    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 578.3k Views
      mediamogul Global Moderator
      This guide has since been revised and can be found at:
      https://github.com/RetroPie/RetroPie-Setup/wiki/Universal-Controller-Calibration-&-Mapping-Using-xboxdrv
      Of course, anyone can continue to ask questions and trade controller configurations here if need be.
      This guide will attempt to detail several advanced controller mappings suitable for just about any controller. The focus will be on the use of xboxdrv, as it is an extremely versatile tool that can handle almost any situation and is able to be installed directly from from the 'RetroPie Setup' menu. It's actually so versatile that it's difficult to list the many possibilities without it ending up as a dry and confusing information dump as seen in the software's man page here. Instead, what follows is a grouping of use case scenarios that would be of direct interest to RetroPie Users. New scenarios will be added from time to time. Some of these scenarios will include:
      • Keyboard mapping for emulators that don't support controllers natively
      • Mouse mapping to analog joysticks for full use of certain computer games as well as improved performance in ScummVM and Atari emulators
      • Mapping analog triggers as buttons for a faster response time (Commonly seen in the competitive Smash Bros community pre-WiiU)
      • Four-way directional input restriction for games like Pac-Man that suffer when diagonal control input is introduced
      • Correcting the inner and outer deadzones of analog sticks for finer control and to prevent drifting problems in overly-sensitive or well-worn controllers.
      • Configuring a toggle or utilizing unused buttons for auto-fire in any game or emulator
      • Correcting unruly analog trigger behavior found in some controllers
      (1) Mapping any controller to be read as a standard XBox360 controller.
      None of what is to follow can be accomplished without this first step. The sheer multitude of existing controllers and their loose implementation of "standards" presents a problem to computer software that has a limited definition of what to expect from controller input. Simply mapping a troublesome controller to be read as a standardized XBox360 controller can solve many communication problems without any additional tweaking. However, this same process can also be used to fine-tune a controller in much the same way that you might normally only find in Windows-based solutions.
      First, we need to make sure xboxdrv is installed. This can be done from the 'RetroPie Setup' listing in the 'RetroPie' menu of Emulation Station. Navigate from 'Setup / Tools' to 'xboxdrv - XBox / XBox360 gamepad driver'. From here, select 'Enable xboxdrv' and wait for it to finish. Once installed and enabled, a configuration will be added to /etc/rc.local. Since we will be adding our own custom configuration there later, this command should be removed by selecting 'Disable xboxdrv' from the same menu we enabled it from. With xboxdrv now installed, we now need to discover the core-level device input codes for each button and axis on the physical controller, so that we may then map them to the virtual XBox360 controller. To do this, drop down to the command line by pressing 'F4' on your keyboard, then type:
      cat /proc/bus/input/devices
      Press 'Enter' and look for the controller in the list of devices. It can be identified by it's name in the device groupings next to the line beginning with N: Name=. Once you find it, make a note of it's event number next to the line beginning with H: Handlers= . Next, we'll also need to make note of the event location by name for later use. To do that that, type:
      ls /dev/input/by-id/
      Press 'Enter' and your device should be listed here by name. In the event that you see multiple entries, look for the listing containing "event" in the title. If you find that your controller is not listed by name, you can substitute the event number when it comes time. Now let's move on to discovering the event codes for each button of the controller by typing:
      evtest /dev/input/event*
      Make sure to replace the star with the controllers event number, then press 'Enter'. Here you will see a printout of information regarding your controller. Wait for it to finish and you will be met with a message that reads, "Testing ... (interrupt to exit)". Now, when you press any button on your controller, a few lines of text will appear that make reference to the button's event BTN_ name. Make a note of it's name and repeat with each button until all the names are known. After that, press your left analog stick in the up direction and you will notice that it is given an ABS_ name. As up and down make the complete Y-Axis, both will have an identical name. The same goes for left and right that make up the X-Axis. After you note those two names, repeat the process for the right analog stick, as well as the directional pad. Depending on whether or not your controller has analog triggers, pressing them will either produce a BTN_ name or an ABS_ name. Also, you may find that your directional pad outputs a separate BTN_ name for each direction rather than ABS_ axis names. If your controller doesn't have any analog sticks or triggers, you will still be able to move forward using only the BTN_ codes.
      Now that we have all the event codes from the controller, we can begin mapping them to the virtual XBox360 controller in a command that will be added to /etc/rc.local so that it may launch along with RetroPie as it boots up. Below is a template that illustrates the command format. In essence, this command is simply mapping each of the event codes from the physical controller to the virtual XBox360 controller that xboxdrv will create. The specific information gathered from the steps above are marked with an asterisks. A legend for the virtual Xbox 360 controls can be found here.
      	--evdev /dev/input/by-id/* \
      	--silent \
      	--detach-kernel-driver \
      	--force-feedback \
      	--deadzone-trigger 15% \
      	--deadzone 4000 \
      	--mimic-xpad \
      	--evdev-absmap ABS_*=x1,ABS_*=y1,ABS_*=x2,ABS_*=y2,ABS_*=lt,ABS_*=rt,ABS_*=dpad_x,ABS_*=dpad_y \
      	--evdev-keymap BTN_*=a,BTN_*=b,BTN_*=x,BTN_*=y,BTN_*=lb,BTN_*=rb,BTN_*=tl,BTN_*=tr,BTN_*=guide,BTN_*=back,BTN_*=start \
      If the directional pad of your controller outputs individual BTN_ names instead of ABS_ axis names, the command is altered to accommodate as seen below. Notice the addition of --dpad-as-button as well as the inclusion of individual 'BTN_' assignments marked 'du,dd,dl&dr' under --evdev-keymap.
