    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 501.5k Views
      mediamogul Global Moderator @Hubz
      @Hubz
      Sure. You'd just string two commands together instead of having just one. A quick example for Intellivision would look like
      if [ "$1" = "intellivision" ]
      then
      	--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.2:1.0-event-joystick \
      	--detach-kernel-driver \
      	--force-feedback \
      	--dpad-as-button \
      	--trigger-as-button \
      	--deadzone-trigger 15% \
      	--deadzone 4000 \
      	--device-name "Logitech Rumblepad 2 (xboxdrv)" \
      	--silent \
      	--axismap -Y1=Y1,-Y2=Y2 \
      	--evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RZ=y2,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
      	--evdev-keymap BTN_THUMB2=a,BTN_THUMB=b,BTN_TOP=x,BTN_TRIGGER=y,BTN_BASE3=back,BTN_BASE4=start,BTN_TOP2=lb,BTN_PINKIE=rb,BTN_BASE5=tl,BTN_BASE6=tr,BTN_BASE=lt,BTN_BASE2=rt \
      	--ui-axismap X1=KEY_S:KEY_D,Y1=KEY_E:KEY_X,X2=KEY_1:KEY_2,Y2=KEY_3:KEY_4,lt+X2=KEY_5:KEY_6,lt+Y2=KEY_7:KEY_8,rt+X2=KEY_9:KEY_0,rt+Y2=KEY_MINUS:KEY_EQUAL \
      	--ui-buttonmap b=KEY_LEFTSHIFT,a=KEY_UNKNOWN,x=KEY_LEFTCTRL,y=KEY_LEFTALT,lb=KEY_UNKNOWN,rb=KEY_UNKNOWN,lt=KEY_UNKNOWN,rt=KEY_UNKNOWN,tl=KEY_UNKNOWN,tr=KEY_UNKNOWN,du=KEY_E,dd=KEY_X,dl=KEY_S,dr=KEY_D,start=KEY_PAUSE \
      	--ui-buttonmap back=cycle-key:KEY_F6:KEY_F5 \
      	--ui-buttonmap back+start=KEY_F1,back+b=KEY_F12,back+y=KEY_F11,back+a=KEY_PAUSE \
      	--ui-buttonmap lt+a=KEY_A,lt+b=KEY_B,lt+x=KEY_X,lt+y=KEY_Y,lt+lb=KEY_L,lt+rb=KEY_R,lt+du=KEY_UP,lt+dd=KEY_DOWN,lt+dl=KEY_LEFT,lt+dr=KEY_RIGHT,lt+start=KEY_T,lt+back=KEY_E \
      	--ui-buttonmap guide=void \
      	--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.4:1.0-event-joystick \
      	--force-feedback \
      	--dpad-as-button \
      	--deadzone 4000 \
      	--silent \
      	--ui-axismap X1=KEY_J:KEY_K,Y1=KEY_I:KEY_M,X2=KEY_KP1:KEY_KP2,Y2=KEY_KP3:KEY_KP4,lt+X2=KEY_KP5:KEY_KP6,lt+Y2=KEY_KP7:KEY_KP8,rt+X2=KEY_KP9:KEY_DOT,rt+Y2=KEY_0:KEY_ENTER \
      	--ui-buttonmap b=KEY_RIGHTSHIFT,a=KEY_UNKNOWN,x=KEY_RIGHTCTRL,y=KEY_RIGHTALT,lb=KEY_UNKNOWN,rb=KEY_UNKNOWN,lt=KEY_UNKNOWN,rt=KEY_UNKNOWN,tl=KEY_UNKNOWN,tr=KEY_UNKNOWN,du=KEY_I,dd=KEY_M,dl=KEY_J,dr=KEY_K,back=KEY_UNKNOWN,start=KEY_PAUSE \
      fi
      You can even have both those commands set to run by default and have others run for individual games using elif. Adding a map command to the example above that will only launch for 'Masters of The Universe: The Power of He-Man' would look like:
      if [ "$1" = "intellivision" ] && [ "$3" = "/home/pi/RetroPie/roms/intellivision/Masters of the Universe-The Power of He-Man! (1983) (Mattel).int" ]
      then
      	--force-feedback \
      	--dpad-as-button \
      	--deadzone 4000 \
      	--silent \
      	--ui-buttonmap b=KEY_LEFTSHIFT,a=KEY_2,x=KEY_LEFTCTRL,y=KEY_LEFTALT,lb=KEY_UNKNOWN,rb=KEY_UNKNOWN,lt=KEY_UNKNOWN,rt=KEY_UNKNOWN,tl=KEY_UNKNOWN,tr=KEY_UNKNOWN,du=KEY_E,dd=KEY_X,dl=KEY_S,dr=KEY_D,start=KEY_PAUSE \
      elif [ "$1" = "intellivision" ]
      then
      	--force-feedback \
      	--dpad-as-button \
      	--deadzone 4000 \
      	--silent \
      	--force-feedback \
      	--dpad-as-button \
      	--deadzone 4000 \
      	--silent \
      fi
      So basically it dictates that if the system is Intellivision and the ROM is He-Man, then it will launch the He-Man map command. Otherwise, if the system is Intellivision with no specified ROM, it will always fall back to the default one and two player map commands.
