    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 503.5k Views
      spud11 @mediamogul
      @mediamogul Hi mediamogul. Same response, I'm afraid:
      /opt/retropie/configs/all/runcommand-onstart.sh: line 29: 8way1=sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_1_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
      /opt/retropie/configs/all/runcommand-onstart.sh: line 31: 4way1=sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_1_-_4_way_restricted_xboxdrv" --four-way-restrictor --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
      /opt/retropie/configs/all/runcommand-onstart.sh: line 33: 8way2=sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_2_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
      /opt/retropie/configs/all/runcommand-onstart.sh: line 35: 4way2=sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_2_-_4_way_restricted_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --four-way-restrictor --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
      /opt/retropie/configs/all/runcommand-onstart.sh: line 37: 8way3=sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_3_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
      /opt/retropie/configs/all/runcommand-onstart.sh: line 39: 4way3=sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_3_-_4_way_restricted_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --four-way-restrictor --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
      /opt/retropie/configs/all/runcommand-onstart.sh: line 41: 8way4=sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_4_-_8_way_xboxdrv" --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
      /opt/retropie/configs/all/runcommand-onstart.sh: line 43: 4way4=sudo "/opt/retropie/supplementary/xboxdrv/bin/xboxdrv" --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick --silent --detach-kernel-driver --deadzone=4000 --deadzone-trigger 15% --force-feedback --mimic-xpad --trigger-as-button --device-name "Arcade_Joystick_Player_4_-_4_way_restricted_xboxdrv" --four-way-restrictor --evdev-absmap ABS_X=x1,ABS_Y=y1 --evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void &: No such file or directory
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003/mame2003_libretro.so --config /opt/retropie/configs/mame-libretro/retroarch.cfg "/home/pi/RetroPie/roms/arcade-vertical/amidar.zip" --appendconfig /dev/shm/retroarch.cfg'|'"/home/pi/RetroPie/roms/arcade-vertical/amidar.zip.cfg"
      xboxdrv: no process found
      Just for good measure, I tried on the commandline too and it does work from there.
        mediamogul Global Moderator @spud11
        @spud11
        I know this was an attempt to simplify the second method from the guide, but it might end up being easier to follow @MadHorse's example, seeing as how this hybrid method isn't working out.
          spud11 @mediamogul
          @mediamogul Hi. Thanks. No problem. I'll have another go with @madhorse technique. I'm just wondering though if that technique is going to work with multiple controllers, but will give it a go.
            @spud11 said in Guide: Advanced Controller Mappings:
            What you're looking to do is entirely possible, but it's also a very tailored use case scenario. I have a feeling you'll be dealing with a lot of trial and error no matter what. I'll help as best I can, but it's difficult from the back seat. Plus, my sister keeps kicking me and it smells back here.
              dunnieboy
              I am about to try this. I am going to attempt to use a PS4 controller to map a mouse in DosBOX. I have tried Joymap and only got the mouse to move around not capture clicks.
              I see that Lakka has default mouse capture, but I prefer retropie by far for customization.
              I am hoping this will solve my issue.
                mediamogul Global Moderator @dunnieboy
                @dunnieboy said in Guide: Advanced Controller Mappings:
                You're better off all around. The standalone DOSBox is just more flexible and has less overhead, allowing some of the more complicated and intensive DOS titles to run on the Pi.
                  dunnieboy @mediamogul
                  @mediamogul awesome ...well ... prepare for an onslaught of pleas for help =)
                    @dunnieboy
                    I'll try to answer them as best I can.
                      @mediamogul Ok .. here goes ...
                      I am going to step through what I did first, and ask questions along the way.