      	--silent \
      	--force-feedback \
      	--deadzone 4000 \
      	--mimic-xpad \
      	--dpad-as-button \
      	--evdev-absmap ABS_*=x1,ABS_*=y1,ABS_*=x2,ABS_*=y2,ABS_*=lt,ABS_*=rt \
      	--evdev-keymap BTN_*=a,BTN_*=b,BTN_*=x,BTN_*=y,BTN_*=lb,BTN_*=rb,BTN_*=tl,BTN_*=tr,BTN_*=guide,BTN_*=back,BTN_*=start,BTN_*=du,BTN_*=dd,BTN_*=dl,BTN_*=dr \
      If you're mapping a controller that doesn't have analog controls, or the full set of buttons found on an XBox360 controller, below is a SNES controller type example of how you would ignore those unused controls to prevent some software from trying to access them automatically. Here you will notice the addition of --dpad-only, which will ignore both sticks as well as the added argument for --ui-axismap and --ui-buttonmap where the voided buttons are defined. You can also use the --dpad-as-button argument and the accompanying -evdev-keymap direction buttons found in the example above if this controller also outputs it's Dpad as individual buttons.
      	--silent \
      	--force-feedback \
      	--deadzone 4000 \
      	--mimic-xpad \
      	--evdev-absmap ABS_*=dpad_x,ABS_*=dpad_y \
      	--evdev-keymap BTN_*=a,BTN_*=b,BTN_*=x,BTN_*=y,BTN_*=lb,BTN_*=rb,BTN_*=back,BTN_*=start \
      	--dpad-only \
      	--ui-axismap lt=void,rt=void
      	--ui-buttonmap tl=void,tr-void,guide=void \
      All that is really left is to add the command to /etc/rc.local. To do this type:
      sudo nano `/etc/rc.local`
      Press 'Enter" and paste the command into the file above "exit 0". Now press 'ctrl+o' to save the file, 'Enter' to confirm and 'ctrl+x' to exit. Seeing as how this command is run as the system boots up, you'll now need to reboot by typing:
      sudo reboot
      Press 'Enter' and wait for Emulation Station to load where you can then remap the controller which will now be seen as being no different from a standard XBox 360 wired Controller. If for some reason you should wish your controller to be seen as a wireless XBox360 controller, just change --mimic-xpad to --mimic-xpad-wireless in the configuration.
      (2) Fine tuning your controller.
      As mentioned in the first section, xboxdrv can also be used to fine-tune a controller's operation in ways that aren't often found in most Linux tools. This is very important when you have a controller that misbehaves in one way or another and would be unusable without proper calibration.
      • (2A) Analog control calibration
      You may have noticed that we've already done a bit of fine-tuning with "deadzones" in the three examples from section one. When a pressure-sensitive analog control is used, activity is reported from the controller. The problem is that many controllers, both new and old, sometimes report applied pressure when at rest. This can be due to an overly sensitive new controller or a worn out old controller. Setting a deadzone value specifies that a certain amount of pressure be applied before any activity is reported. This prevents drifting and unwanted character movement. The applied values from the examples above are recommended in the xboxdrv manual, but naturally adjustments can be made when needed.
      To further adjust the accuracy of your analog controls, you can also set the minimum and maximum range of the X and Y axis of your triggers and sticks. This becomes very important to get the full range of movement from your controller, that might otherwise be hindered in some way. One example is the gate surrounding an analog stick sometimes prohibits the maximum outside movement of a joystick causing, among other things, Emulation Station to not register an up, down, left or right movement, preventing a successful map. To calibrate your analog controls we'll first need to make note of the minimum, maximum and center positions using jstest. To do this, drop down to the command line by pressing 'F4'. If your controller has an xboxdrv configuration applied to it you'll first need to type:
      sudo killall xboxdrv
      Press 'Enter' and then we will need to determine which js* you controller is at. To do this, type:
      Press 'Enter' and look for the controller in the list of devices. It can be identified by it's name in the device groupings next to the line beginning with N: Name=. Once you find it, make a note of it's js* number next to the line beginning with H: Handlers= . After you know the js* number, you will then type:
      jstest /dev/input/js*
      Make sure to replace the star with your joystick's number and press 'Enter'. You should now see the joystick testing interface. Starting with the left joystick, slowly push in the left direction until it will not move anymore. You should see numerical onscreen feedback representing the absolute minimum X-axis value. Make a note of that value and release the joystick completely. At this point, make a note of the absolute center X-axis numerical value. Then, slowly push in the right direction until it will not move anymore and make note of the absolute maximum X-axis numerical value. Repeat that process moving slowly from top, center to bottom of the Y-axis, making notes of each value. When completed, you will then repeat the entire process on the right joystick. This process can also be applied to your analog triggers as well if needed. Once of of the values are known for your analog controls, you will add them to your xboxdrv configuration formatted as: --calibration AXIS=MIN:CENTER:MAX. Using the base configuration example from the first section, it would look like this in practice:
      	--silent \
      	--force-feedback \
      	--deadzone 4000 \
      	--calibration x1=MIN:CENTER:MAX,y1=MIN:CENTER:MAX,x2=MIN:CENTER:MAX,y2=MIN:CENTER:MAX \
      	--mimic-xpad \
      Once this is added, each of your joysticks will benefit from the absolute full range of movement possible allowing for much finer control. If your xboxdrv configuration is invoked in /etc/rc.local, you'll need to reboot your system to see the changes.