      • H
        Hubz @mediamogul
        @mediamogul Nice! So there are certain games you don't want to run in two player mode like He-Man?
          @Hubz
          Not really. It'll just ignore the second controller input if it's a game that doesn't use it.
            spud11 @mediamogul
            @mediamogul Thanks, mediamogul.
            I've also managed to get 2 players working (see below) based on your response to @Hubz, albeit I'm still having the same problems with the "newlines" and finding I'm manually re-doing the carriage returns to get it working.
            #!/bin/sh
            if [ "$1" = "amiga" ]
            then
            sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv > /dev/null 2>&1 \
            --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick \
            --silent \
            --force-feedback \
            --deadzone 4000 \
            --mimic-xpad \
            --device-name "Amiga Joystick Player 1 (xboxdrv)" \
            --evdev-absmap ABS_X=y1,ABS_Y=x1 \
            --evdev-keymap BTN_TRIGGER=X,BTN_THUMB=Y,BTN_THUMB2=A,BTN_PINKIE=B,BTN_BASE3=BACK,BTN_BASE6=START \
            --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void \
            sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >/dev/null 2>&1 \
            --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick \
            --silent \
            --force-feedback \
            --deadzone 4000 \
            --mimic-xpad \
            --device-name "Amiga Joystick Player 2 (xboxdrv)" \
            --evdev-keymap BTN_TRIGGER=Y,BTN_THUMB=A,BTN_THUMB2=BACK,BTN_PINKIE=X,BTN_TOP=B,BTN_TOP2=START \
            fi
            Since getting this Amiga script working, I've tried to make a script for multiple emulators, similar to the one appearing in my response to @EctoOne at 275 above. I wasn't successful.
            As I've got the Amiga script working based on the if/then statement, I was wondering whether it's possible to adapt the existing script using another if/then statement so that I might also be able to use xboxdrv for particular Arcade games that require 4 way joysticks (like Pacman and Donkey Kong). I've got a list of about 200 arcade games that apparently use 4 way, rather than 8 way, joysticks. I suspect this script might end up being very long....
            Thanks for any help.
            mediamogulM H 2 Replies Last reply Reply Quote 0
              mediamogul Global Moderator @spud11
              @spud11 said in Guide: Advanced Controller Mappings:
              I had a similar problem with the OSX TextEdit, but was able to set it to Unicode UTF-8. That might not be the exact setting in your case, but it'll end up being easier if you can adapt Notepad++ to omit the rogue carriage returns or find another text editor that doesn't have that issue.
              It would indeed. This would seem like a good opportunity to use @MadHorse's expanded case statement technique from the xboxdrv guide. In his example there, you'll see an area for adding just the ROM names of titles that should use a four-way restrictor, making the script much shorter and more manageable.
              pjftP S 2 Replies Last reply Reply Quote 0
                pjft @mediamogul
                @mediamogul Hi! Here I am, with a few naive questions if I may. This morning I managed to have some time and looked into xboxdrv. I was trying out a simple example to see if I could remap a button to a key, but it didn't seem to work in the game I was trying it in so I thought of dropping by again.
                I got to launch xboxdrv "properly", and having it assign a new id to my controller. In this case, I was just trying to assign "select" on my controller to "escape" on the keyboard. I did the whole evtest thing.