                      pi@retropie:~ $ cat /proc/bus/input/devices
                      returned
                      I: Bus=0003 Vendor=054c Product=09cc Version=0111
                      N: Name="Sony Interactive Entertainment Wireless Controller"
                      P: Phys=usb-3f980000.usb-1.5/input3
                      S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.3/0003:054C:09CC.0004/input/input0
                      U: Uniq=
                      H: Handlers=js0 event0
                      B: PROP=0
                      B: EV=1b
                      B: KEY=3fff0000 0 0 0 0 0 0 0 0 0
                      B: ABS=3003f
                      B: MSC=10
                      I: Bus=0003 Vendor=046d Product=404d Version=0111
                      N: Name="Logitech K400 Plus"
                      P: Phys=usb-3f980000.usb-1.4:1
                      S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:404D.0005/input/input1
                      U: Uniq=
                      H: Handlers=sysrq kbd leds mouse0 event1
                      B: PROP=0
                      B: EV=12001f
                      B: KEY=3007f 0 0 0 0 83ffff 17aff32d bf544446 0 0 ffff0001 130f97 8b17c007 ffff73fa d941dfff febeffdf ffefffff ffffffff fffffffe
                      B: REL=1c3
                      B: ABS=1 0
                      B: MSC=10
                      B: LED=1f
                      ls /dev/input/by-id
                      usb-Logitech_USB_Receiver-if02-event-mouse
                      usb-Logitech_USB_Receiver-if02-mouse
                      usb-Sony_Interactive_Entertainment_Wireless_Controller-if03-event-joystick
                      usb-Sony_Interactive_Entertainment_Wireless_Controller-if03-joystick
                      sudo nano /etc/rc.local
                      #!/bin/sh -e
                      # rc.local
                      # This script is executed at the end of each multiuser runlevel.
                      # Make sure that the script will "exit 0" on success or any other
                      # value on error.
                      # In order to enable or disable this script just change the execution
                      # bits.
                      # By default this script does nothing.
                      # Print the IP address
                      _IP=$(hostname -I) || true
                      if [ "$_IP" ]; then
                        printf "My IP address is %s\n" "$_IP"
                      fi
                      	--evdev /dev/input/event0 \
                      	--silent \
                      	--detach-kernel-driver \
                      	--force-feedback \
                      	--deadzone-trigger 15% \
                      	--deadzone 4000 \
                      	--device-name "donotroller" \
                      	--mimic-xpad \
                      	--evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RZ=y2,ABS_RX=lt,ABS_RY=rt,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
                      	--evdev-keymap BTN_EAST=a,BTN_C=b,BTN_SOUTH=x,BTN_NORTH=y,BTN_WEST=lb,BTN_Z=rb,BTN_START=tl,BTN_SELECT=tr,BTN_THUMBL=guide,BTN_TL2=back,BTN_TR2=start \
                      exit 0
                      sudo reboot and cat /proc/bus/input/devices
                      U: Uniq=
                      B: PROP=0
                      B: EV=1b
                      B: ABS=3003f
                      B: MSC=10
                      U: Uniq=
                      B: PROP=0
                      B: EV=12001f
                      B: REL=1c3
                      B: ABS=1 0
                      B: MSC=10
                      B: LED=1f
                      I: Bus=0003 Vendor=045e Product=028e Version=0110
                      N: Name="Microsoft X-Box 360 pad"
                      P: Phys=
                      S: Sysfs=/devices/virtual/input/input2
                      U: Uniq=
                      H: Handlers=js1 event2
                      B: PROP=0
                      B: EV=20000b
                      B: KEY=7cdb0000 0 0 0 0 0 0 0 0 0
                      B: ABS=3003f
                      B: FF=1 3f870000 0 0
                      I would have thought I would see "donotroller" as a device - what did I do wrong ???
                        @dunnieboy
                        Not all controllers have a unique event name. I believe you said you were wanting to map your PS4 controller and it appears to be listed above under the name "Sony Interactive Entertainment Wireless Controller". It's event handler is "event0", so you'll need to use "event0" to move on to the next steps.
                          @mediamogul Ok ... I figured out that it was the --mimic -xpad \ that was preventing the controller from being renamed. Do I need that line ?
                          I know have ...
                          I: Bus=0000 Vendor=0000 Product=0000 Version=0000
                          N: Name="donotroller"
                          P: Phys=
                          U: Uniq=
                          B: PROP=0
                          B: EV=20000b
                          B: ABS=3061b
                            @dunnieboy
                            You do not. If it's there, it will mimic the naming scheme and button arrangement of an authentic XBox3600 controller. Without it, you're free to create a virtual controller to your own specs.
                            • H
                              Hubz @spud11
                              @spud11 Hey Spud, would you mind sharing your list of 4-way games? Or tell me how you were able to figure them out? Was going to add them all to my script :)
                                @mediamogul OMG - Its working - a little chunky (slow) for command and conquer ... but i think that means I just need to adjust my dosbox config. Any suggestions would be appreciated.