      • (2B) Converting analog triggers to digital
      This next one is a quick, easy and very effective for retro-gamers. Pressure sensitive analog triggers bring an extra level of realism and control to the few games that can make use of them, such as Mame racing games. However, most retro games and console emulation software don't really benefit from analog triggers and in some cases, they can slow response time and even prevent functionality altogether. For these reasons, it is generally suggested that analog triggers be converted to digital input in almost all cases. to do this, you would simply add --trigger-as-button to your xboxdrv configuration. Using the base configuration example from the first section, it would look like this in practice:
      	--silent \
      	--force-feedback \
      	--deadzone 4000 \
      	--trigger-as-button \
      	--mimic-xpad \
      Once added, the system will register any analog increase or decrease as an on/off digital button state. If your xboxdrv configuration is invoked in /etc/rc.local, you'll need to reboot your system to see the changes.
      • (2C) Personalizing your controller's ID name
      After fine-tuning your controller, you may want to give it a personalized ID. Outside of the novelty, this technique can be used as a tool to separate identification of multiple identical controllers in some software that can otherwise get confused when identically named controllers are discovered. To do this, you would replace --mimic-xpad with --device-name "My Most Non-Non-Triumphant Controller Name Here". Using the base configuration example from the first section, it would look like this in practice:
      	--silent \
      	--force-feedback \
      	--deadzone 4000 \
      	--device-name "My Most Non-Non-Triumphant Controller Name Here" \
      Once added the entire system will identify the controller by the new name, so remapping will be necessary in Emulation Station. If your xboxdrv configuration is invoked in /etc/rc.local, you'll need to reboot your system to see the changes.
      • (2D) Restricting directional control to four ways
      When emulating classic video games, sometimes having a modern controller can work against you. Games like 'Burger Time' or the 'Pac-Man' series were only ever designed for 4-way directional control. This becomes a problem when using a controller with a free range of analog movement. When Pac-Man tries to turn a corner or Chef Peter Pepper tries to climb a ladder, a brief, but deadly pause often happens as a result of getting mixed directional input when the joystick hits a diagonal position. This can be eliminated in an xboxdrv control scheme by simply adding --four-way-restrictor. Using the base configuration example from the first section, it would look like this in practice:
      	--silent \
      	--force-feedback \
      	--deadzone 4000 \
      	--mimic-xpad \
      Once added, the games will perform just as fluidly as they did using their original joysticks.
      (3) Key-Mapping For Individual Emulators
      • (3A) Key-Mapping and Launch Fundamentals
      The foundation has been laid. Controller's have been fine-tuned. Now, we'll take a look at how to map keyboard keys and mouse movements to a controller's analog sticks and buttons for use in emulators that lack native controller support and how to launch and maintain multiple mappings accordingly. So far we have dealt with xboxdrv on a system level. This first step in facilitating program-specific key-mappings requires that xboxdrv be able to run at a user level. To do this, drop down to the command line by pressing 'F4' on your keyboard, then type:
      sudo nano /etc/udev/rules.d/55-permissions-uinput.rules
      Press 'Enter" and type the following:
      KERNEL=="uinput", MODE="0660", GROUP="users"
      sudo reboot
      Now that we've prepared xboxdrv to operate at a user level, we are ready to key-map our emulator. I've chosen to use ScummVM as an example because it's easy and it involves mapping both keyboard keys to buttons and the mouse to the analog stick. Those who have tried using the internal joystick support in ScummVM know that it leaves much to be desired. The cursor movement is shakey and you still need a keyboard to quit the program. This mapping will solve both of those problems. As with any emulator or port in RetroPie, you'll first need to figure out where the launch command is located for the specific emulator or port you wish to map. This command is usually found in the /opt/retropie/configs/systemname/emulators.cfg file. However, it is sometimes located in different places. In the case of ScummVM, we find by checking it's emulators.cfg file that it is actually launched from a script located at /home/pi/RetroPie/roms/scummvm/+Start\ ScummVM.sh. Once located, adding an xboxdrv mapping is just a matter of adding the configuration to the beginning of the command and separating it by using the -- entry. Using the base configuration example from the first section, below is a before and after look at how this should be formatted.
