Bezel Project - ColecoVision - System Generic bezels only
Hey all, Pulling my hair out, hoping someone else has had this problem and fixed it. No matter what I do, I am only getting generic ColecoVision system bezels. All other 15 Emulators are working great.
- Yes, I am using lr-bluemsx
- Yes, I am using no-intro romsets
- Yes, I have verified that everything is named the same
I have even:
- Deleted and recopied the ROMS
- Rescraped and generated new gamelist.xml
- Uninstalled lr-bluemsx
- deleted all config files from \retropie\configs\coleco
- reinstalled lr-bluemsx from source
- disabled all overlays and re-enabled them from Bezel Project menu
- Manually disabled and re-enabled ColecoVision bezel pack from Bezel Project menu
- Rebooted ;)
Not sure where else to look. Is there just another config file I am missing that has something stuck in it? At least there aren't a gazillion ROMS, but I really don't want to manually change each one. (although, I could have by now - haha)
Thanks!
Run a Coleco game with verbose logging enable, then check
/dev/shm/runcommand.log
to see where RetroArch looks for each game's.cfg