                                One note ... I am adding the code to my fame config files ... I am not sure if this is the most elegant way of handling this ... what do you think .. here is an example.
                                #!/bin/bash
                                sudo killall >/dev/null xboxdrv
                                	--silent \
                                	--force-feedback \
                                	--deadzone 4000 \
                                	--calibration x1=-32767:0:32767,y1=-32767:0:32767,x2=-32767:0:32767,y2=-32767:0:32767 \
                                	--trigger-as-button \
                                	--axismap -Y1=Y1,-Y2=Y2 \
                                	--ui-axismap x1=REL_X:10,y1=REL_Y:10 \
                                	--ui-buttonmap b=BTN_LEFT,a=BTN_RIGHT,start=KEY_F5 \
                                	--ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,back=void \
                                	--ui-axismap x2=void \
                                /opt/retropie/emulators/dosbox/bin/dosbox -conf "/home/pi/RetroPie/roms/pc/CC_conf.conf"
                                  spud11 @Hubz
                                  @Hubz Certainly. I got the list from the website below:
                                  http://www.armchairarcade.com/neo/node/486
                                  001	.	Ali Baba and 40 Thieves
                                  002	.	Alpha Fighter / Head On
                                  003	.	Amidar
                                  004	.	Anteater
                                  005	.	Arm Wrestling
                                  006	.	Armored Car
                                  007	.	Astro Blaster
                                  008	.	Astro Fighter
                                  009	.	Astro Invader
                                  010	.	Bagman
                                  011	.	Balloon Bomber
                                  012	.	Barrier
                                  013	.	Black Hole
                                  014	.	Blasto
                                  015	.	Blockade
                                  016	.	Burger Time
                                  017	.	Car Jamboree
                                  018	.	Carnival
                                  019	.	Cavelon
                                  020	.	Chameleon
                                  021	.	Checkman
                                  022	.	Chinese Hero
                                  023	.	Circus Charlie
                                  024	.	Commando
                                  025	.	Comotion
                                  026	.	Congo Bongo
                                  027	.	Cops'n Robbers
                                  028	.	Cosmic Guerilla
                                  029	.	Cosmos1981
                                  030	.	Crash
                                  031	.	Crazy Kong (set 1)
                                  032	.	Crush Roller
                                  033	.	Dazzler
                                  034	.	Defend the Terra Attack on the Red UFO (bootleg)
                                  035	.	Devil Fish
                                  036	.	Diamond Run
                                  037	.	Dig Dug
                                  038	.	Dig Dug II
                                  039	.	Digger
                                  040	.	Disco No.1
                                  041	.	Do! Run Run (set 1)
                                  042	.	Dominos
                                  043	.	Dommy
                                  044	.	Donkey Kong
                                  045	.	Donkey Kong 3
                                  046	.	Donkey Kong Junior
                                  047	.	Dorodon (set 1)
                                  048	.	Dr. Micro
                                  049	.	Dragon Buster
                                  050	.	Dream Shopper
                                  051	.	Elevator Action
                                  052	.	Eyes
                                  053	.	Faster, Harder, More Challenging Q*bert (prototype)
                                  054	.	Fire Trap (US)
                                  055	.	Forty-Love
                                  056	.	Frogger
                                  057	.	Galaga
                                  058	.	Galaxian
                                  059	.	Galaxy Wars
                                  060	.	Gals Panic
                                  061	.	Gun Dealer (set 1)
                                  062	.	Guzzler
                                  063	.	Hard Hat
                                  064	.	Head On (2 players)
                                  065	.	Head On 2
                                  066	.	Heiankyo Alien
                                  067	.	Hexa
                                  068	.	Hustle
                                  069	.	Intrepid
                                  070	.	Invader's Revenge
                                  071	.	Invinco / Head On 2
                                  072	.	Iron Horse
                                  073	.	Joust 2 - Survival of the Fittest
                                  074	.	Jr. Pac-Man
                                  075	.	Jump Coaster
                                  076	.	Jumping Jack
                                  077	.	Jungler
                                  078	.	Karate Champ (US)
                                  079	.	Karian Cross (Rev. 1.0)
                                  080	.	Kicker
                                  081	.	King & Balloon
                                  082	.	Kung-Fu Master
                                  083	.	Lady Bug
                                  084	.	Las Vegas Girl (Girl '94)
                                  085	.	Lasso
                                  086	.	Levers
                                  087	.	Lock'n'Chase
                                  088	.	Loco-Motion
                                  089	.	Logger
                                  090	.	Logic Pro (Japan)
                                  091	.	Logic Pro 2 (Japan)
                                  092	.	Lunar Rescue
                                  093	.	Lupin III
                                  094	.	Mahjong Satsujin Jiken (Japan 881017)
                                  095	.	Mappy
                                  096	.	Marvin's Maze
                                  097	.	Meikyu Jima (Japan)
                                  098	.	Mikie
                                  099	.	Minesweeper
                                  100	.	Minky Monkey
                                  101	.	Monster Bash
                                  102	.	Moon Alien Part 2
                                  103	.	Moon Quasar
                                  104	.	Mouse Trap (version 5)
                                  105	.	Mr. Do!