      Before
      #!/bin/bash
      game="$1"
      pushd "/home/pi/RetroPie/roms/scummvm" >/dev/null
      /opt/retropie/emulators/scummvm/bin/scummvm --fullscreen --joystick=0 --extrapath="/opt/retropie/emulators/scummvm/extra" $game
      while read line; do
          id=($line);
          touch "/home/pi/RetroPie/roms/scummvm/$id.svm"
      done < <(/opt/retropie/emulators/scummvm/bin/scummvm --list-targets | tail -n +3)
      popd >/dev/null
      After
      #!/bin/sh
      game="$1"
      sudo killall >/dev/null xboxdrv
      	>/dev/null \
      	--silent \
      	--force-feedback \
      	--deadzone 4000 \
      	--mimic-xpad \
      	--axismap -Y1=Y1,-Y2=Y2 \
      	--ui-axismap x1=REL_X:10,y1=REL_Y:10 \
      	--ui-buttonmap b=BTN_LEFT,a=BTN_RIGHT,start=KEY_F5 \
      	--ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,back=void \
      	--ui-axismap x2=void \
      while read line; do
          id=($line);
      popd >/dev/null
      Notice that it begins with a sudo command to kill any other instances of xboxdrv. This is in case you have already configured your controller with a system-wide mapping from the earlier steps. We'll go over later how to re-enable that system-wide mapping automatically when the emulator shuts down so that you will be left where you started. If you have no system-wide mapping, the basic controls you have set up in Emulation Station will return once the emulator quits without any further setting. For this particular mapping, we have enabled mouse support to the left joystick, mouse left and right buttons to controller buttons 'b' and 'a', as well as mapping the 'F5' key to the controller's 'start' button so that we can bring up the menu and control the entire software from the controller. To do this, we added two new lines to our basic configuration in the form of --ui-axismap and --ui-buttonmap.
      This particular example works well for mapping a controller's left analog stick to mouse support using the --ui-axismap variable and can be changed to the right stick by simply altering the line to --ui-axismap x2=REL_X:10,y2=REL_Y:10. If you should ever want to map keyboard keys to an analog stick, a classic example would look like --ui-axismap X1=KEY_A:KEY_D,Y1=KEY_W:KEY_S, giving you the ADWS control scheme found in many classic computer titles. As far as key-mapping buttons is concerned, first you must consider which buttons are available to you. Seeing as how xboxdrv emulates a standard XBox 360 controller, you will have any of those buttons that you have already assigned to your controller in the earlier steps. If you have assigned all the buttons that are possible, you'll have access to a,b,x,y,lb,rb,lt,rt,tl,tr,start,back and guide. The placement of these buttons can be seen here. By using the --ui-buttonmap variable, you can then map any one of the buttons to a key using the format above. To discover all the possible keyboard keys that are available to you, type /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --help-key. Finally, you'll notice that their are two more lines added with the --ui-axismap and --ui-buttonmap variables that are solely responsible for voiding the unused control elements. This is optional, but it will make the control scheme cleaner by eliminating the possibility of those elements conflicting in any way.
      So now that we have our control scheme added to the launch command, we can save it and try it out. I've had this particular example running for some time, so it should load right up and tear itself down once the emulator quits. If it doesn't, you'll want to troubleshoot your xboxdrv command separately by removing the >/dev/null \ line and executing it from the command line. It should report any errors that need correcting. From there you would add the >/dev/null \ back to the command and place it back in the launch command. For those who have a system-wide xboxdrv mapping that should be restored afterward, copy that same configuration from your /etc/rc.local to the '/opt/retropie/configs/all/runcommand-onend.sh' bash script. If the script doesn't exist, drop to the command line and type:
      nano /opt/retropie/configs/all/runcommand-onend.sh
      #!/bin/sh
      On a line below, you can now add the global xboxdrv command you previously added to /etc/rc.local. To keep things nice and silent, you may wish to alter your original command by changing the first two lines to read:
      	>/dev/null \
      This will keep xboxdrv from printing any onscreen feedback, making the whole process completely transparent to the user. Now, press 'ctrl+o' to save the file, 'Enter' to confirm and 'ctrl+x' to exit. All that is left is to make the script executable in the terminal by typing:
      chmod +x /opt/retropie/configs/all/runcommand-onend.sh
      To fully round out this section on key-mapping, it should be mentioned that in some rare scenarios, the keyboard that xbmc virtualizes may not be recognized as being a keyboard by the software you intend to use it with. In this situation, you can create a udev rule that will authenticate the input as being from an actual keyboard at a system level, allowing it to function anywhere. To add this udev rule, drop to the command line and type:
      sudo nano /etc/udev/rules.d/99-xboxdrv.rules
      SUBSYSTEM=="input", ATTRS{name}=="Microsoft X-Box 360 pad - Keyboard Emulation", GROUP="users", MODE="0666", ENV{ID_INPUT_KEYBOARD}="1"
      Now press 'ctrl+o' to save the file, 'Enter' to confirm and 'ctrl+x' to exit. The name "Microsoft X-Box 360 pad - Keyboard Emulation" is dependent on the use of the --mimic-xpad variable used in your xboxdrv command. If you have customized that name using the --device-name variable instead, as seen in the earlier example, it would then be replaced with "My Most Non-Non-Triumphant Controller Name Here - Keyboard Emulation".
