    NAOMI CONTROLS PROBLEM
    retropienaomicrazy taxi
    17 Posts 8 Posters 4.8k Views
      Codafire
      Pi Model: 4 4gb
      Power Supply used: 5v 3amp
      RetroPie Version Used 4.6.8
      Built From: Pre made SD Image from retropie official
      USB Devices connected: 1 gamepad
      Controller used: playstation 2 type gamepad
      Hi mates, i hope you all are ok in this days, im having a problem with some games from Naomi, i use lr-flycast to emulate naomi and atomiswave, but in some games from naomi like crazy taxi or 18 wheeler the controls are crazy, when you start the game its like the taxi was braking and accelerating at same time. The left down analog speed up, but not enought, but if you press left down analog and right left analog at same time its full speed, its like if you where playing in a simulator and using the foot to accelerate, X button freezes the game, and a lot of issues, any ideas? I try remapping all controls but do the same, the taxi starts like burning wheels, with accelerate and brake same time. Thanks for support.
      • Z
        Zering @Codafire
        @codafire I'm pretty sure the controls in those games are off because the arcade cabinets used steering wheels for input. You can play pretty much arcade perfect versions of both on the Dreamcast.
        sirhenrythe5thS C 2 Replies Last reply Reply Quote 0
        • sirhenrythe5thS
          sirhenrythe5th @Zering
          @zering i just saw a solution to remap the steering manually in RGUI, for "18 Wheeler" this concerns "Handle right" and "Handle left".
          I will try this on sunday when i am back home.
          RetroRatio: 1.91
          Started Games beaten: 2,40%
            Codafire @Zering
            @zering Yep i know in dreamcast works better but the file its heavier so thats im trying to make it work on Naomi version, we can wait until Sunday for sirhenry results hehehe
              barbudreadmon @Codafire
              @codafire while default mapping has a tendency to be all over the place for naomi games using lots of analog controls, it should be fine after you remap it to your tastes in Quick Menu > Controls.
                Codafire @barbudreadmon
                @barbudreadmon remapped and dont doing nothing, its like you need 2 buttons to speed up, try if you can crazy taxi for naomi and you understand what i said, i erase all buttons and make a clear configuration but not working.
                • sirhenrythe5thS
                  sirhenrythe5th @Codafire
                  @codafire i had great success by adding the clone "18whellu.zip" (1.3 MB) to the rom-folder and starting this one.
                  Controls are working and even this annoying "motor network error" of the parent romset "18wheeler.zip" does not appear.
                  I guess it is worth a try ;)
                  RetroRatio: 1.91
                  • DreamcastKidD
                    DreamcastKid Banned
                    @codafire said in NAOMI CONTROLS PROBLEM:
                    If you compress the Dreamcast version to .chd it only weighs 160MB
                      Codafire @DreamcastKid
                      @dreamcastkid redream supports chd?
                      Z DreamcastKidD 2 Replies Last reply Reply Quote 0
                      • Z
                        Zering @Codafire
                        @codafire Flypast does.
                          @dreamcastkid ypu use CHDMan or what program? Thanks!!!
                          • Z
                            Zering @Codafire
                            @codafire I don't use .chds myself for Dreamcast, but if I did I'd use either chdman or official mame chds.
                            • DreamcastKidD
                              DreamcastKid Banned @Codafire
                              Yes, it sure does ... lr-flycast too, plus many other emulators.
                              see the Retropie Dreamcast Wiki
                              https://retropie.org.uk/docs/Dreamcast/
                              • DreamcastKidD
                                i use CHDman 0.205 which is just an .exe file
                                along with a *.bat file in Windows which can convert a single game or batch compress an entire folder of games.
                                example: CUE or GDI to CHD.bat and the contents are ..
                                for /r %%i in (.cue, .gdi) do chdman createcd -i "%%i" -o "%%~ni.chd"
                                here's a download link (no viruses , clean) : http://www.mediafire.com/file/v1jz59nv723z69h/chdman.zip/file
                                  G30FF
                                  Redream and Flycast both support CHDs, as long as you create the CHD file using a .gdi, not a .cue (if you get a Redump version of any DC game it will have both).
                                  • H
                                    harmeetsingh0013 @sirhenrythe5th
                                    @sirhenrythe5th from where I find 18whellu.zip file? I am using XBox, does it work for that as well?
                                      mitu Global Moderator @harmeetsingh0013
                                      @harmeetsingh0013 You've bumped again a very old topic, even though I asked you not to. Also, per the forum rules - don't ask for ROMs. Come back when want to respect the forum's rules.