                I ran
                 --evdev /dev/input/by-id/usb-Sony_PLAYSTATION_R_3_Controller-event-joystick \
                --silent \
                --force-feedback \
                --deadzone 4000 \
                --mimic-xpad \
                --evdev-keymap BTN_TRIGGER=b \
                --ui-buttonmap b=KEY_ESC
                But escape didn't seem to be registered, so I'm surely doing something wrong here. I believe I also tried it with
                 --evdev /dev/input/event2
                But got similar non-results. :)
                Is there a way I can just press the buttons on my controller and see if the keys are registering, say by sending characters to the terminal? I'm happy to map it to any other key. Is the right way for that to launch xboxdrv (for instance, via SSH), and go to the terminal on the Pi?
                Just so I can continue testing.
                Do I need to explicitly map all the buttons from the controller? Do I explicitly need to map app evdev-keymap definitions to -ui-buttonmap definitions?
                Thanks, and sorry for the trouble.
                  mediamogul Global Moderator @pjft
                  @pjft
                  If the game happened to be running from a RetroArch core, RetroArch requires a udev rule be set before it will recognize the virtual keyboard. That information is located at the tail-end of section 3A of the guide.
                  You could map a letter for your test key and open up something like nano to see if it enters correctly. Something more substantial would be to consider that the virtual keyboard actually registers as a normal keyboard event, so you could test every keypress you map to it with evtest.
                  No, your example is fine and an ideal first test.
                  No trouble at all.
                    pjft @mediamogul
                    @mediamogul Thanks.
                    The nano test was what I had in mind - just wanted to confirm what was the right approach to test it, given that when I launch xboxdrv at the moment it just takes over the window. I suppose I could launch it as a daemon, but for quick iterations I'd rather test it like this.
                    I'll launch xboxdrv from SSH, and then in the Pi's command line I'll check for key presses.
                    It's not a RetroArch core per se, but the GameMaker port. I'll look into the udev thingie, though, if events are being registered but don't make it to the game.
                    Thank you for your excellent service here! I'll report back when I do have the chance to test this, but may only be in the coming days.
                      @pjft said in Guide: Advanced Controller Mappings:
                      It seems like I remember helping someone setup xboxdrv with a GameMaker port several months ago where the same thing was required, so that could be it.
                      Keen beans mean Gene.
                        pjft @mediamogul
                        @mediamogul Thanks.
                        So, indeed, the terminal shows the keys I'm pressing, and I can control Rick Dangerous (of all things)!
                        I can't, however, send my inputs to GameMaker. I even tried disconnecting my keyboard, thinking it could be something like it defaulting to the first keyboard it detected, but nada.
                        Here's the command I'm using:
                         --evdev /dev/input/event2 \
                         --silent \
                         --force-feedback \
                         --deadzone 4000 \
                         --mimic-xpad \
                         --dpad-as-button \
                         --evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RZ=y2,ABS_#48=lt,ABS_#49=rt \
                         --evdev-keymap KEY_#302=a,KEY_#301=b,BTN_DEAD=x,KEY_#300=y,BTN_THUMB=tl,BTN_THUMB2=tr,
                        BTN_BASE5=lb,BTN_BASE6=rb,BTN_TRIGGER=back,KEY_#720=guide,
                        BTN_TOP=start,BTN_TOP2=du,BTN_PINKIE=dr,BTN_BASE=dd,BTN_BASE2=dl \
                         --ui-buttonmap a=KEY_Z,b=KEY_X,x=KEY_S,y=KEY_A,lb=KEY_F1,rb=KEY_F12,lt=KEY_HOME,
                        rt=KEY_HOME,tl=KEY_HOME,tr=KEY_HOME,du=KEY_UP,dd=KEY_DOWN,
                        dl=KEY_LEFT,dr=KEY_RIGHT,start=KEY_ESC \
                         --calibration x1=-32767:0:32767,y1=-32767:0:32767,x2=-32767:0:32767,y2=-32767:0:32767
                        (yes, I broke some of the lines here deliberately, for legibility, but they're all together as they should).
                        I even added the udev thingie you have in this post, as well as the one in the wiki (in case they're different - using only one didn't do much).
                        sudo nano /etc/udev/rules.d/99-xboxdrv.rules
                        SUBSYSTEM=="input", ATTRS{name}=="Microsoft X-Box 360 pad - Keyboard Emulation", GROUP="users", MODE="0666", ENV{ID_INPUT_KEYBOARD}="1"
                        and
                        sudo nano /etc/udev/rules.d/55-permissions-uinput.rules
                        KERNEL=="uinput", MODE="0660", GROUP="users"
                        and rebooted.
                        I'm calling it a day here, but curious as to what else you'd suggest me doing here - if anything.