      • (3B) Expanding Launch Capabilities
      The above method of combining the xboxdrv configuration with the launch command is a function that is built in to xboxdrv. However, it can be a bit unwieldy when considering the multiple launch methods found in RetroPie. What follows is an alternate method that that utilizes the runcommand-onstart.sh shell script, allowing a unified location and format for multiple xboxdrv configurations that launch based on a case statement. In addition, all the xboxdrv parameters are assigned to variables, making the case statement more readable.
      If it doesn't already exist, start by creating the runcommand-onstart.sh:
      nano /opt/retropie/configs/all/runcommand-onstart.sh
      The following is just an example, everyone should change the configuration based on their own controller
      #!/bin/sh
      ## Uncomment one or all of the following if you need to find some information about the emulator or roms
      ## Name of the emulator
      #echo $1 >> /dev/shm/runcommand.log
      ## Name of the software used for running the emulation
      #echo $2 >> /dev/shm/runcommand.log
      ## Name of the rom
      #echo $3 >> /dev/shm/runcommand.log
      ##Executed command line
      #echo $4 >> /dev/shm/runcommand.log
      ### The FUN begins
      #Get ROM name striping full path
      rom="${3##*/}"
      ### Set variables for your joypad and emulator
      ### Basic Configuraions - Standard controller mappings
      basicPS3="/opt/retropie/supplementary/xboxdrv/bin/xboxdrv >/dev/null \
      	--evdev /dev/input/event2 \
      	--silent \
      	--force-feedback \
      	--mimic-xpad \
      	--dpad-as-button \
      	--evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RX=y2 \
      	--evdev-keymap KEY_#302=a,KEY_#301=b,BTN_DEAD=x,KEY_#300=y,BTN_THUMB=tl,BTN_THUMB2=tr,BTN_BASE5=lb,BTN_BASE6=rb,BTN_BASE3=lt,BTN_BASE4=rt,BTN_TRIGGER=back,BTN_TOP=start,BTN_SOUTH=guide,BTN_TOP2=du,BTN_PINKIE=dr,BTN_BASE=dd,BTN_BASE2=dl
      	--calibration x1=-32767:0:32767,y1=-32767:0:32767,x2=-32767:0:32767,y2=-32767:0:32767"
      ### Extended Configurations
      ### Specific emulator configuration or any other parameters you will need only for some emulators
      scummVM="--axismap -Y1=Y1,-Y2=Y2 \
      	--ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \
      	--ui-axismap x2=void"
      amiga="--axismap -Y1=Y1,-Y2=Y2 \
      	--ui-axismap x2=REL_X:1,y2=REL_Y:1 \
      	--ui-axismap x1=KEY_LEFT:KEY_RIGHT,y1=KEY_DOWN:KEY_UP \
      	--ui-buttonmap du=KEY_UP,dd=KEY_DOWN,dl=KEY_LEFT,dr=KEY_RIGHT \
      	--ui-buttonmap lt=BTN_LEFT,rt=BTN_RIGHT,start=KEY_ESC,back=KEY_LEFTCTRL,y=KEY_SPACE,a=KEY_LEFTCTRL,b=KEY_LEFTALT,x=KEY_LEFTSHIFT \
      	--ui-buttonmap guide=void,tl=void,lt=void,rt=void,back=void \
      fourway="--four-way-restrictor"
      invert="--ui-buttonmap du=KEY_DOWN,dd=KEY_UP"
      ### Kill Command
      xboxkill="sudo killall >/dev/null xboxdrv"
      ### Execute the driver with the configuration you need
      # $1 is the name of the emulation, not the name of the software used
      # it is intellivision not jzintv
      case $1 in
      	mame-libretro)
      	fba)
      		case $rom in
      			"amidar.zip"|"atetris.zip"|"puckman.zip") # Configuration used only for these ROMs
      				$xboxkill
      				joycommand="$basicPS3 $fourway &"
      				eval $joycommand
      			*) # Configuration for every other ROMs on this emulator
      				$xboxkill
      				joycommand="$basicPS3 &"
      				eval $joycommand
      		esac
      	daphne)
      	scummvm)
      		$xboxkill
      		joycommand="$basicPS3 $scummVM &"
      		eval $joycommand
      	amiga)
      		$xboxkill
      		joycommand="$basicPS3 $amiga &"
      		eval $joycommand
      	intellivision)
      esac
      We assign to the joycommand variable, the list of variables that contains the parameters we need for example joycommand="BasicVAR var1 var2 var3 $". The Basic variables must be the first, and & must be the last.
      Next, we make the script executable:
      sudo chmod +x /opt/retropie/configs/all/runcommand-onstart.sh
      For some emulators we could face some problem, i have a PS3 controller recognized as input device event2, when i execute xboxdrv the controller is recognized as input device event3. The system now see 2 controller device, the PS3 as controller with id 0 and an Xbox360 controller with id 1, for the emulator you are now using the controller for player2 and this will cause some problem, for example you can only start a 2 players game, you can't quit the emulation pushing 'select+start'. To solve the problem we have to specify on retroarch.cfg the id of the controller used by player1 and player2.