                                  106	.	Mr. Do's Castle
                                  107	.	Mr. Do's Wild Ride
                                  108	.	Mr. F. Lea
                                  109	.	Mr. Goemon (Japan)
                                  110	.	Mr. Jong
                                  111	.	Mr. TNT
                                  112	.	Ms. Pac-Man
                                  113	.	Mysterious Stones
                                  114	.	NATO Defense
                                  115	.	Naughty Boy
                                  116	.	Net Wars
                                  117	.	New Rally X
                                  118	.	Oli-Boo-Chu
                                  119	.	Ozma Wars
                                  120	.	Pac & Pal
                                  121	.	Pac-Man
                                  122	.	Pac-Man Plus
                                  123	.	Pairs (System Ten) (Japan 890826)
                                  124	.	Pengo
                                  125	.	Pepper II
                                  126	.	Perestroika Girls
                                  127	.	Pettan Pyuu (Japan)
                                  128	.	Pickin'
                                  129	.	Pig Newton (version C)
                                  130	.	Pirate Ship HigeMaru
                                  131	.	Pisces
                                  132	.	Pleiads
                                  133	.	Pooyan
                                  134	.	Pop Flamer
                                  135	.	Popeye (revision D)
                                  136	.	Pulsar
                                  137	.	Punch-Out!!
                                  138	.	Q*bert
                                  139	.	Q*bert's Qubes
                                  140	.	Qix
                                  141	.	Radar Scope
                                  142	.	Raiders5
                                  143	.	Rally X
                                  144	.	Rampage (revision 3)
                                  145	.	Reikai Doushi (Japan)
                                  146	.	Return of the Invaders
                                  147	.	Robby Roto
                                  148	.	Roc'n Rope
                                  149	.	Rolling Thunder (new version)
                                  150	.	Route 16
                                  151	.	Route 16
                                  152	.	Samurai
                                  153	.	Samurai Nihon-ichi
                                  154	.	Satan's Hollow
                                  155	.	Scrambled Egg
                                  156	.	Side Track
                                  157	.	Sindbad Mystery
                                  158	.	Solar Fox
                                  159	.	Son of Phoenix
                                  160	.	Space Chaser
                                  161	.	Space Invaders
                                  162	.	Space Invaders Part II
                                  163	.	Space Laser
                                  164	.	Space Panic
                                  165	.	Space Zap
                                  166	.	Spectar (revision 3)
                                  167	.	Springer
                                  168	.	Stratovox
                                  169	.	Streaking
                                  170	.	Super Bagman
                                  171	.	Super Invader Attack
                                  172	.	Super Pac-Man
                                  173	.	Super Punch-Out!!
                                  174	.	Super Qix
                                  175	.	Super Space Invaders '91
                                  176	.	SWAT
                                  177	.	Tactician (set 1)
                                  178	.	Tank Battalion
                                  179	.	Tapper (Budweiser)
                                  180	.	Targ
                                  181	.	Taxi Driver
                                  182	.	Telephone Mahjong (Japan 890111)
                                  183	.	The Amazing Adventures of Mr. F. Lea
                                  184	.	The Electric Yo-Yo
                                  185	.	The Electric Yo-Yo (set 1)
                                  186	.	The End
                                  187	.	The Glob
                                  188	.	Thief
                                  189	.	Timber
                                  190	.	Time Limit
                                  191	.	Tomahawk 777
                                  192	.	Tower of Druaga
                                  193	.	Toypop
                                  194	.	Tranquilizer Gun
                                  195	.	Triple Punch
                                  196	.	Tutankham
                                  197	.	Van Van Car
                                  198	.	Volfied (World)
                                  199	.	VS Gong Fight
                                  200	.	Wai Wai Jockey Gate-In!
