    Sound issues since I connected two BT controllers
    audiovolume
    2 Posts 2 Posters 302 Views
      mxc0bbn
      It may not mean anything, but I wanted to mention it in case there was a relation.
      The bottom line is that before I connected the controllers I was getting sound out of the HDMI port when connecting the pi to a TV and I could still plug in a 3.5mm jack and get great sound out of it.
      At this point there is NO sound coming from the 3.5mm jack at all unless I FORCE it to use the jack and then it is very very low. My system volume is a 0 and won't stay when I change it and I've made a bunch of changes in the Emulation Station audio settings, but I never took the default settings down so I have no ide what they are.
      Can someone post what the default audio options are for ES on Retropie when it's first installed? I just want to get back to baseline and test from there.
      Thanks,
      Mike
        mitu Global Moderator @mxc0bbn
        @mxc0bbn Can you describe your setup, as indicated in https://retropie.org.uk/forum/topic/3/read-this-first