      This is the configuration for Final Burn Alpha, we have to add input_playerx_joypad_index = "x" for every controller between input_remapping_directory = "/opt/retropie/configs/fba/" and #include "/opt/retropie/configs/all/retroarch.cfg" where the first X is the player number, and the secon X is the controller ID.
      input_player1_joypad_index = "1"
      input_player2_joypad_index = "0"
      input_player2_analog_dpad_mode = 1
      If you want this configuration for every retroarch emulators, you have to edit nano /opt/retropie/configs/all/retroarch.cfg
      Now we need to kill xboxdrv when we exit from the emulator, we do this with the onend script
      #!/bin/sh
      and make it executable
      sudo chmod +x /opt/retropie/configs/all/runcommand-onend.sh
      M 1 Reply Last reply Reply Quote 13
        This is my first attempt at a guide here and there's a lot of information to put forth. I've tried to be as thorough as I can, but bear with me if any mistakes are found. I'll be sure to make a note of any major omissions or inaccuracies here as they are rectified.
        • RiverstormR
          Riverstorm
          Next, we'll take a look at how to map keyboard keys and mouse movements to a controller's analog sticks and buttons for use in emulators that lack native controller support
          I'll be looking forward to this as I think it would be quite handy.
          Nice guide Media, well written and easy to follow for us layman folks! ;)
            mediamogul Global Moderator @Riverstorm
            @Riverstorm said in Advanced Controller Mappings:
            Thanks Riverstorm, I'm glad you like it so far. I had some reservations on being overly detailed, but I've been in the position of following guides before where most of the difficulty came from deciphering the missing steps that were taken for granted by the author and that's never fun. The keyboard mapping will be added soon and is very easy to do. The only part of the guide that will take any time to write is how to maintain multiple mappings, as there are a few options there. However, it shouldn't be too far down the road now. I hope it proves useful and thanks again.
              BuZz administrators
              great job! :)
                mediamogul Global Moderator @BuZz
                @BuZz
                Thank you much. As I see it, the big difference between RetroPie and the other retro-gaming distributions is the thoughtful inclusion of tools like this that can be leveraged to customize our setups in just about any way imaginable. With the recent addition of control over installation and removal of the emulators, RetroPie is quite literally second to none in customization. So... great job back at you and all the folks who make it possible. :)
                  Mayki
                  I am trying to map the buttons on my PS3 controller, but I have no names for the buttons X(302), Triangle(300) and Circle(301).
                  Event: time 1469807542.183632, type 1 (EV_KEY), code 297 (BTN_BASE4), value 0
                  Event: time 1469807542.183632, -------------- EV_SYN ------------
                  Event: time 1469807542.930848, type 1 (EV_KEY), code 298 (BTN_BASE5), value 1
                  Event: time 1469807542.930848, -------------- EV_SYN ------------
                  Event: time 1469807543.074988, type 1 (EV_KEY), code 298 (BTN_BASE5), value 0
                  Event: time 1469807543.074988, -------------- EV_SYN ------------
                  Event: time 1469807543.684320, type 1 (EV_KEY), code 299 (BTN_BASE6), value 1
                  Event: time 1469807543.684320, -------------- EV_SYN ------------
                  Event: time 1469807543.805707, type 1 (EV_KEY), code 299 (BTN_BASE6), value 0
                  Event: time 1469807543.805707, -------------- EV_SYN ------------
                  Event: time 1469807544.772830, type 1 (EV_KEY), code 303 (BTN_DEAD), value 1
                  Event: time 1469807544.772830, -------------- EV_SYN ------------
                  Event: time 1469807544.930849, type 1 (EV_KEY), code 303 (BTN_DEAD), value 0
                  Event: time 1469807544.930849, -------------- EV_SYN ------------
                  Event: time 1469807545.909350, type 1 (EV_KEY), code 300 (?), value 1
                  Event: time 1469807545.909350, -------------- EV_SYN ------------
                  Event: time 1469807546.058367, type 1 (EV_KEY), code 300 (?), value 0
                  Event: time 1469807546.058367, -------------- EV_SYN ------------
                  Event: time 1469807546.599438, type 1 (EV_KEY), code 301 (?), value 1
                  Event: time 1469807546.599438, -------------- EV_SYN ------------
                  Event: time 1469807546.711951, type 1 (EV_KEY), code 301 (?), value 0
                  Event: time 1469807546.711951, -------------- EV_SYN ------------
                  Event: time 1469807547.283398, type 1 (EV_KEY), code 302 (?), value 1
                  Event: time 1469807547.283398, -------------- EV_SYN ------------
                  Event: time 1469807547.407163, type 1 (EV_KEY), code 302 (?), value 0
                  Event: time 1469807547.407163, -------------- EV_SYN ------------
                  It is normal?
