-tyrquake, and the music (ogg files) is placed following the guide.
      • Quake 3 has no documentation page, and is not included on Quake page.
      • It should be noted that quake 3 files changed location from previous releases, and they are placed on /home/pi/Retropie/rom/ports/quake3 now.
      • I've been unable to make Team Arena work. On some posts they say that the files must be placed at /home/pi/Retropie/rom/ports/teamarena but it doesn't work. What files and where should they be placed? (It is stated that the files are pak0.pk3, pak1.pk3, pak2.pk3 and pak3.pk3 but the Steam release only inclues pak0.pk3).
      • It should be noted that Quake stores its key on /home/pi/.q3a/baseq3/q3key but I don't know if it could be included elsewhere (i.e.: at the same place at Q3 files) and make the quake3 installation script put it on the right place (so it can be auto loaded from USB).
      Thanks in advance.
        ReadyPlayaWon Banned @Zup
        @Zup
        Not a really a solution as such ... but an alternative option if you wanna play Quake and Quake 3 Arena on Retropie (i'm using a Raspberry Pi 4)
        Quake 1 PC Homebrew Port to PSP ... runs perfect in either lr-ppsspp or PPSSPP Standalone Emulator(s)
        Quake 3 Arena ... Dreamcast version runs perfect in Redream
        Both cases just require downloading the *.ISO and placing into the appropriate system folder ... and you're done. No setup, annoying configs or scripts ... just enjoy playing the game.
        • Z
          Zering @ReadyPlayaWon
          @ReadyPlayaWon The controls for Quake 3 on Dreamcast are pretty bad.
            ReadyPlayaWon Banned @Zering
            @Zering said in Issues installing Quake:
            Well, at least a can play a version of Quake 3 Arena ... unlike the OP, that can't :P
            What's your advice for the OP to solve his problem ? Got Any ? or just Criticisms of the Dreamcast port ?
            Z 1 Reply Last reply Reply Quote -1
            • Z
              @ReadyPlayaWon There's no need for that, I was only making an observation.
                That's your negative opinion and criticism ... and there's no need for that.
                • Z
                  @ReadyPlayaWon Well excuse me for having an opinion ; here I thought I was entitled to one.
                  For my money, I would bet that OP's problem stems from the Steam version. I didn't touch my Quake 3 installation since last year, but I recall the GOG version having the necessary files and it working pretty much out of the 'box'. I'll check later today.
                    yeah, you do sound entitled ... by trashing someone else's suggestions.
                    only yours matters right ?
                    BuZzB 1 Reply Last reply Reply Quote -1
                    • Z
                      Zup
                      Sorry, but Quake 3 DOES work (base files) if installed pk3 files are installed on /home/pi/Retropie/rom/ports/quake3. My issues with Quake 3 are that only the base game is working (no Team Arena) and that files locations is not documented on Quake documentation page.
                        BuZz administrators @ReadyPlayaWon
                        @ReadyPlayaWon Enough of the attitude please.
                        • Z
                          Zering @Zup
                          @Zup I'm looking into Team Arena now.
                          I had music issues when I got Quake running earlier this year, but I don't recall why exactly.
                          Not trying to be pedantic but could you share your directory structure for quake? It may be a simple thing that you've overlooked.
                          Edit : I take it you followed this tutorial for Team Arena?
                          Edit 2 : Team Arena would not be documented as it's not supported by any 'official' RetroPie package.
                          • Z
                            Zup
                            @Zering My directories Quake are:
                            quake
                            quake/dopa
                            quake/hipnotic
                            quake/hipnotic/music
                            quake/rogue
                            quake/rogue/music
                            quake/id1
                            quake/id1/music
                            (parent is ~/RetroPie/roms/ports)
                            In Quake 3, I follow this structure:
                            ~/RetroPie/roms/ports/quake3
                            ~/RetroPie/roms/ports/teamarena
                            I can't see the tutorial you linked, but in other tutorials said that I must use the files pak0.pk3, pak1.pk3, pak2.pk3 and pak3.pk3... but Steam only includes pak0.pk3 for Team Arena.
                              ReadyPlayaWon Banned @BuZz
                              @BuZz said in Issues installing Quake:
                              Zering started it .. where's his [removed] warning ?
                              1 Reply Last reply Reply Quote -2
                              • Z
                                Zering @Zup
                                @Zup Try my link again, I just corrected an error.
                                The tutorial in the link says that the GOG version works, and has all the files you need. I'm checking now but I have to redownload it and my computer is very slow.
                                I assumed your quake/id1/music directory contains track02.ogg through to track11.ogg?
                                This is the guide I used when I encountered the same issue, maybe it will help you.
                                • Z
                                  Zup @Zering
                                  @Zering I think I've solved the issue with Team Arena... the Steam release is not up to date. It contains only the pak0.pk3 file, while pak1 through 3 were aded on a later patch.
                                  I've downloaded the patch, applied it and copied the files to the Raspberry. Team Arena is running fine now.
                                  Z 1 Reply Last reply Reply Quote 1
                                  • Z
                                    Zering @Zup
                                    @Zup Excellent! Did you make any headway with Quake 1's music?
                                      ReadyP1ayaW0n Banned
                                      @BuZz
                                      aaah didums .. i said a naughty word :(
                                      won't happen again ... until someone trash talks me and moderators take their side.
                                      mituM 1 Reply Last reply Reply Quote -2
                                        mitu Global Moderator @ReadyP1ayaW0n
                                        @ReadyP1ayaW0n said in Issues installing Quake:
                                        Actually it was I that banned your account for inappropriate language. It was a temporary ban, but I guess you haven't got the patience to wait until it expired.
                                          A Former User @mitu
                                          @mitu said in Issues installing Quake:
                                          I guess not .. lol :D
                                          • Z
                                            Zup
                                            Sorry, I got distracted installing Doom and Quake 2.
                                            After downloading a new set of ogg files, I've got the music working. It seem that my files were corrupted.
                                            Now, the only question is how to use mods in lr-tyrquake...