                        By all means, your guide was tremendously helpful, and knowing that I can at least set it up for some other games is great! Just curious to see if we could get the GameMaker ones on board as well, but it's not critical.
                        Thanks, have a great day!
                          When I've tried to do that in the past, the command always ends prematurely at the break and xboxdrv ignores everything afterward. Is there some special carriage return that keeps them together?
                            pjft @mediamogul
                            @mediamogul Oh, no, sorry.
                            What I meant is that I broke the lines here in the forum, as it was messing up my whole window when I pasted them here. Not in the terminal.
                            The command is, effectively the following - apologies for the lack of formatting as it's unwieldy:
                            --silent
                            --force-feedback
                            --deadzone 4000
                            --mimic-xpad
                            --dpad-as-button
                            --evdev-keymap KEY_#302=a,KEY_#301=b,BTN_DEAD=x,KEY_#300=y,BTN_THUMB=tl,BTN_THUMB2=tr,BTN_BASE5=lb,BTN_BASE6=rb,BTN_TRIGGER=back,KEY_#720=guide,BTN_TOP=start,BTN_TOP2=du,BTN_PINKIE=dr,BTN_BASE=dd,BTN_BASE2=dl
                            --ui-buttonmap a=KEY_Z,b=KEY_X,x=KEY_S,y=KEY_A,lb=KEY_F1,rb=KEY_F12,lt=KEY_HOME,rt=KEY_HOME,tl=KEY_HOME,tr=KEY_HOME,du=KEY_UP,dd=KEY_DOWN,dl=KEY_LEFT,dr=KEY_RIGHT,start=KEY_ESC
                              @pjft
                              Ah, OK. I'll try to dig up that post from a while back and see what happened there. It could be that it didn't work in GameMaker then either.
                                pjft @mediamogul
                                @mediamogul no problems. I'll also do some digging and report back.
                                Thanks, as always!
                                  spud11 @mediamogul
                                  @mediamogul Hi mediamogul. I've now used the expanded case statements and got it partially working. I've also resolved the Notepad++ newline problem, so that's now no longer an issue.
                                  The runcommand-onstart.sh below works with Amiga (2 player), but the remaining configurations don't.
                                  I have 4 DragonRise arcade style joysticks that move in 8 directions. I was hoping to have separate configurations for the 2 joysticks for Amiga. This part works. Then I was hoping to have a default configuration (8 way) for each of the 4 joysticks and separate default 4 way configurations for each joystick. After playing with "basic" and "extended" configurations, I found it a bit easier just to have full "basic" configurations. However, I suspect that has led to some conflicts along the way. It is the 8 way/4 way configurations that don't work at present. It spits out "no file or directory" as the error.
                                  I've got the statements all on one line, because I had to troubleshoot the Amiga configs and this appeared to work for those.
                                  For your info, I have a separate roms folder called "arcade-vertical" where games like Amidar, Pacman are.
                                  #!/bin/sh
                                  ## Uncomment one or all of the following if you need to find some information about the emulator or roms
                                  ## Name of the emulator
                                  #echo $1 >> /dev/shm/runcommand.log
                                  ## Name of the software used for running the emulation
                                  #echo $2 >> /dev/shm/runcommand.log
                                  ## Name of the rom
                                  #echo $3 >> /dev/shm/runcommand.log
                                  ##Executed command line
                                  #echo $4 >> /dev/shm/runcommand.log
                                  ### The FUN begins
                                  #Get ROM name striping full path
                                  rom="${3##*/}"
                                  ### Set variables for your joypad and emulator
                                  ### Basic Configurations - Standard controller mappings
                                  fourway="--four-way-restrictor"
                                  Amiga1="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Amiga_Joystick_Player_1_xboxdrv" --evdev-absmap ABS_X=y1,ABS_Y=x1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  Amiga2="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Amiga_Joystick_Player_2_xboxdrv" --evdev-absmap ABS_X=y1,ABS_Y=x1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  8way1="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_1_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  4way1="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_1_-_4_way_restricted_xboxdrv" --four-way-restrictor --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  8way2="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_2_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  4way2="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_2_-_4_way_restricted_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --four-way-restrictor --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  8way3="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_3_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  4way3="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_3_-_4_way_restricted_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --four-way-restrictor --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  8way4="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_4_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  4way4="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_4_-_4_way_restricted_xboxdrv" --four-way-restrictor --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &"
                                  ### Kill Command
                                  xboxkill="sudo killall xboxdrv"
                                  ### Execute the driver with the configuration you need
                                  # $1 is the name of the emulation, not the name of the software used
                                  # it is intellivision not jzintv
                                  case $1 in
                                      amiga)
                                          $xboxkill
                                          joycommand="$Amiga1 $Amiga2"