                                  201	.	Warp & Warp
                                  202	.	Wiping
                                  203	.	Wonder Momo
                                  204	.	Yam! Yam!?
                                  205	.	Zero Zone
                                  206	.	Zig Zag (Galaxian hardware, set 1)
                                  207	.	Zoo Keeper (set 1)
                                  208	.	Zzyzzyxx
                                  If you manage to create the right code to get them going, please let me know. I'll be working on it myself fairly shortly using the $3 scenario.
                                  pjftP H 2 Replies Last reply Reply Quote 0
                                    pjft @spud11
                                    @spud11 ... That Commando might be the Sega commando, not the Capcom one. Unless memory is playing tricks on me, I'd have a hard time playing the Capcom one with 4 directions only. I never played the Sega one, so that's why I'm guessing it's that one. I may be wrong though.
                                    Also unsure of whether Rolling Thunder wouldn't allow you to turn while crouching, which would suggest that there'd be use in 8-way controls.
                                    Still, great list, will certainly keep it for reference!
                                      spud11 @mediamogul
                                      @mediamogul That made me laugh. By the way, I have got it working up to a point using the @madhorse technique.
                                      The code is below, and a couple of interesting pointers for anyone else who finds themselves stuck and is not sure why:
                                      (a) the issue you alluded to with the --device-name problem definitely is a problem. It really doesn't seem to like any "white space" or "brackets" in the name. Adding underscores instead seems to work;
                                      (b) the start of each line shouldn't start with a number. For example, I've got "amiga1" for the name of my first Amiga joystick. If I had that as "1amiga", it would spit out errors. I think that's why my previous code wasn't working - because I had names like "8way" and "4way" for my joysticks. Starting a line with a number is verboten;
                                      (c) although I had set up a separate folder on the pi for my cocktail (arcade vertical) games, I needed to point to mame-libretro to get it working as I'm using lr-mame2003;
                                      (d) it's possible to get 2 (or more) joysticks working at the same time by using & but you have to remember to refer back to the "basic" joystick configuration each time.
                                      #!/bin/sh
                                      ## Uncomment one or all of the following if you need to find some information about the emulator or roms
                                      ## Name of the emulator
                                      #echo $1 >> /dev/shm/runcommand.log
                                      ## Name of the software used for running the emulation
                                      #echo $2 >> /dev/shm/runcommand.log
                                      ## Name of the rom
                                      #echo $3 >> /dev/shm/runcommand.log
                                      ##Executed command line
                                      #echo $4 >> /dev/shm/runcommand.log
                                      ### The FUN begins
                                      #Get ROM name striping full path
                                      rom="${3##*/}"
                                      ### Set variables for your joypad and emulator
                                      ### Basic Configurations - Standard controller mappings
                                      basic="sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv \
                                      --silent \
                                      --deadzone=4000 \
                                      --force-feedback \
                                      --mimic-xpad \
                                      --ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void"
                                      ### Extended Configurations
                                      ### Specific emulator configurations or any other parameters you will need only for some emulators
                                      scummVM="--axismap -Y1=Y1,-Y2=Y2 \
                                      	--ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \
                                      	--ui-axismap x2=void"
                                      amiga1="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick \
                                      	--device-name "Amiga_Joystick_Player_1_xboxdrv" \
                                      	--evdev-absmap ABS_X=y1,ABS_Y=x1 \
                                      	--evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start"
                                      amiga2="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick \
                                      	--device-name "Amiga_Joystick_Player_2_xboxdrv" \
                                      	--evdev-keymap BTN_TRIGGER=y,BTN_THUMB=a,BTN_THUMB2=back,BTN_PINKIE=x,BTN_TOP=b,BTN_TOP2=start"
                                      joy1restricted="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick \
                                      	--device-name "Player_1_-_4-Way_Joystick_xboxdrv" \
                                      	--evdev-absmap ABS_X=x1,ABS_Y=y1 \
                                      	--four-way-restrictor \
                                      joy1unrestricted="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.3:1.0-event-joystick \
                                      	--device-name "Player_1_-_8-Way_Joystick_xboxdrv" \