                  My other buttons:
                  D-PAD UP - BTN_TOP2   CODE 292
                  D-PAD DOWN - BTN_BASE  CODE 294
                  D-PAD LEFT - BTN_BASE2  CODE 295
                  D-PAD RIGHT - BTN_PINKIE  CODE 293
                  SELECT - BTN_TRIGGER  CODE 288
                  START - BTN_TOP  CODE 291
                  L1 - BTN_BASE5  CODE 298
                  L2 - BTN_BASE3  CODE 296
                  R1 - BTN_BASE6  CODE 299
                  R2 - BTN_BASE4  CODE 297
                  X - (?) CODE 302
                  SQUARE "ČTVEREC" - BTN_DEAD  CODE 303
                  TRIANGLE "TROJÚHELNÍK" - (?) CODE 300
                  CIRCLE "KOLEČKO" - (?) CODE 301
                  L-ANALOG KLIK - BTN_THUMB CODE 289
                  R-ANALOG KLIK - BTN_THUMB2 CODE 290
                  L-ANALOG LEFT - ABS_X MÍNUS
                  L-ANALOG RIGHT - ABS_X PLUS
                  L-ANALOG UP - ABS_Y MÍNUS
                  L-ANALOG DOWN - ABS_Y PLUS
                  R-ANALOG LEFT - ABS_Z MÍNUS
                  R-ANALOG RIGHT - ABS_Z PLUS
                  R-ANALOG UP - ABS_RX MÍNUS
                  R-ANALOG DOWN - ABS_RX PLUS
                    mediamogul Global Moderator @Mayki
                    @Mayki said in Advanced Controller Mappings:
                    It is normal?
                    I believe first party PS3 controllers have native support in xboxdrv. I don't own a PS3 controller myself, so I was unable to test this, but supposedly it will automatically map the controller for you with the button locations in the same places you'd expect to find them. Try the mapping below and see if it works.
                    	--silent \
                    	--force-feedback \
                    	--deadzone 4000 \
                    	--mimic-xpad \
                    In this situation, most people will be happy with the automatic button mapping, as the buttons and sticks are more or less in the same location between the two types of controllers, but it is still possible to alter the arrangement by using the --axismap and --buttonmap command arguments. Using the example I just gave above, I'll illustrate this technique below by inverting the Y-axis on the left joystick (useful in some games if you don't like helicopter controls) and also switch the 'A' and 'B' buttons.
                    	--silent \
                    	--force-feedback \
                    	--deadzone 4000 \
                    	--mimic-xpad \
                    	--axismap -y1=y1 \
                    	--buttonmap a=b,b=a \
                    Of course this example can be expanded to include any number of mappings. You could even switch the left and right joysticks completely if needed.
                      Mayki
                      When I type in the rc.local:
                      	--silent \
                      	--force-feedback \
                      	--deadzone 4000 \
                      	--calibration x1=-32767:0:32767,y1=-32767:0:32767,x2=-32767:0:32767,y2=-32767:0:32767 \
                      	--mimic-xpad \
                      Have not noticed any change after the restart, gamepad is still reported as a Playstation 3 controller.
                      How do I know that it works?
                        @Mayki
                        Drop --evdev /dev/input/event2 \ and see if that does it. If not, I did a little reading on the PS3 controller and it appears as though you can map those four buttons using my original instructions as follows:
                        In context, that would look like:
                        	--silent \
                        	--force-feedback \
                        	--deadzone 4000 \
                        	--mimic-xpad \
                        	--evdev-keymap BTN_KEY_#302=a,KEY_#301=b,BTN_DEAD=x,KEY_#300=y,BTN_*=lb,BTN_*=rb,BTN_*=tl,BTN_*=tr,BTN_*=guide,BTN_*=back,BTN_*=start \
                        I hate that I don't have a PS3 controller to test, but maybe that will take care of the issue. If so, I'll add it to the instructions up top.
                          Mayki
                          Without success.
                          Write :
                          output:
                          I: Bus=0006 Vendor=054c Product=0268 Version=0100
                          N: Name="PLAYSTATION(R)3 Controller"
                          P: Phys=
                          S: Sysfs=/devices/virtual/input/input2
                          U: Uniq=
                          H: Handlers=event2 js0
                          B: PROP=0
                          B: EV=20000b
                          B: KEY=1ffff 0 0 0 0 0 0 0 0 0
                          B: ABS=7f fc00ffff
                          B: FF=7030000 0 0
                          write:
                          output:
                          usb-Logitech_USB_Receiver-event-kbd
                          usb-Logitech_USB_Receiver-if01-event-mouse
                          usb-Logitech_USB_Receiver-if01-mouse
                          No PS3 gamepad on the list.
                          Unable to add to the line.
                          When writing this:
                          	--silent \
                          	--force-feedback \
                          	--deadzone 4000 \
                          	--mimic-xpad \
                          No change.
                          When writing this:
                          	--silent \
                          	--force-feedback \
                          	--deadzone 4000 \
                          	--mimic-xpad \
                          No change. Gamepad is still reported as a Playstation 3 controller.
                          ps3
                            @Mayki
                            Based on all the information you've given so far, you're configuration should look like this:
                            	--silent \
                            	--force-feedback \
                            	--deadzone 4000 \
                            	--mimic-xpad \
                            	--dpad-as-button \
                            	--evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RZ=y2,ABS_#48=lt,ABS_#49=rt \
                            	--evdev-keymap KEY_#302=a,KEY_#301=b,BTN_DEAD=x,KEY_#300=y,BTN_THUMB=tl,BTN_THUMB2=tr,BTN_BASE5=lb,BTN_BASE6=rb,BTN_TRIGGER=back,KEY_#720=guide,BTN_TOP=start,BTN_TOP2=du,BTN_PINKIE=dr,BTN_BASE=dd,BTN_BASE2=dl \
                            If that doesn't work, we'll have to look at the error that is given. The easiest way to do that is to paste the previous command directly into the terminal minus the final backslash and ampersand. After you press 'Enter', the error will print out if something's wrong.