                                          eval $joycommand
                                  	 arcade-vertical)
                                          case $rom in
                                              "amidar.zip"|"atetris.zip"|"puckman.zip") # Configuration used only for these ROMs
                                                  $xboxkill
                                                  joycommand="$4way1 $4way2 $4way3 $4way4"
                                                  eval $joycommand
                                              *) # Configuration for every other ROM with this emulator
                                                  $xboxkill
                                                 joycommand="$8way1 $8way2 $8way3 $8way4"
                                                 eval $joycommand
                                          esac
                                  esac
                                  runcommand.log:
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 29: 8way1=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name Arcade_Joystick_Player_1_-_8_way_xboxdrv --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 31: 4way1=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name Arcade_Joystick_Player_1_-_4_way_restricted_xboxdrv --four-way-restrictor --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 33: 8way2=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name Arcade_Joystick_Player_2_-_8_way_xboxdrv --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 35: 4way2=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name Arcade_Joystick_Player_2_-_4_way_restricted_xboxdrv --evdev-absmap ABS_X=x1,ABS_Y=y1 --four-way-restrictor --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 37: 8way3=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name Arcade_Joystick_Player_3_-_8_way_xboxdrv --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 39: 4way3=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name Arcade_Joystick_Player_3_-_4_way_restricted_xboxdrv --evdev-absmap ABS_X=x1,ABS_Y=y1 --four-way-restrictor --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 41: 8way4=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name Arcade_Joystick_Player_4_-_8_way_xboxdrv --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 43: 4way4=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name Arcade_Joystick_Player_4_-_4_way_restricted_xboxdrv --four-way-restrictor --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                  Parameters:
                                  Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003/mame2003_libretro.so --config /opt/retropie/configs/mame-libretro/retroarch.cfg "/home/pi/RetroPie/roms/arcade-vertical/amidar.zip" --appendconfig /dev/shm/retroarch.cfg'|'"/home/pi/RetroPie/roms/arcade-vertical/amidar.zip.cfg"
                                  xboxdrv: no process found"
                                  Any help would be greatly appreciated. Thanks.
                                    @spud11
                                    It could be that the variables and --device-name arguments are both being wrapped in double quotation marks. Try wrapping the variables in single quotation marks and the --device-name arguments in doubles. For example:
                                    8way1='sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_1_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &'
                                      spud11 @mediamogul
                                      @mediamogul Hi mediamogul. Thank you. That is interesting. A lot of the errors I was getting earlier on before fixing the Amiga joysticks related to the device name. The only way I solved that was by using underscores in the name, simplifying the name and having the statement on one line - eg Amiga_Joystick_Player_1_xboxdrv .
                                      I've now made the change as suggested to all configurations including the Amiga joysticks, but the response is the same in runcommand.log:
                                      /opt/retropie/configs/all/runcommand-onstart.sh: line 29: 8way1=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_1_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                      /opt/retropie/configs/all/runcommand-onstart.sh: line 31: 4way1=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_1_-_4_way_restricted_xboxdrv" --four-way-restrictor --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                      /opt/retropie/configs/all/runcommand-onstart.sh: line 33: 8way2=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_2_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                      /opt/retropie/configs/all/runcommand-onstart.sh: line 35: 4way2=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_2_-_4_way_restricted_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --four-way-restrictor --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                      /opt/retropie/configs/all/runcommand-onstart.sh: line 37: 8way3=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_3_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                      /opt/retropie/configs/all/runcommand-onstart.sh: line 39: 4way3=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_3_-_4_way_restricted_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --four-way-restrictor --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                      /opt/retropie/configs/all/runcommand-onstart.sh: line 41: 8way4=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_4_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                      /opt/retropie/configs/all/runcommand-onstart.sh: line 43: 4way4=sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_4_-_4_way_restricted_xboxdrv" --four-way-restrictor --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
                                      Parameters:
                                        @spud11
                                        Just to cover the bases, you've tested that each of these commands work on their own from the command line?
                                          spud11 @mediamogul
                                          @mediamogul Yes, I have and they work from the commandline.
                                            @spud11
                                            Definitely keep the previous fix, but also try wrapping the path to xboxdrv in double quotations:
                                            8way1='sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_1_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &'