                                      joy2restricted="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick \
                                      	--device-name "Player_2_-_4-Way_Joystick_xboxdrv" \
                                      joy2unrestricted="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.1:1.0-event-joystick \
                                      	--device-name "Player_2_-_8-Way_Joystick_xboxdrv" \
                                      joy3restricted="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick \
                                      	--device-name "Player_3_-_4-Way_Joystick_xboxdrv" \
                                      joy3unrestricted="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.2:1.0-event-joystick \
                                      	--device-name "Player_3_-_8-Way_Joystick_xboxdrv" \
                                      joy4restricted="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick \
                                      	--device-name "Player_4_-_4-Way_Joystick_xboxdrv" \
                                      joy4unrestricted="--evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3.4:1.0-event-joystick \
                                      	--device-name "Player_4_-_8-Way_Joystick_xboxdrv" \
                                      fourway="--four-way-restrictor"
                                      invert="--ui-buttonmap du=KEY_DOWN,dd=KEY_UP"
                                      ### Kill Command
                                      xboxkill="sudo killall xboxdrv"
                                      ### Execute the driver with the configuration you need
                                      # $1 is the name of the emulation, not the name of the software used
                                      # it is intellivision not jzintv
                                      case $1 in
                                      	mame-libretro)
                                      	case $rom in
                                      			"amidar.zip"|"atetris.zip"|"puckman.zip") # Configuration used only for these ROMs
                                      				$xboxkill
                                      				joycommand="$basic $joy3restricted & $basic $joy4restricted &"
                                      				eval $joycommand
                                      			*) # Configuration for every other ROMs on this emulator
                                      				$xboxkill
                                      				joycommand="$basic $joy3unrestricted & $basic $joy4unrestricted &"
                                      				eval $joycommand
                                      		esac
                                      	daphne)
                                      	scummvm)
                                      		$xboxkill
                                      		joycommand="$basic $scummVM &"
                                      		eval $joycommand
                                      	amiga)
                                      		$xboxkill
                                      		joycommand="$basic $amiga1 & $basic $amiga2 &"
                                      		eval $joycommand
                                      	intellivision)
                                      esac
                                      So where I'm up to with this is that the Amiga joysticks work.
                                      But the same can't be said for the "cocktail" games. When I start Amidar for example, the little yellow writing at the bottom comes up and it informs me that the 4 DragonRise joysticks are set up and also starts joy3restricted and joy4restricted, but that they are unconfigured. The result of that is that I can't press any joystick buttons at all once the rom has begun (although the keyboard still works). Using TAB to get to Mame's internal menu doesn't help as I can't change the buttons. Exiting out of the rom with the keyboard triggers the runcommand-onend.sh file killing xboxdrv and everything then works as per normal using the xpad driver. (If I start Amidar without loading xboxdrv, then everything works but of course I'm using an 8-way unrestricted joystick.)
                                      To troubleshoot, as I'm using lr-mame2003, using putty I have first started xboxdrv for those 2 joysticks (joy3restricted and joy4restricted), then fired up retroarch and configured those joysticks as users 5 and 6, saving the configurations to retroarch.cfg.
                                      I then go back, start Amidar again, and note that joy3restricted and joy4restricted have started, but once again - no buttons work and using the mame TAB interface again doesn't do anything.
                                      Not sure where to go from here. Any help would be great please.
                                        spud11 @pjft
                                        @pjft I definitely can't take credit for the list, but I imagine you'll be right - that some of the games aren't really 4 way. I have the same recollection as you about Commando. I'm sure it's 8 way.
                                        It's going to be trial and error, I feel, for a lot of these games, particularly as there's going to be a need to match the game names to the actual rom names. Haven't figured out yet an automatic method of doing this to save time. May have to do it manually.....
                                        • H
                                          Hubz @spud11
                                          @spud11 Thanks a ton for the list! BTW I ran into that same error too with the devicename not working when having spaces in it. Glad to know I wasn't crazy and it happened to others as it took me forever to troubleshoot.
                                            spud11 @Hubz
                                            @Hubz No problems. It was mediamogul who picked it up.
