    Retroarch audio problem (digital/I2S)
    retroarchaudiosounddigitali2s amp
    5 Posts 3 Posters 966 Views
    • Y
      yoc1983
      I am using a speaker connected through an amp to the I2S for sound (Pi 4).
      sound works well except in retroarch games
      it give an echo/delay effect
      i updated retroarch but it didn't solved it.
      i tried to look for downgrade but didn't managed to find how to do it.
      i know for the same hardware with the old retroarch it was working good.
        mitu Global Moderator @yoc1983
        Add a few more details about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        Do you have any configuration in RetroArch specifically for the soundcard or does it use the system (default) audio configuration ? How did you configure the I2S audio on the Raspberry Pi ?
        Y 1 Reply Last reply Reply Quote 0
        • themazingnessT
          themazingness
          It seems to keep forgetting to detect if you have speakers or headphones hooked up in 4.7.1. I have to keep going back into RetroPie Setup to change the audio settings to headphones. I suspect that might be the same thing here.
          • Y
            yoc1983 @mitu
            hi
            configuration in RetroArch, audio device set to alsa
            i configure the I2S according to the adafruit documentation:
            https://learn.adafruit.com/adafruit-max98357-i2s-class-d-mono-amp/raspberry-pi-usage
            so just running this curl noted on this link
            if it's matters i see a massage in the background when the system goes from
            the GUI to the linux configurations:
            'ALSA lib pcm.c:8424:(snd_pcm_recover) underrun occurred'
            i also tried to remove retroarch and install again
            didn't solved it
            Pi Model : 4
            Power Supply used: officel (3A)
            RetroPie Version Used : 4.6.8
            Built From: Pre made Image, Wolfanoz Raspberry Pi 4 Supreme Pro
            Emulator: retroarch
            How to replicate the problem:
            install Wolfanoz Raspberry Pi 4 Supreme Pro
            configure and connect digital audio device
            run retroarch emulator
              @yoc1983 said in Retroarch audio problem (digital/I2S):
              We don't support 3rd party images - use the image from retropie.org.uk/download if you want support here.