                              Mayki
                              Some success...
                              pi@retropie:~ $ sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv \
                              > --silent \
                              > --force-feedback \
                              > --deadzone 4000 \
                              > --mimic-xpad \
                              > --dpad-as-button \
                              xboxdrv 0.8.8 - http://pingus.seul.org/~grumbel/xboxdrv/
                              Copyright © 2008-2011 Ingo Ruhnke <grumbel@gmail.com>
                              Licensed under GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
                              This program comes with ABSOLUTELY NO WARRANTY.
                              This is free software, and you are welcome to redistribute it under certain
                              conditions; see the file COPYING for details.
                              Your Xbox/Xbox360 controller should now be available as:
                                /dev/input/js1
                                /dev/input/event3
                              Press Ctrl-C to quit
                              pi@retropie:~ $ cat /proc/bus/input/devices
                              I: Bus=0003 Vendor=046d Product=c52b Version=0111
                              N: Name="Logitech USB Receiver"
                              P: Phys=usb-3f980000.usb-1.4/input0
                              S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C52B.0001/input/input0
                              U: Uniq=
                              H: Handlers=sysrq kbd leds event0
                              B: PROP=0
                              B: EV=120013
                              B: KEY=10000 7 ff800000 7ff febeffdf ffefffff ffffffff fffffffe
                              B: MSC=10
                              B: LED=1f
                              P: Phys=usb-3f980000.usb-1.4/input1
                              S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input1
                              U: Uniq=
                              H: Handlers=kbd mouse0 event1
                              B: PROP=0
                              B: EV=1f
                              B: KEY=3007f 0 0 0 0 83ffff 17aff32d bf544446 0 0 ffff0001 130f97 8b17c000 6773fa d941dfed 9ed680 4400 0 10000002
                              B: REL=1c3
                              B: ABS=1 0
                              B: MSC=10
                              P: Phys=
                              U: Uniq=
                              H: Handlers=js0 event2
                              B: PROP=0
                              B: EV=20000b
                              B: ABS=7f fc00ffff
                              B: FF=7030000 0 0
                              I: Bus=0003 Vendor=045e Product=028e Version=0110
                              N: Name="Microsoft X-Box 360 pad"
                              P: Phys=
                              S: Sysfs=/devices/virtual/input/input5
                              U: Uniq=
                              H: Handlers=js1 event3
                              B: PROP=0
                              B: EV=20000b
                              B: KEY=7cdb03c0 0 0 0 0 0 0 0 0 0
                              B: ABS=3f
                              B: FF=1 3f870000 0 0
                                @Mayki
                                Very glad to hear it. Everything looks to be in order from here. If anything else comes up, I'll be around.
                                  Mayki
                                  Write to rc.local:
                                  #!/bin/sh -e
                                  # rc.local
                                  # This script is executed at the end of each multiuser runlevel.
                                  # Make sure that the script will "exit 0" on success or any other
                                  # value on error.
                                  # In order to enable or disable this script just change the execution
                                  # bits.
                                  # By default this script does nothing.
                                  # Print the IP address
                                  _IP=$(hostname -I) || true
                                  if [ "$_IP" ]; then
                                    printf "My IP address is %s\n" "$_IP"
                                  fi
                                  	--silent \
                                  	--force-feedback \
                                  	--deadzone 4000 \
                                  	--mimic-xpad \
                                  	--dpad-as-button \
                                  exit 0
                                  Restart, when writing this:
                                  U: Uniq=
                                  B: PROP=0
                                  B: EV=120013
                                  B: MSC=10
                                  B: LED=1f
                                  U: Uniq=
                                  B: PROP=0
                                  B: EV=1f
                                  B: REL=1c3
                                  B: ABS=1 0
                                  B: MSC=10
                                  P: Phys=
                                  U: Uniq=
                                  B: PROP=0
                                  B: EV=20000b
                                  B: ABS=7f fc00ffff
                                  B: FF=7030000 0 0
                                  Not X-Box 360 gamepad, why?
                                    @Mayki
                                    So it's working when you enter it into the command line directly, but not from /etc/rc.local? Go ahead and post the entire contents of your /etc/rc.local so we can take a look at it.
                                    EDIT: Nevermind, I see it above.
                                      Mayki
                                      /etc/rc.local :
                                      #!/bin/sh -e
                                      # rc.local
                                      # value on error.
                                      # bits.
                                      if [ "$_IP" ]; then
                                      fi
                                      	--silent \
                                      	--force-feedback \
                                      	--deadzone 4000 \
                                      	--mimic-xpad \
                                      	--dpad-as-button \
                                      exit 0
                                        mediamogul Global Moderator @mediamogul
                                        @mediamogul
                                        Try pasting the command above the line # Print the IP address.
                                          Mayki
                                          No change. No Xbox gamepad.
                                            @Mayki
                                            There's a conflict with the other command in the file that's printing the IP address. I'm not sure how to make them coexist, but the xboxdrv command itself should run without the other.
